gz::msgs Namespace Reference
class  Actor
class  Actor_Animation
class  Actor_Trajectory
class  Actor_Waypoint
class  Actuators
class  AirPressureSensor
class  AirSpeedSensor
class  Altimeter
class  AltimeterSensor
class  AnnotatedAxisAligned2DBox
class  AnnotatedAxisAligned2DBox_V
class  AnnotatedOriented3DBox
class  AnnotatedOriented3DBox_V
class  Any
class  Atmosphere
class  Axis
class  AxisAligned2DBox
class  AxisAlignedBox
class  Battery
class  BatteryState
class  Boolean
class  BoxGeom
class  Bytes
class  CameraCmd
class  CameraInfo
class  CameraInfo_Distortion
class  CameraInfo_Intrinsics
class  CameraInfo_Projection
class  CameraLens
class  CameraSensor
class  CapsuleGeom
class  Cessna
class  Clock
class  CmdVel2D
class  Collision
class  Color
class  ConeGeom
class  Contact
class  Contacts
class  ContactSensor
class  CylinderGeom
class  Dataframe
class  DataLoadPathOptions
class  Density
class  Diagnostics
class  Diagnostics_DiagTime
class  DirIter
class  Discovery
class  Discovery_Flags
class  Discovery_Publisher
class  Discovery_Publisher_MessagePublisher
class  Discovery_Publisher_ServicePublisher
class  Discovery_Subscriber
class  Distortion
class  Double
class  Double_V
class  Duration
class  DVLBeamState
class  DVLKinematicEstimate
class  DVLRangeEstimate
class  DVLTrackingTarget
class  DVLVelocityTracking
class  EllipsoidGeom
class  Empty
class  Entity
class  EntityFactory
class  EntityFactory_V
class  EntityPlugin_V
class  EntityWrench
class  EntityWrenchMap
class  EntityWrenchMap_WrenchesEntry_DoNotUse
class  Factory
class  Float
class  Float_V
class  Fluid
class  FluidPressure
class  Fog
class  Friction
class  Friction_Torsional
class  Friction_Torsional_ODE
class  FuelMetadata
class  FuelMetadata_AnnotationsEntry_DoNotUse
class  FuelMetadata_Categories
class  FuelMetadata_Compatibility
class  FuelMetadata_Contact
class  FuelMetadata_Dependency
class  FuelMetadata_Legal
class  FuelMetadata_Model
class  FuelMetadata_World
class  Geometry
class  GPS
class  GPSSensor
class  GPSSensor_Sensing
class  GUI
class  GUICamera
class  Header
class  Header_Map
class  HeightmapGeom
class  HeightmapGeom_Blend
class  HeightmapGeom_Texture
class  Hydra
class  Hydra_Paddle
class  Image
class  ImageGeom
class  IMU
class  IMUSensor
class  IMUSensor_AngularVelocity
class  IMUSensor_LinearAcceleration
class  IMUSensor_OrientationReferenceFrame
class  Inertial
class  Int32
class  Int32_V
class  Int64
class  Int64_V
class  Joint
class  Joint_Gearbox
class  Joint_Screw
class  JointAnimation
class  JointAnimation_Joint
class  JointCmd
class  JointTrajectory
class  JointTrajectoryPoint
class  JointWrench
class  Joy
class  Joystick
class  LaserScan
class  Lens
class  LidarSensor
class  Light
class  Link
class  LinkData
class  LogControl
class  LogicalCameraImage
class  LogicalCameraImage_Model
class  LogicalCameraSensor
class  LogPlaybackControl
class  LogPlaybackStatistics
class  LogStatus
class  LogStatus_LogFile
class  Magnetometer
class  MagnetometerSensor
class  Marker
class  Marker_V
class  Material
class  Material_PBR
class  Material_Script
class  MeshGeom
class  Metric
class  Model
class  Model_V
class  ModelConfiguration
class  NavSat
class  NavSatSensor
class  NavSatSensor_Sensing
class  OccupancyGrid
class  OccupancyGrid_MapMetaInfo
class  Odometry
class  OdometryWithCovariance
class  Oriented3DBox
class  Packet
class  Param
class  Param_ParamsEntry_DoNotUse
class  Param_V
class  Parameter
class  ParameterDeclaration
class  ParameterDeclarations
class  ParameterError
class  ParameterName
class  ParameterValue
class  ParticleEmitter
class  ParticleEmitter_V
class  PerformanceSensorMetrics
class  Physics
class  PID
class  PlaneGeom
class  Plugin
class  Plugin_V
class  PointCloud
class  PointCloudPacked
class  PointCloudPacked_Field
class  PointCloudPackedConstIterator
class  PointCloudPackedIterator
class  Polyline
class  Pose
class  Pose_V
class  PoseAnimation
class  PoseTrajectory
class  PoseWithCovariance
class  Projector
class  PropagationGrid
class  PropagationParticle
class  Publish
class  Publishers
class  Quaternion
class  RaySensor
class  Request
class  Response
class  RestLogin
class  RestLogout
class  RestPost
class  RestResponse
class  Road
class  Scene
class  SdfGeneratorConfig
class  SdfGeneratorConfig_EntityGeneratorConfig
class  SdfGeneratorConfig_OverrideEntityGenConfigsEntry_DoNotUse
class  Selection
class  Sensor
class  Sensor_V
class  SensorNoise
class  SerializedComponent
class  SerializedEntity
class  SerializedEntityMap
class  SerializedEntityMap_ComponentsEntry_DoNotUse
class  SerializedState
class  SerializedStateMap
class  SerializedStateMap_EntitiesEntry_DoNotUse
class  SerializedStep
class  SerializedStepMap
class  ServerControl
class  Shadows
class  SimEvent
class  Sky
class  Sonar
class  SphereGeom
class  SphericalCoordinates
class  Statistic
class  StatisticsGroup
class  StringMsg
class  StringMsg_V
class  Subscribe
class  Surface
class  Tactile
class  Test
class  Time
class  TopicInfo
class  TrackVisual
class  Twist
class  TwistWithCovariance
class  UInt32
class  UInt32_V
class  UInt64
class  UInt64_V
class  UndoRedo
class  UserCmd
class  UserCmdStats
class  Vector2d
class  Vector3d
class  Version
class  VersionedName
class  VersionRange
class  VideoRecord
class  Visual
class  Visual_Meta
class  Visual_V
class  WebRequest
class  WheelSlipParametersCmd
class  Wind
class  WirelessNode
class  WirelessNodes
class  WorldControl
class  WorldControlState
class  WorldModify
class  WorldReset
class  WorldStatistics
class  Wrench
typedef std::unique_ptr< google::protobuf::Message >(* FactoryFn) ()
Enumerations
enum  Any_ValueType
enum  Atmosphere_Type
enum  BatteryState_PowerSupplyStatus
enum  CameraInfo_Distortion_DistortionModelType
enum  CameraSensor_BoundingBoxType
enum  CameraSensor_SegmentationType
enum  DataLoadPathOptions_DataAngularUnits
enum  Discovery_Publisher_Scope
enum  Discovery_Type
enum  DVLKinematicEstimate_ReferenceType
enum  DVLTrackingTarget_TargetType
enum  DVLVelocityTracking_DVLType
enum  Entity_Type
enum  FilesystemWarningOp
enum  Fog_FogType
enum  Geometry_Type
enum  Joint_Type
enum  Lens_FunctionType
enum  Lens_Type
enum  Light_LightType
enum  LogStatus_LogFile_Units
enum  Marker_Action
enum  Marker_Type
enum  Marker_Visibility
