gz::sim::serializers Namespace Reference
A Serializer class is used to serialize and deserialize a component. It is passed in as the third template parameter to components::Component. Eg. More...
class  AnimationTimeSerializer
class  ComponentToMsgSerializer
 Serialization for that converts components data types to gz::msgs. This assumes that convert<DataType> is defined. More...
class  DefaultSerializer
 Default serializer template to call stream operators only on types that support them. If the stream operator is not available, a warning message is printed. More...
class  DefaultSerializer< components::NoData >
 Specialization of DefaultSerializer for NoData. More...
class  DetachableJointInfoSerializer
 Serializer for DetachableJointInfo object. More...
class  JointTypeSerializer
class  LevelEntityNamesSerializer
class  LogicalAudioSourcePlayInfoSerializer
 Serializer for components::LogicalAudioSourcePlayInfo object. More...
class  LogicalAudioSourceSerializer
 Serializer for components::LogicalAudioSource object. More...
class  LogicalMicrophoneSerializer
 Serializer for components::LogicalMicrophone object. More...
class  MsgSerializer
 Serializer for components that hold protobuf messages. More...
class  PerformerLevelsSerializer
class  SdfElementSerializer
class  SdfModelSerializer
class  StringSerializer
 Serializer for components that hold std::string. More...
class  TemperatureRangeInfoSerializer
 Serializer for components::TemperatureRangeInfo object. More...
class  VectorDoubleSerializer
 Serializer for components that hold std::vector<double>. More...
class  VectorSerializer
using ActorSerializer = serializers::ComponentToMsgSerializer< sdf::Actor, msgs::Actor >
using AtmosphereSerializer = serializers::ComponentToMsgSerializer< sdf::Atmosphere, msgs::Atmosphere >
using AxisAlignedBoxSerializer = serializers::ComponentToMsgSerializer< math::AxisAlignedBox, msgs::AxisAlignedBox >
using CollisionElementSerializer = serializers::ComponentToMsgSerializer< sdf::Collision, msgs::Collision >
using GeometrySerializer = serializers::ComponentToMsgSerializer< sdf::Geometry, msgs::Geometry >
using InertialSerializer = serializers::ComponentToMsgSerializer< math::Inertiald, msgs::Inertial >
using JointAxisSerializer = serializers::ComponentToMsgSerializer< sdf::JointAxis, msgs::Axis >
using LightSerializer = serializers::ComponentToMsgSerializer< sdf::Light, msgs::Light >
using MaterialSerializer = serializers::ComponentToMsgSerializer< sdf::Material, msgs::Material >
using PhysicsSerializer = serializers::ComponentToMsgSerializer< sdf::Physics, msgs::Physics >
using ProjectorSerializer = serializers::ComponentToMsgSerializer< sdf::Projector, msgs::Projector >
using SceneSerializer = serializers::ComponentToMsgSerializer< sdf::Scene, msgs::Scene >
using SensorSerializer = ComponentToMsgSerializer< sdf::Sensor, msgs::Sensor >
 Common serializer for sensors. More...
using SphericalCoordinatesSerializer = serializers::ComponentToMsgSerializer< math::SphericalCoordinates, msgs::SphericalCoordinates >
Functions
std::ostream & operator<< (std::ostream &_out, const logical_audio::AttenuationFunction &_func)
 Output stream overload for logical_audio::AttenuationFunction. More...
std::ostream & operator<< (std::ostream &_out, const logical_audio::AttenuationShape &_shape)
 Output stream overload for logical_audio::AttenuationShape. More...
std::ostream & operator<< (std::ostream &_out, const std::chrono::steady_clock::duration &_dur)
 Output stream overload for std::chrono::steady_clock::duration. More...
std::istream & operator>> (std::istream &_in, logical_audio::AttenuationFunction &_func)
 Input stream overload for logical_audio::AttenuationFunction. More...
std::istream & operator>> (std::istream &_in, logical_audio::AttenuationShape &_shape)
 Input stream overload for logical_audio::AttenuationShape. More...
std::istream & operator>> (std::istream &_in, std::chrono::steady_clock::duration &_dur)
 Input stream overload for std::chrono::steady_clock::duration. More...
using Geometry = components::Component<sdf::Geometry, GeometryTag,
A serializer class implements two static functions: Serialize and Deserialize with the following signatures
class ExampleSerializer
public: static std::ostream &Serialize(std::ostream &_out,
const DataType &_data);
public: static std::istream &Deserialize(std::istream &_in,
DataType &_data)
Typedef Documentation
◆ ActorSerializer
◆ AtmosphereSerializer
◆ AxisAlignedBoxSerializer
◆ CollisionElementSerializer
◆ GeometrySerializer
◆ InertialSerializer
◆ JointAxisSerializer
◆ LightSerializer
◆ MaterialSerializer
◆ PhysicsSerializer
◆ ProjectorSerializer
◆ SceneSerializer
◆ SensorSerializer
◆ SphericalCoordinatesSerializer
Function Documentation
◆ operator<<() [1/3]
std::ostream& gz::sim::serializers::operator<< ( std::ostream &  _out,
const logical_audio::AttenuationFunction &  _func
inline
◆ operator<<() [2/3]
const logical_audio::AttenuationShape &  _shape
inline
◆ operator<<() [3/3]
const std::chrono::steady_clock::duration &  _dur
inline
◆ operator>>() [1/3]
std::istream& gz::sim::serializers::operator>> ( std::istream &  _in,
inline
◆ operator>>() [2/3]
inline
◆ operator>>() [3/3]
inline
