ComponentToMsgSerializer< DataType, MsgType > Class Template Reference
Serialization for that converts components data types to gz::msgs. This assumes that convert<DataType> is defined. More...
#include <Serialization.hh>
static std::istream & Deserialize (std::istream &_in, DataType &_data)
 Deserialization. More...
static std::ostream & Serialize (std::ostream &_out, const DataType &_data)
 Serialization. More...
template<typename DataType, typename MsgType>
class gz::sim::serializers::ComponentToMsgSerializer< DataType, MsgType >
Template Parameters
DataTypeUnderlying data type of the component
This can be used for components that can be converted to gz::msg types via convert. For example sdf::Geometry can be converted to msgs::Geometry so the component can be defined as
using Geometry = Component<sdf::Geometry, class GeometryTag,
ComponentToMsgSerializer<sdf::Geometry, msgs::Geometry>>
◆ Deserialize()
static std::istream& Deserialize ( std::istream &  _in,
DataType &  _data
inlinestatic
Deserialization.
[in]_inInput stream.
[out]_datadata to populate
The stream.
References gz::msgs::Convert().
◆ Serialize()
static std::ostream& Serialize ( std::ostream &  _out,
const DataType &  _data
inlinestatic
Serialization.
[in]_outOutput stream.
[in]_datadata to stream
The stream.