enum  Material_PBR_WorkflowType
enum  Material_ShaderType
enum  ParameterError_Type
enum  ParticleEmitter_EmitterType
enum  Physics_Type
enum  PixelFormatType
enum  PointCloudPacked_Field_DataType
enum  RestResponse_Type
enum  SensorNoise_Type
enum  Shadows_ShadowType
enum  SphericalCoordinates_SurfaceModel
enum  SphericalCoordinatesType
enum  Statistic_DataType
enum  UserCmd_Type
enum  Visual_Type
Functions
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Any_ValueType_descriptor ()
GZ_MSGS_VISIBLE bool Any_ValueType_IsValid (int value)
const ::std::string & Any_ValueType_Name (Any_ValueType value)
bool Any_ValueType_Parse (const ::std::string &name, Any_ValueType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Atmosphere_Type_descriptor ()
GZ_MSGS_VISIBLE bool Atmosphere_Type_IsValid (int value)
const ::std::string & Atmosphere_Type_Name (Atmosphere_Type value)
bool Atmosphere_Type_Parse (const ::std::string &name, Atmosphere_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * BatteryState_PowerSupplyStatus_descriptor ()
GZ_MSGS_VISIBLE bool BatteryState_PowerSupplyStatus_IsValid (int value)
const ::std::string & BatteryState_PowerSupplyStatus_Name (BatteryState_PowerSupplyStatus value)
bool BatteryState_PowerSupplyStatus_Parse (const ::std::string &name, BatteryState_PowerSupplyStatus *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * CameraInfo_Distortion_DistortionModelType_descriptor ()
GZ_MSGS_VISIBLE bool CameraInfo_Distortion_DistortionModelType_IsValid (int value)
const ::std::string & CameraInfo_Distortion_DistortionModelType_Name (CameraInfo_Distortion_DistortionModelType value)
bool CameraInfo_Distortion_DistortionModelType_Parse (const ::std::string &name, CameraInfo_Distortion_DistortionModelType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * CameraSensor_BoundingBoxType_descriptor ()
GZ_MSGS_VISIBLE bool CameraSensor_BoundingBoxType_IsValid (int value)
const ::std::string & CameraSensor_BoundingBoxType_Name (CameraSensor_BoundingBoxType value)
bool CameraSensor_BoundingBoxType_Parse (const ::std::string &name, CameraSensor_BoundingBoxType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * CameraSensor_SegmentationType_descriptor ()
GZ_MSGS_VISIBLE bool CameraSensor_SegmentationType_IsValid (int value)
const ::std::string & CameraSensor_SegmentationType_Name (CameraSensor_SegmentationType value)
bool CameraSensor_SegmentationType_Parse (const ::std::string &name, CameraSensor_SegmentationType *value)
msgs::Boolean Convert (const bool &_b)
msgs::Double Convert (const double &_d)
msgs::Float Convert (const float &_f)
msgs::PlaneGeom Convert (const gz::math::Planed &_p)
msgs::Pose Convert (const gz::math::Pose3d &_p)
msgs::Quaternion Convert (const gz::math::Quaterniond &_q)
msgs::Vector2d Convert (const gz::math::Vector2d &_v)
msgs::Vector3d Convert (const gz::math::Vector3d &_v)
msgs::Int32 Convert (const int32_t &_i)
msgs::Int64 Convert (const int64_t &_i)
msgs::AxisAlignedBox Convert (const math::AxisAlignedBox &_b)
msgs::Color Convert (const math::Color &_c)
msgs::Inertial Convert (const math::Inertiald &_i)
msgs::Inertial Convert (const math::MassMatrix3d &_m)
msgs::SphericalCoordinates Convert (const math::SphericalCoordinates &_coord)
math::AxisAlignedBox Convert (const msgs::AxisAlignedBox &_b)
bool Convert (const msgs::Boolean &_m)
math::Color Convert (const msgs::Color &_c)
double Convert (const msgs::Double &_m)
float Convert (const msgs::Float &_m)
math::Inertiald Convert (const msgs::Inertial &_i)
int32_t Convert (const msgs::Int32 &_m)
int64_t Convert (const msgs::Int64 &_m)
gz::math::Planed Convert (const msgs::PlaneGeom &_p)
gz::math::Pose3d Convert (const msgs::Pose &_p)
gz::math::Quaterniond Convert (const msgs::Quaternion &_q)
math::SphericalCoordinates Convert (const msgs::SphericalCoordinates &_coord)
math::SphericalCoordinates::CoordinateType Convert (const msgs::SphericalCoordinatesType &_sc)
std::string Convert (const msgs::StringMsg &_m)
std::chrono::steady_clock::duration Convert (const msgs::Time &_time)
uint32_t Convert (const msgs::UInt32 &_m)
uint64_t Convert (const msgs::UInt64 &_m)
gz::math::Vector2d Convert (const msgs::Vector2d &_v)
gz::math::Vector3d Convert (const msgs::Vector3d &_v)
msgs::Time Convert (const std::chrono::steady_clock::duration &_time_point)
msgs::StringMsg Convert (const std::string &_s)
msgs::UInt32 Convert (const uint32_t &_u)
msgs::UInt64 Convert (const uint64_t &_u)
msgs::SphericalCoordinatesType ConvertCoord (const math::SphericalCoordinates::CoordinateType &_coord)
bool ConvertFuelMetadata (const msgs::FuelMetadata &_meta, std::string &_modelConfigStr)
bool ConvertFuelMetadata (const std::string &_modelConfigStr, msgs::FuelMetadata &_meta)
std::string ConvertGeometryType (const msgs::Geometry::Type _type)
msgs::Geometry::Type ConvertGeometryType (const std::string &_str)
std::string ConvertJointType (const msgs::Joint::Type &_type)
msgs::Joint::Type ConvertJointType (const std::string &_str)
std::string ConvertPixelFormatType (const msgs::PixelFormatType &_t)
msgs::PixelFormatType ConvertPixelFormatType (const std::string &_str)
std::string ConvertShaderType (const msgs::Material::ShaderType &_type)
msgs::Material::ShaderType ConvertShaderType (const std::string &_str)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * DataLoadPathOptions_DataAngularUnits_descriptor ()
GZ_MSGS_VISIBLE bool DataLoadPathOptions_DataAngularUnits_IsValid (int value)
const ::std::string & DataLoadPathOptions_DataAngularUnits_Name (DataLoadPathOptions_DataAngularUnits value)
bool DataLoadPathOptions_DataAngularUnits_Parse (const ::std::string &name, DataLoadPathOptions_DataAngularUnits *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Discovery_Publisher_Scope_descriptor ()
GZ_MSGS_VISIBLE bool Discovery_Publisher_Scope_IsValid (int value)
const ::std::string & Discovery_Publisher_Scope_Name (Discovery_Publisher_Scope value)
bool Discovery_Publisher_Scope_Parse (const ::std::string &name, Discovery_Publisher_Scope *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Discovery_Type_descriptor ()
GZ_MSGS_VISIBLE bool Discovery_Type_IsValid (int value)
const ::std::string & Discovery_Type_Name (Discovery_Type value)
bool Discovery_Type_Parse (const ::std::string &name, Discovery_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * DVLKinematicEstimate_ReferenceType_descriptor ()
GZ_MSGS_VISIBLE bool DVLKinematicEstimate_ReferenceType_IsValid (int value)
const ::std::string & DVLKinematicEstimate_ReferenceType_Name (DVLKinematicEstimate_ReferenceType value)
bool DVLKinematicEstimate_ReferenceType_Parse (const ::std::string &name, DVLKinematicEstimate_ReferenceType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * DVLTrackingTarget_TargetType_descriptor ()
GZ_MSGS_VISIBLE bool DVLTrackingTarget_TargetType_IsValid (int value)
const ::std::string & DVLTrackingTarget_TargetType_Name (DVLTrackingTarget_TargetType value)
bool DVLTrackingTarget_TargetType_Parse (const ::std::string &name, DVLTrackingTarget_TargetType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * DVLVelocityTracking_DVLType_descriptor ()
GZ_MSGS_VISIBLE bool DVLVelocityTracking_DVLType_IsValid (int value)
const ::std::string & DVLVelocityTracking_DVLType_Name (DVLVelocityTracking_DVLType value)
bool DVLVelocityTracking_DVLType_Parse (const ::std::string &name, DVLVelocityTracking_DVLType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Entity_Type_descriptor ()
GZ_MSGS_VISIBLE bool Entity_Type_IsValid (int value)
const ::std::string & Entity_Type_Name (Entity_Type value)
bool Entity_Type_Parse (const ::std::string &name, Entity_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Fog_FogType_descriptor ()
GZ_MSGS_VISIBLE bool Fog_FogType_IsValid (int value)
const ::std::string & Fog_FogType_Name (Fog_FogType value)
bool Fog_FogType_Parse (const ::std::string &name, Fog_FogType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Geometry_Type_descriptor ()
GZ_MSGS_VISIBLE bool Geometry_Type_IsValid (int value)
const ::std::string & Geometry_Type_Name (Geometry_Type value)
bool Geometry_Type_Parse (const ::std::string &name, Geometry_Type *value)
void InitPointCloudPacked (msgs::PointCloudPacked &_msg, const std::string &_frameId, bool _memoryAligned, const std::vector< std::pair< std::string, msgs::PointCloudPacked::Field::DataType >> &_fields)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Joint_Type_descriptor ()
GZ_MSGS_VISIBLE bool Joint_Type_IsValid (int value)
const ::std::string & Joint_Type_Name (Joint_Type value)
bool Joint_Type_Parse (const ::std::string &name, Joint_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Lens_FunctionType_descriptor ()
GZ_MSGS_VISIBLE bool Lens_FunctionType_IsValid (int value)
const ::std::string & Lens_FunctionType_Name (Lens_FunctionType value)
bool Lens_FunctionType_Parse (const ::std::string &name, Lens_FunctionType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Lens_Type_descriptor ()
GZ_MSGS_VISIBLE bool Lens_Type_IsValid (int value)
const ::std::string & Lens_Type_Name (Lens_Type value)
bool Lens_Type_Parse (const ::std::string &name, Lens_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Light_LightType_descriptor ()
GZ_MSGS_VISIBLE bool Light_LightType_IsValid (int value)
const ::std::string & Light_LightType_Name (Light_LightType value)
bool Light_LightType_Parse (const ::std::string &name, Light_LightType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * LogStatus_LogFile_Units_descriptor ()
GZ_MSGS_VISIBLE bool LogStatus_LogFile_Units_IsValid (int value)
const ::std::string & LogStatus_LogFile_Units_Name (LogStatus_LogFile_Units value)
bool LogStatus_LogFile_Units_Parse (const ::std::string &name, LogStatus_LogFile_Units *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Marker_Action_descriptor ()
GZ_MSGS_VISIBLE bool Marker_Action_IsValid (int value)
const ::std::string & Marker_Action_Name (Marker_Action value)
bool Marker_Action_Parse (const ::std::string &name, Marker_Action *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Marker_Type_descriptor ()
GZ_MSGS_VISIBLE bool Marker_Type_IsValid (int value)
const ::std::string & Marker_Type_Name (Marker_Type value)
bool Marker_Type_Parse (const ::std::string &name, Marker_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Marker_Visibility_descriptor ()
GZ_MSGS_VISIBLE bool Marker_Visibility_IsValid (int value)
const ::std::string & Marker_Visibility_Name (Marker_Visibility value)
bool Marker_Visibility_Parse (const ::std::string &name, Marker_Visibility *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Material_PBR_WorkflowType_descriptor ()
GZ_MSGS_VISIBLE bool Material_PBR_WorkflowType_IsValid (int value)
const ::std::string & Material_PBR_WorkflowType_Name (Material_PBR_WorkflowType value)
bool Material_PBR_WorkflowType_Parse (const ::std::string &name, Material_PBR_WorkflowType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Material_ShaderType_descriptor ()
GZ_MSGS_VISIBLE bool Material_ShaderType_IsValid (int value)
const ::std::string & Material_ShaderType_Name (Material_ShaderType value)
bool Material_ShaderType_Parse (const ::std::string &name, Material_ShaderType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * ParameterError_Type_descriptor ()
GZ_MSGS_VISIBLE bool ParameterError_Type_IsValid (int value)
const ::std::string & ParameterError_Type_Name (ParameterError_Type value)
bool ParameterError_Type_Parse (const ::std::string &name, ParameterError_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * ParticleEmitter_EmitterType_descriptor ()
GZ_MSGS_VISIBLE bool ParticleEmitter_EmitterType_IsValid (int value)
const ::std::string & ParticleEmitter_EmitterType_Name (ParticleEmitter_EmitterType value)
bool ParticleEmitter_EmitterType_Parse (const ::std::string &name, ParticleEmitter_EmitterType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Physics_Type_descriptor ()
GZ_MSGS_VISIBLE bool Physics_Type_IsValid (int value)
const ::std::string & Physics_Type_Name (Physics_Type value)
bool Physics_Type_Parse (const ::std::string &name, Physics_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * PixelFormatType_descriptor ()
GZ_MSGS_VISIBLE bool PixelFormatType_IsValid (int value)
const ::std::string & PixelFormatType_Name (PixelFormatType value)
bool PixelFormatType_Parse (const ::std::string &name, PixelFormatType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * PointCloudPacked_Field_DataType_descriptor ()
GZ_MSGS_VISIBLE bool PointCloudPacked_Field_DataType_IsValid (int value)
const ::std::string & PointCloudPacked_Field_DataType_Name (PointCloudPacked_Field_DataType value)
bool PointCloudPacked_Field_DataType_Parse (const ::std::string &name, PointCloudPacked_Field_DataType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * RestResponse_Type_descriptor ()
GZ_MSGS_VISIBLE bool RestResponse_Type_IsValid (int value)
const ::std::string & RestResponse_Type_Name (RestResponse_Type value)
bool RestResponse_Type_Parse (const ::std::string &name, RestResponse_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * SensorNoise_Type_descriptor ()
GZ_MSGS_VISIBLE bool SensorNoise_Type_IsValid (int value)
const ::std::string & SensorNoise_Type_Name (SensorNoise_Type value)
bool SensorNoise_Type_Parse (const ::std::string &name, SensorNoise_Type *value)
void Set (msgs::AxisAlignedBox *_b, const math::AxisAlignedBox &_v)
void Set (msgs::Boolean *_p, const bool &_v)
void Set (msgs::Color *_c, const math::Color &_v)
void Set (msgs::Double *_p, const double &_v)
void Set (msgs::Float *_p, const float &_v)
void Set (msgs::Inertial *_i, const math::Inertiald &_m)
void Set (msgs::Inertial *_i, const math::MassMatrix3d &_m)
void Set (msgs::Int32 *_p, const int32_t &_v)
void Set (msgs::Int64 *_p, const int64_t &_v)
void Set (msgs::PlaneGeom *_p, const gz::math::Planed &_v)
void Set (msgs::Pose *_p, const gz::math::Pose3d &_v)
void Set (msgs::Quaternion *_q, const gz::math::Quaterniond &_v)
void Set (msgs::SphericalCoordinates *_sc, const math::SphericalCoordinates &_m)
void Set (msgs::StringMsg *_p, const std::string &_v)
void Set (msgs::UInt32 *_p, const uint32_t &_v)
void Set (msgs::UInt64 *_p, const uint64_t &_v)
void Set (msgs::Vector2d *_pt, const gz::math::Vector2d &_v)
void Set (msgs::Vector3d *_pt, const gz::math::Vector3d &_v)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Shadows_ShadowType_descriptor ()
GZ_MSGS_VISIBLE bool Shadows_ShadowType_IsValid (int value)
const ::std::string & Shadows_ShadowType_Name (Shadows_ShadowType value)
bool Shadows_ShadowType_Parse (const ::std::string &name, Shadows_ShadowType *value)
int sizeOfPointField (PointCloudPacked::Field::DataType _dataType)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * SphericalCoordinates_SurfaceModel_descriptor ()
GZ_MSGS_VISIBLE bool SphericalCoordinates_SurfaceModel_IsValid (int value)
const ::std::string & SphericalCoordinates_SurfaceModel_Name (SphericalCoordinates_SurfaceModel value)
bool SphericalCoordinates_SurfaceModel_Parse (const ::std::string &name, SphericalCoordinates_SurfaceModel *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * SphericalCoordinatesType_descriptor ()
GZ_MSGS_VISIBLE bool SphericalCoordinatesType_IsValid (int value)
const ::std::string & SphericalCoordinatesType_Name (SphericalCoordinatesType value)
bool SphericalCoordinatesType_Parse (const ::std::string &name, SphericalCoordinatesType *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Statistic_DataType_descriptor ()
GZ_MSGS_VISIBLE bool Statistic_DataType_IsValid (int value)
const ::std::string & Statistic_DataType_Name (Statistic_DataType value)
bool Statistic_DataType_Parse (const ::std::string &name, Statistic_DataType *value)
std::string ToString (const msgs::Discovery::Type &_t)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * UserCmd_Type_descriptor ()
GZ_MSGS_VISIBLE bool UserCmd_Type_IsValid (int value)
const ::std::string & UserCmd_Type_Name (UserCmd_Type value)
bool UserCmd_Type_Parse (const ::std::string &name, UserCmd_Type *value)
const GZ_MSGS_VISIBLE ::google::protobuf::EnumDescriptor * Visual_Type_descriptor ()
GZ_MSGS_VISIBLE bool Visual_Type_IsValid (int value)
const ::std::string & Visual_Type_Name (Visual_Type value)
bool Visual_Type_Parse (const ::std::string &name, Visual_Type *value)
Variables
GZ_MSGS_VISIBLE Actor_AnimationDefaultTypeInternal _Actor_Animation_default_instance_
GZ_MSGS_VISIBLE ActorDefaultTypeInternal _Actor_default_instance_
GZ_MSGS_VISIBLE Actor_TrajectoryDefaultTypeInternal _Actor_Trajectory_default_instance_
GZ_MSGS_VISIBLE Actor_WaypointDefaultTypeInternal _Actor_Waypoint_default_instance_
GZ_MSGS_VISIBLE ActuatorsDefaultTypeInternal _Actuators_default_instance_
GZ_MSGS_VISIBLE AirPressureSensorDefaultTypeInternal _AirPressureSensor_default_instance_
GZ_MSGS_VISIBLE AirSpeedSensorDefaultTypeInternal _AirSpeedSensor_default_instance_
GZ_MSGS_VISIBLE AltimeterDefaultTypeInternal _Altimeter_default_instance_
GZ_MSGS_VISIBLE AltimeterSensorDefaultTypeInternal _AltimeterSensor_default_instance_
GZ_MSGS_VISIBLE AnnotatedAxisAligned2DBoxDefaultTypeInternal _AnnotatedAxisAligned2DBox_default_instance_
GZ_MSGS_VISIBLE AnnotatedAxisAligned2DBox_VDefaultTypeInternal _AnnotatedAxisAligned2DBox_V_default_instance_
GZ_MSGS_VISIBLE AnnotatedOriented3DBoxDefaultTypeInternal _AnnotatedOriented3DBox_default_instance_
GZ_MSGS_VISIBLE AnnotatedOriented3DBox_VDefaultTypeInternal _AnnotatedOriented3DBox_V_default_instance_
GZ_MSGS_VISIBLE AnyDefaultTypeInternal _Any_default_instance_
GZ_MSGS_VISIBLE AtmosphereDefaultTypeInternal _Atmosphere_default_instance_
GZ_MSGS_VISIBLE AxisDefaultTypeInternal _Axis_default_instance_
GZ_MSGS_VISIBLE AxisAligned2DBoxDefaultTypeInternal _AxisAligned2DBox_default_instance_
GZ_MSGS_VISIBLE AxisAlignedBoxDefaultTypeInternal _AxisAlignedBox_default_instance_
GZ_MSGS_VISIBLE BatteryDefaultTypeInternal _Battery_default_instance_
GZ_MSGS_VISIBLE BatteryStateDefaultTypeInternal _BatteryState_default_instance_
GZ_MSGS_VISIBLE BooleanDefaultTypeInternal _Boolean_default_instance_
GZ_MSGS_VISIBLE BoxGeomDefaultTypeInternal _BoxGeom_default_instance_
GZ_MSGS_VISIBLE BytesDefaultTypeInternal _Bytes_default_instance_
GZ_MSGS_VISIBLE CameraCmdDefaultTypeInternal _CameraCmd_default_instance_
GZ_MSGS_VISIBLE CameraInfoDefaultTypeInternal _CameraInfo_default_instance_
GZ_MSGS_VISIBLE CameraInfo_DistortionDefaultTypeInternal _CameraInfo_Distortion_default_instance_
GZ_MSGS_VISIBLE CameraInfo_IntrinsicsDefaultTypeInternal _CameraInfo_Intrinsics_default_instance_
GZ_MSGS_VISIBLE CameraInfo_ProjectionDefaultTypeInternal _CameraInfo_Projection_default_instance_
GZ_MSGS_VISIBLE CameraLensDefaultTypeInternal _CameraLens_default_instance_
GZ_MSGS_VISIBLE CameraSensorDefaultTypeInternal _CameraSensor_default_instance_
GZ_MSGS_VISIBLE CapsuleGeomDefaultTypeInternal _CapsuleGeom_default_instance_
GZ_MSGS_VISIBLE CessnaDefaultTypeInternal _Cessna_default_instance_
GZ_MSGS_VISIBLE ClockDefaultTypeInternal _Clock_default_instance_
GZ_MSGS_VISIBLE CmdVel2DDefaultTypeInternal _CmdVel2D_default_instance_
GZ_MSGS_VISIBLE CollisionDefaultTypeInternal _Collision_default_instance_
GZ_MSGS_VISIBLE ColorDefaultTypeInternal _Color_default_instance_
GZ_MSGS_VISIBLE ConeGeomDefaultTypeInternal _ConeGeom_default_instance_
GZ_MSGS_VISIBLE ContactDefaultTypeInternal _Contact_default_instance_
GZ_MSGS_VISIBLE ContactsDefaultTypeInternal _Contacts_default_instance_
GZ_MSGS_VISIBLE ContactSensorDefaultTypeInternal _ContactSensor_default_instance_
GZ_MSGS_VISIBLE CylinderGeomDefaultTypeInternal _CylinderGeom_default_instance_
GZ_MSGS_VISIBLE DataframeDefaultTypeInternal _Dataframe_default_instance_
GZ_MSGS_VISIBLE DataLoadPathOptionsDefaultTypeInternal _DataLoadPathOptions_default_instance_
GZ_MSGS_VISIBLE DensityDefaultTypeInternal _Density_default_instance_
GZ_MSGS_VISIBLE DiagnosticsDefaultTypeInternal _Diagnostics_default_instance_
GZ_MSGS_VISIBLE Diagnostics_DiagTimeDefaultTypeInternal _Diagnostics_DiagTime_default_instance_
GZ_MSGS_VISIBLE DiscoveryDefaultTypeInternal _Discovery_default_instance_
GZ_MSGS_VISIBLE Discovery_FlagsDefaultTypeInternal _Discovery_Flags_default_instance_
GZ_MSGS_VISIBLE Discovery_PublisherDefaultTypeInternal _Discovery_Publisher_default_instance_
GZ_MSGS_VISIBLE Discovery_Publisher_MessagePublisherDefaultTypeInternal _Discovery_Publisher_MessagePublisher_default_instance_
GZ_MSGS_VISIBLE Discovery_Publisher_ServicePublisherDefaultTypeInternal _Discovery_Publisher_ServicePublisher_default_instance_
GZ_MSGS_VISIBLE Discovery_SubscriberDefaultTypeInternal _Discovery_Subscriber_default_instance_
GZ_MSGS_VISIBLE DistortionDefaultTypeInternal _Distortion_default_instance_
GZ_MSGS_VISIBLE DoubleDefaultTypeInternal _Double_default_instance_
GZ_MSGS_VISIBLE Double_VDefaultTypeInternal _Double_V_default_instance_
GZ_MSGS_VISIBLE DurationDefaultTypeInternal _Duration_default_instance_
GZ_MSGS_VISIBLE DVLBeamStateDefaultTypeInternal _DVLBeamState_default_instance_
GZ_MSGS_VISIBLE DVLKinematicEstimateDefaultTypeInternal _DVLKinematicEstimate_default_instance_
GZ_MSGS_VISIBLE DVLRangeEstimateDefaultTypeInternal _DVLRangeEstimate_default_instance_
GZ_MSGS_VISIBLE DVLTrackingTargetDefaultTypeInternal _DVLTrackingTarget_default_instance_
GZ_MSGS_VISIBLE DVLVelocityTrackingDefaultTypeInternal _DVLVelocityTracking_default_instance_
GZ_MSGS_VISIBLE EllipsoidGeomDefaultTypeInternal _EllipsoidGeom_default_instance_
GZ_MSGS_VISIBLE EmptyDefaultTypeInternal _Empty_default_instance_
GZ_MSGS_VISIBLE EntityDefaultTypeInternal _Entity_default_instance_
GZ_MSGS_VISIBLE EntityFactoryDefaultTypeInternal _EntityFactory_default_instance_
GZ_MSGS_VISIBLE EntityFactory_VDefaultTypeInternal _EntityFactory_V_default_instance_
GZ_MSGS_VISIBLE EntityPlugin_VDefaultTypeInternal _EntityPlugin_V_default_instance_
GZ_MSGS_VISIBLE EntityWrenchDefaultTypeInternal _EntityWrench_default_instance_
GZ_MSGS_VISIBLE EntityWrenchMapDefaultTypeInternal _EntityWrenchMap_default_instance_
GZ_MSGS_VISIBLE EntityWrenchMap_WrenchesEntry_DoNotUseDefaultTypeInternal _EntityWrenchMap_WrenchesEntry_DoNotUse_default_instance_
GZ_MSGS_VISIBLE FloatDefaultTypeInternal _Float_default_instance_
GZ_MSGS_VISIBLE Float_VDefaultTypeInternal _Float_V_default_instance_
GZ_MSGS_VISIBLE FluidDefaultTypeInternal _Fluid_default_instance_
GZ_MSGS_VISIBLE FluidPressureDefaultTypeInternal _FluidPressure_default_instance_
GZ_MSGS_VISIBLE FogDefaultTypeInternal _Fog_default_instance_
GZ_MSGS_VISIBLE FrictionDefaultTypeInternal _Friction_default_instance_
GZ_MSGS_VISIBLE Friction_TorsionalDefaultTypeInternal _Friction_Torsional_default_instance_
GZ_MSGS_VISIBLE Friction_Torsional_ODEDefaultTypeInternal _Friction_Torsional_ODE_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_AnnotationsEntry_DoNotUseDefaultTypeInternal _FuelMetadata_AnnotationsEntry_DoNotUse_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_CategoriesDefaultTypeInternal _FuelMetadata_Categories_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_CompatibilityDefaultTypeInternal _FuelMetadata_Compatibility_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_ContactDefaultTypeInternal _FuelMetadata_Contact_default_instance_
GZ_MSGS_VISIBLE FuelMetadataDefaultTypeInternal _FuelMetadata_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_DependencyDefaultTypeInternal _FuelMetadata_Dependency_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_LegalDefaultTypeInternal _FuelMetadata_Legal_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_ModelDefaultTypeInternal _FuelMetadata_Model_default_instance_
GZ_MSGS_VISIBLE FuelMetadata_WorldDefaultTypeInternal _FuelMetadata_World_default_instance_
GZ_MSGS_VISIBLE GeometryDefaultTypeInternal _Geometry_default_instance_
GZ_MSGS_VISIBLE GPSDefaultTypeInternal _GPS_default_instance_
GZ_MSGS_VISIBLE GPSSensorDefaultTypeInternal _GPSSensor_default_instance_
GZ_MSGS_VISIBLE GPSSensor_SensingDefaultTypeInternal _GPSSensor_Sensing_default_instance_
GZ_MSGS_VISIBLE GUIDefaultTypeInternal _GUI_default_instance_
GZ_MSGS_VISIBLE GUICameraDefaultTypeInternal _GUICamera_default_instance_
GZ_MSGS_VISIBLE HeaderDefaultTypeInternal _Header_default_instance_
GZ_MSGS_VISIBLE Header_MapDefaultTypeInternal _Header_Map_default_instance_
GZ_MSGS_VISIBLE HeightmapGeom_BlendDefaultTypeInternal _HeightmapGeom_Blend_default_instance_
GZ_MSGS_VISIBLE HeightmapGeomDefaultTypeInternal _HeightmapGeom_default_instance_
GZ_MSGS_VISIBLE HeightmapGeom_TextureDefaultTypeInternal _HeightmapGeom_Texture_default_instance_
GZ_MSGS_VISIBLE HydraDefaultTypeInternal _Hydra_default_instance_
GZ_MSGS_VISIBLE Hydra_PaddleDefaultTypeInternal _Hydra_Paddle_default_instance_
GZ_MSGS_VISIBLE ImageDefaultTypeInternal _Image_default_instance_
GZ_MSGS_VISIBLE ImageGeomDefaultTypeInternal _ImageGeom_default_instance_
GZ_MSGS_VISIBLE IMUDefaultTypeInternal _IMU_default_instance_
GZ_MSGS_VISIBLE IMUSensor_AngularVelocityDefaultTypeInternal _IMUSensor_AngularVelocity_default_instance_
GZ_MSGS_VISIBLE IMUSensorDefaultTypeInternal _IMUSensor_default_instance_
GZ_MSGS_VISIBLE IMUSensor_LinearAccelerationDefaultTypeInternal _IMUSensor_LinearAcceleration_default_instance_
GZ_MSGS_VISIBLE IMUSensor_OrientationReferenceFrameDefaultTypeInternal _IMUSensor_OrientationReferenceFrame_default_instance_
GZ_MSGS_VISIBLE InertialDefaultTypeInternal _Inertial_default_instance_
GZ_MSGS_VISIBLE Int32DefaultTypeInternal _Int32_default_instance_
GZ_MSGS_VISIBLE Int32_VDefaultTypeInternal _Int32_V_default_instance_
GZ_MSGS_VISIBLE Int64DefaultTypeInternal _Int64_default_instance_
GZ_MSGS_VISIBLE Int64_VDefaultTypeInternal _Int64_V_default_instance_
GZ_MSGS_VISIBLE JointDefaultTypeInternal _Joint_default_instance_
GZ_MSGS_VISIBLE Joint_GearboxDefaultTypeInternal _Joint_Gearbox_default_instance_
GZ_MSGS_VISIBLE Joint_ScrewDefaultTypeInternal _Joint_Screw_default_instance_
GZ_MSGS_VISIBLE JointAnimationDefaultTypeInternal _JointAnimation_default_instance_
GZ_MSGS_VISIBLE JointAnimation_JointDefaultTypeInternal _JointAnimation_Joint_default_instance_
GZ_MSGS_VISIBLE JointCmdDefaultTypeInternal _JointCmd_default_instance_
GZ_MSGS_VISIBLE JointTrajectoryDefaultTypeInternal _JointTrajectory_default_instance_
GZ_MSGS_VISIBLE JointTrajectoryPointDefaultTypeInternal _JointTrajectoryPoint_default_instance_
GZ_MSGS_VISIBLE JointWrenchDefaultTypeInternal _JointWrench_default_instance_
GZ_MSGS_VISIBLE JoyDefaultTypeInternal _Joy_default_instance_
GZ_MSGS_VISIBLE JoystickDefaultTypeInternal _Joystick_default_instance_
GZ_MSGS_VISIBLE LaserScanDefaultTypeInternal _LaserScan_default_instance_
GZ_MSGS_VISIBLE LensDefaultTypeInternal _Lens_default_instance_
GZ_MSGS_VISIBLE LidarSensorDefaultTypeInternal _LidarSensor_default_instance_
GZ_MSGS_VISIBLE LightDefaultTypeInternal _Light_default_instance_
GZ_MSGS_VISIBLE LinkDefaultTypeInternal _Link_default_instance_
GZ_MSGS_VISIBLE LinkDataDefaultTypeInternal _LinkData_default_instance_
GZ_MSGS_VISIBLE LogControlDefaultTypeInternal _LogControl_default_instance_
GZ_MSGS_VISIBLE LogicalCameraImageDefaultTypeInternal _LogicalCameraImage_default_instance_
GZ_MSGS_VISIBLE LogicalCameraImage_ModelDefaultTypeInternal _LogicalCameraImage_Model_default_instance_
GZ_MSGS_VISIBLE LogicalCameraSensorDefaultTypeInternal _LogicalCameraSensor_default_instance_
GZ_MSGS_VISIBLE LogPlaybackControlDefaultTypeInternal _LogPlaybackControl_default_instance_
GZ_MSGS_VISIBLE LogPlaybackStatisticsDefaultTypeInternal _LogPlaybackStatistics_default_instance_
GZ_MSGS_VISIBLE LogStatusDefaultTypeInternal _LogStatus_default_instance_
GZ_MSGS_VISIBLE LogStatus_LogFileDefaultTypeInternal _LogStatus_LogFile_default_instance_
GZ_MSGS_VISIBLE MagnetometerDefaultTypeInternal _Magnetometer_default_instance_
GZ_MSGS_VISIBLE MagnetometerSensorDefaultTypeInternal _MagnetometerSensor_default_instance_
GZ_MSGS_VISIBLE MarkerDefaultTypeInternal _Marker_default_instance_
GZ_MSGS_VISIBLE Marker_VDefaultTypeInternal _Marker_V_default_instance_
GZ_MSGS_VISIBLE MaterialDefaultTypeInternal _Material_default_instance_
GZ_MSGS_VISIBLE Material_PBRDefaultTypeInternal _Material_PBR_default_instance_
GZ_MSGS_VISIBLE Material_ScriptDefaultTypeInternal _Material_Script_default_instance_
GZ_MSGS_VISIBLE MeshGeomDefaultTypeInternal _MeshGeom_default_instance_
GZ_MSGS_VISIBLE MetricDefaultTypeInternal _Metric_default_instance_
GZ_MSGS_VISIBLE ModelDefaultTypeInternal _Model_default_instance_
GZ_MSGS_VISIBLE Model_VDefaultTypeInternal _Model_V_default_instance_
GZ_MSGS_VISIBLE ModelConfigurationDefaultTypeInternal _ModelConfiguration_default_instance_
GZ_MSGS_VISIBLE NavSatDefaultTypeInternal _NavSat_default_instance_
GZ_MSGS_VISIBLE NavSatSensorDefaultTypeInternal _NavSatSensor_default_instance_
GZ_MSGS_VISIBLE NavSatSensor_SensingDefaultTypeInternal _NavSatSensor_Sensing_default_instance_
GZ_MSGS_VISIBLE OccupancyGridDefaultTypeInternal _OccupancyGrid_default_instance_
GZ_MSGS_VISIBLE OccupancyGrid_MapMetaInfoDefaultTypeInternal _OccupancyGrid_MapMetaInfo_default_instance_
GZ_MSGS_VISIBLE OdometryDefaultTypeInternal _Odometry_default_instance_
GZ_MSGS_VISIBLE OdometryWithCovarianceDefaultTypeInternal _OdometryWithCovariance_default_instance_
GZ_MSGS_VISIBLE Oriented3DBoxDefaultTypeInternal _Oriented3DBox_default_instance_
GZ_MSGS_VISIBLE PacketDefaultTypeInternal _Packet_default_instance_
GZ_MSGS_VISIBLE ParamDefaultTypeInternal _Param_default_instance_
GZ_MSGS_VISIBLE Param_ParamsEntry_DoNotUseDefaultTypeInternal _Param_ParamsEntry_DoNotUse_default_instance_
GZ_MSGS_VISIBLE Param_VDefaultTypeInternal _Param_V_default_instance_
GZ_MSGS_VISIBLE ParameterDefaultTypeInternal _Parameter_default_instance_
GZ_MSGS_VISIBLE ParameterDeclarationDefaultTypeInternal _ParameterDeclaration_default_instance_
GZ_MSGS_VISIBLE ParameterDeclarationsDefaultTypeInternal _ParameterDeclarations_default_instance_
GZ_MSGS_VISIBLE ParameterErrorDefaultTypeInternal _ParameterError_default_instance_
GZ_MSGS_VISIBLE ParameterNameDefaultTypeInternal _ParameterName_default_instance_
GZ_MSGS_VISIBLE ParameterValueDefaultTypeInternal _ParameterValue_default_instance_
GZ_MSGS_VISIBLE ParticleEmitterDefaultTypeInternal _ParticleEmitter_default_instance_
GZ_MSGS_VISIBLE ParticleEmitter_VDefaultTypeInternal _ParticleEmitter_V_default_instance_
GZ_MSGS_VISIBLE PerformanceSensorMetricsDefaultTypeInternal _PerformanceSensorMetrics_default_instance_
GZ_MSGS_VISIBLE PhysicsDefaultTypeInternal _Physics_default_instance_
GZ_MSGS_VISIBLE PIDDefaultTypeInternal _PID_default_instance_
GZ_MSGS_VISIBLE PlaneGeomDefaultTypeInternal _PlaneGeom_default_instance_
GZ_MSGS_VISIBLE PluginDefaultTypeInternal _Plugin_default_instance_
GZ_MSGS_VISIBLE Plugin_VDefaultTypeInternal _Plugin_V_default_instance_
GZ_MSGS_VISIBLE PointCloudDefaultTypeInternal _PointCloud_default_instance_
GZ_MSGS_VISIBLE PointCloudPackedDefaultTypeInternal _PointCloudPacked_default_instance_
GZ_MSGS_VISIBLE PointCloudPacked_FieldDefaultTypeInternal _PointCloudPacked_Field_default_instance_
GZ_MSGS_VISIBLE PolylineDefaultTypeInternal _Polyline_default_instance_
GZ_MSGS_VISIBLE PoseDefaultTypeInternal _Pose_default_instance_
GZ_MSGS_VISIBLE Pose_VDefaultTypeInternal _Pose_V_default_instance_
GZ_MSGS_VISIBLE PoseAnimationDefaultTypeInternal _PoseAnimation_default_instance_
GZ_MSGS_VISIBLE PoseTrajectoryDefaultTypeInternal _PoseTrajectory_default_instance_
GZ_MSGS_VISIBLE PoseWithCovarianceDefaultTypeInternal _PoseWithCovariance_default_instance_
GZ_MSGS_VISIBLE ProjectorDefaultTypeInternal _Projector_default_instance_
GZ_MSGS_VISIBLE PropagationGridDefaultTypeInternal _PropagationGrid_default_instance_
GZ_MSGS_VISIBLE PropagationParticleDefaultTypeInternal _PropagationParticle_default_instance_
GZ_MSGS_VISIBLE PublishDefaultTypeInternal _Publish_default_instance_
GZ_MSGS_VISIBLE PublishersDefaultTypeInternal _Publishers_default_instance_
GZ_MSGS_VISIBLE QuaternionDefaultTypeInternal _Quaternion_default_instance_
GZ_MSGS_VISIBLE RaySensorDefaultTypeInternal _RaySensor_default_instance_
GZ_MSGS_VISIBLE RequestDefaultTypeInternal _Request_default_instance_
GZ_MSGS_VISIBLE ResponseDefaultTypeInternal _Response_default_instance_
GZ_MSGS_VISIBLE RestLoginDefaultTypeInternal _RestLogin_default_instance_
GZ_MSGS_VISIBLE RestLogoutDefaultTypeInternal _RestLogout_default_instance_
GZ_MSGS_VISIBLE RestPostDefaultTypeInternal _RestPost_default_instance_
GZ_MSGS_VISIBLE RestResponseDefaultTypeInternal _RestResponse_default_instance_
GZ_MSGS_VISIBLE RoadDefaultTypeInternal _Road_default_instance_
GZ_MSGS_VISIBLE SceneDefaultTypeInternal _Scene_default_instance_
GZ_MSGS_VISIBLE SdfGeneratorConfigDefaultTypeInternal _SdfGeneratorConfig_default_instance_
GZ_MSGS_VISIBLE SdfGeneratorConfig_EntityGeneratorConfigDefaultTypeInternal _SdfGeneratorConfig_EntityGeneratorConfig_default_instance_
GZ_MSGS_VISIBLE SdfGeneratorConfig_OverrideEntityGenConfigsEntry_DoNotUseDefaultTypeInternal _SdfGeneratorConfig_OverrideEntityGenConfigsEntry_DoNotUse_default_instance_
GZ_MSGS_VISIBLE SelectionDefaultTypeInternal _Selection_default_instance_
GZ_MSGS_VISIBLE SensorDefaultTypeInternal _Sensor_default_instance_
GZ_MSGS_VISIBLE Sensor_VDefaultTypeInternal _Sensor_V_default_instance_
GZ_MSGS_VISIBLE SensorNoiseDefaultTypeInternal _SensorNoise_default_instance_
GZ_MSGS_VISIBLE SerializedComponentDefaultTypeInternal _SerializedComponent_default_instance_
GZ_MSGS_VISIBLE SerializedEntityDefaultTypeInternal _SerializedEntity_default_instance_
GZ_MSGS_VISIBLE SerializedEntityMap_ComponentsEntry_DoNotUseDefaultTypeInternal _SerializedEntityMap_ComponentsEntry_DoNotUse_default_instance_
GZ_MSGS_VISIBLE SerializedEntityMapDefaultTypeInternal _SerializedEntityMap_default_instance_
GZ_MSGS_VISIBLE SerializedStateDefaultTypeInternal _SerializedState_default_instance_
GZ_MSGS_VISIBLE SerializedStateMapDefaultTypeInternal _SerializedStateMap_default_instance_
GZ_MSGS_VISIBLE SerializedStateMap_EntitiesEntry_DoNotUseDefaultTypeInternal _SerializedStateMap_EntitiesEntry_DoNotUse_default_instance_
GZ_MSGS_VISIBLE SerializedStepDefaultTypeInternal _SerializedStep_default_instance_
GZ_MSGS_VISIBLE SerializedStepMapDefaultTypeInternal _SerializedStepMap_default_instance_
GZ_MSGS_VISIBLE ServerControlDefaultTypeInternal _ServerControl_default_instance_
GZ_MSGS_VISIBLE ShadowsDefaultTypeInternal _Shadows_default_instance_
GZ_MSGS_VISIBLE SimEventDefaultTypeInternal _SimEvent_default_instance_
GZ_MSGS_VISIBLE SkyDefaultTypeInternal _Sky_default_instance_
GZ_MSGS_VISIBLE SonarDefaultTypeInternal _Sonar_default_instance_
GZ_MSGS_VISIBLE SphereGeomDefaultTypeInternal _SphereGeom_default_instance_
GZ_MSGS_VISIBLE SphericalCoordinatesDefaultTypeInternal _SphericalCoordinates_default_instance_
GZ_MSGS_VISIBLE StatisticDefaultTypeInternal _Statistic_default_instance_
GZ_MSGS_VISIBLE StatisticsGroupDefaultTypeInternal _StatisticsGroup_default_instance_
GZ_MSGS_VISIBLE StringMsgDefaultTypeInternal _StringMsg_default_instance_
GZ_MSGS_VISIBLE StringMsg_VDefaultTypeInternal _StringMsg_V_default_instance_
GZ_MSGS_VISIBLE SubscribeDefaultTypeInternal _Subscribe_default_instance_
GZ_MSGS_VISIBLE SurfaceDefaultTypeInternal _Surface_default_instance_
GZ_MSGS_VISIBLE TactileDefaultTypeInternal _Tactile_default_instance_
GZ_MSGS_VISIBLE TestDefaultTypeInternal _Test_default_instance_
GZ_MSGS_VISIBLE TimeDefaultTypeInternal _Time_default_instance_
GZ_MSGS_VISIBLE TopicInfoDefaultTypeInternal _TopicInfo_default_instance_
GZ_MSGS_VISIBLE TrackVisualDefaultTypeInternal _TrackVisual_default_instance_
GZ_MSGS_VISIBLE TwistDefaultTypeInternal _Twist_default_instance_
GZ_MSGS_VISIBLE TwistWithCovarianceDefaultTypeInternal _TwistWithCovariance_default_instance_
GZ_MSGS_VISIBLE UInt32DefaultTypeInternal _UInt32_default_instance_
GZ_MSGS_VISIBLE UInt32_VDefaultTypeInternal _UInt32_V_default_instance_
GZ_MSGS_VISIBLE UInt64DefaultTypeInternal _UInt64_default_instance_
GZ_MSGS_VISIBLE UInt64_VDefaultTypeInternal _UInt64_V_default_instance_
GZ_MSGS_VISIBLE UndoRedoDefaultTypeInternal _UndoRedo_default_instance_
GZ_MSGS_VISIBLE UserCmdDefaultTypeInternal _UserCmd_default_instance_
GZ_MSGS_VISIBLE UserCmdStatsDefaultTypeInternal _UserCmdStats_default_instance_
GZ_MSGS_VISIBLE Vector2dDefaultTypeInternal _Vector2d_default_instance_
GZ_MSGS_VISIBLE Vector3dDefaultTypeInternal _Vector3d_default_instance_
GZ_MSGS_VISIBLE VersionDefaultTypeInternal _Version_default_instance_
GZ_MSGS_VISIBLE VersionedNameDefaultTypeInternal _VersionedName_default_instance_
GZ_MSGS_VISIBLE VersionRangeDefaultTypeInternal _VersionRange_default_instance_
GZ_MSGS_VISIBLE VideoRecordDefaultTypeInternal _VideoRecord_default_instance_
GZ_MSGS_VISIBLE VisualDefaultTypeInternal _Visual_default_instance_
GZ_MSGS_VISIBLE Visual_MetaDefaultTypeInternal _Visual_Meta_default_instance_
GZ_MSGS_VISIBLE Visual_VDefaultTypeInternal _Visual_V_default_instance_
GZ_MSGS_VISIBLE WebRequestDefaultTypeInternal _WebRequest_default_instance_
GZ_MSGS_VISIBLE WheelSlipParametersCmdDefaultTypeInternal _WheelSlipParametersCmd_default_instance_
GZ_MSGS_VISIBLE WindDefaultTypeInternal _Wind_default_instance_
GZ_MSGS_VISIBLE WirelessNodeDefaultTypeInternal _WirelessNode_default_instance_
GZ_MSGS_VISIBLE WirelessNodesDefaultTypeInternal _WirelessNodes_default_instance_
GZ_MSGS_VISIBLE WorldControlDefaultTypeInternal _WorldControl_default_instance_
GZ_MSGS_VISIBLE WorldControlStateDefaultTypeInternal _WorldControlState_default_instance_
GZ_MSGS_VISIBLE WorldModifyDefaultTypeInternal _WorldModify_default_instance_
GZ_MSGS_VISIBLE WorldResetDefaultTypeInternal _WorldReset_default_instance_
GZ_MSGS_VISIBLE WorldStatisticsDefaultTypeInternal _WorldStatistics_default_instance_
GZ_MSGS_VISIBLE WrenchDefaultTypeInternal _Wrench_default_instance_
 Any_ValueType_Any_ValueType_INT_MAX_SENTINEL_DO_NOT_USE_
 Any_ValueType_Any_ValueType_INT_MIN_SENTINEL_DO_NOT_USE_
 Any_ValueType_BOOLEAN
 Any_ValueType_COLOR
 Any_ValueType_DOUBLE
 Any_ValueType_INT32
 Any_ValueType_NONE
 Any_ValueType_POSE3D
 Any_ValueType_QUATERNIOND
 Any_ValueType_STRING
 Any_ValueType_TIME
const int Any_ValueType_ValueType_ARRAYSIZE
const Any_ValueType Any_ValueType_ValueType_MAX
const Any_ValueType Any_ValueType_ValueType_MIN
 Any_ValueType_VECTOR3D
 Atmosphere_Type_ADIABATIC
 Atmosphere_Type_Atmosphere_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Atmosphere_Type_Atmosphere_Type_INT_MIN_SENTINEL_DO_NOT_USE_
const int Atmosphere_Type_Type_ARRAYSIZE
const Atmosphere_Type Atmosphere_Type_Type_MAX
const Atmosphere_Type Atmosphere_Type_Type_MIN
 BatteryState_PowerSupplyStatus_BatteryState_PowerSupplyStatus_INT_MAX_SENTINEL_DO_NOT_USE_
 BatteryState_PowerSupplyStatus_BatteryState_PowerSupplyStatus_INT_MIN_SENTINEL_DO_NOT_USE_
 BatteryState_PowerSupplyStatus_CHARGING
 BatteryState_PowerSupplyStatus_DISCHARGING
 BatteryState_PowerSupplyStatus_FULL
 BatteryState_PowerSupplyStatus_NOT_CHARGING
const int BatteryState_PowerSupplyStatus_PowerSupplyStatus_ARRAYSIZE
const BatteryState_PowerSupplyStatus BatteryState_PowerSupplyStatus_PowerSupplyStatus_MAX
const BatteryState_PowerSupplyStatus BatteryState_PowerSupplyStatus_PowerSupplyStatus_MIN
 BatteryState_PowerSupplyStatus_UNKNOWN
 BAYER_BGGR8
 BAYER_GBRG8
 BAYER_GRBG8
 BAYER_RGGB8
 BGR_INT16
 BGR_INT32
 BGR_INT8
 BGRA_INT8
 CameraInfo_Distortion_DistortionModelType_CameraInfo_Distortion_DistortionModelType_INT_MAX_SENTINEL_DO_NOT_USE_
 CameraInfo_Distortion_DistortionModelType_CameraInfo_Distortion_DistortionModelType_INT_MIN_SENTINEL_DO_NOT_USE_
const int CameraInfo_Distortion_DistortionModelType_DistortionModelType_ARRAYSIZE
const CameraInfo_Distortion_DistortionModelType CameraInfo_Distortion_DistortionModelType_DistortionModelType_MAX
const CameraInfo_Distortion_DistortionModelType CameraInfo_Distortion_DistortionModelType_DistortionModelType_MIN
 CameraInfo_Distortion_DistortionModelType_EQUIDISTANT
 CameraInfo_Distortion_DistortionModelType_PLUMB_BOB
 CameraInfo_Distortion_DistortionModelType_RATIONAL_POLYNOMIAL
const int CameraSensor_BoundingBoxType_BoundingBoxType_ARRAYSIZE
const CameraSensor_BoundingBoxType CameraSensor_BoundingBoxType_BoundingBoxType_MAX
const CameraSensor_BoundingBoxType CameraSensor_BoundingBoxType_BoundingBoxType_MIN
 CameraSensor_BoundingBoxType_BOX_3D
 CameraSensor_BoundingBoxType_CameraSensor_BoundingBoxType_INT_MAX_SENTINEL_DO_NOT_USE_
 CameraSensor_BoundingBoxType_CameraSensor_BoundingBoxType_INT_MIN_SENTINEL_DO_NOT_USE_
 CameraSensor_BoundingBoxType_FULL_BOX_2D
 CameraSensor_BoundingBoxType_NO_BOUNDING_BOX
 CameraSensor_BoundingBoxType_VISIBLE_BOX_2D
 CameraSensor_SegmentationType_CameraSensor_SegmentationType_INT_MAX_SENTINEL_DO_NOT_USE_
 CameraSensor_SegmentationType_CameraSensor_SegmentationType_INT_MIN_SENTINEL_DO_NOT_USE_
 CameraSensor_SegmentationType_NO_SEGMENTATION
 CameraSensor_SegmentationType_PANOPTIC
const int CameraSensor_SegmentationType_SegmentationType_ARRAYSIZE
const CameraSensor_SegmentationType CameraSensor_SegmentationType_SegmentationType_MAX
const CameraSensor_SegmentationType CameraSensor_SegmentationType_SegmentationType_MIN
 CameraSensor_SegmentationType_SEMANTIC
const int DataLoadPathOptions_DataAngularUnits_DataAngularUnits_ARRAYSIZE
const DataLoadPathOptions_DataAngularUnits DataLoadPathOptions_DataAngularUnits_DataAngularUnits_MAX
const DataLoadPathOptions_DataAngularUnits DataLoadPathOptions_DataAngularUnits_DataAngularUnits_MIN
 DataLoadPathOptions_DataAngularUnits_DataLoadPathOptions_DataAngularUnits_INT_MAX_SENTINEL_DO_NOT_USE_
 DataLoadPathOptions_DataAngularUnits_DataLoadPathOptions_DataAngularUnits_INT_MIN_SENTINEL_DO_NOT_USE_
 DataLoadPathOptions_DataAngularUnits_DEGREES
 DataLoadPathOptions_DataAngularUnits_RADIANS
 Discovery_Publisher_Scope_ALL
 Discovery_Publisher_Scope_Discovery_Publisher_Scope_INT_MAX_SENTINEL_DO_NOT_USE_
 Discovery_Publisher_Scope_Discovery_Publisher_Scope_INT_MIN_SENTINEL_DO_NOT_USE_
 Discovery_Publisher_Scope_HOST
 Discovery_Publisher_Scope_PROCESS
const int Discovery_Publisher_Scope_Scope_ARRAYSIZE
const Discovery_Publisher_Scope Discovery_Publisher_Scope_Scope_MAX
const Discovery_Publisher_Scope Discovery_Publisher_Scope_Scope_MIN
 Discovery_Type_ADVERTISE
 Discovery_Type_BYE
 Discovery_Type_Discovery_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Discovery_Type_Discovery_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 Discovery_Type_END_CONNECTION
 Discovery_Type_HEARTBEAT
 Discovery_Type_NEW_CONNECTION
 Discovery_Type_SUBSCRIBE
const int Discovery_Type_Type_ARRAYSIZE
const Discovery_Type Discovery_Type_Type_MAX
const Discovery_Type Discovery_Type_Type_MIN
 Discovery_Type_UNADVERTISE
 Discovery_Type_UNINITIALIZED
 DVLKinematicEstimate_ReferenceType_DVL_REFERENCE_EARTH
 DVLKinematicEstimate_ReferenceType_DVL_REFERENCE_SHIP
 DVLKinematicEstimate_ReferenceType_DVL_REFERENCE_UNSPECIFIED
 DVLKinematicEstimate_ReferenceType_DVLKinematicEstimate_ReferenceType_INT_MAX_SENTINEL_DO_NOT_USE_
 DVLKinematicEstimate_ReferenceType_DVLKinematicEstimate_ReferenceType_INT_MIN_SENTINEL_DO_NOT_USE_
const int DVLKinematicEstimate_ReferenceType_ReferenceType_ARRAYSIZE
const DVLKinematicEstimate_ReferenceType DVLKinematicEstimate_ReferenceType_ReferenceType_MAX
const DVLKinematicEstimate_ReferenceType DVLKinematicEstimate_ReferenceType_ReferenceType_MIN
 DVLTrackingTarget_TargetType_DVL_TARGET_BOTTOM
 DVLTrackingTarget_TargetType_DVL_TARGET_UNSPECIFIED
 DVLTrackingTarget_TargetType_DVL_TARGET_WATER_MASS
 DVLTrackingTarget_TargetType_DVLTrackingTarget_TargetType_INT_MAX_SENTINEL_DO_NOT_USE_
 DVLTrackingTarget_TargetType_DVLTrackingTarget_TargetType_INT_MIN_SENTINEL_DO_NOT_USE_
const int DVLTrackingTarget_TargetType_TargetType_ARRAYSIZE
const DVLTrackingTarget_TargetType DVLTrackingTarget_TargetType_TargetType_MAX
const DVLTrackingTarget_TargetType DVLTrackingTarget_TargetType_TargetType_MIN
 DVLVelocityTracking_DVLType_DVL_TYPE_PHASED_ARRAY
 DVLVelocityTracking_DVLType_DVL_TYPE_PISTON
 DVLVelocityTracking_DVLType_DVL_TYPE_UNSPECIFIED
const int DVLVelocityTracking_DVLType_DVLType_ARRAYSIZE
const DVLVelocityTracking_DVLType DVLVelocityTracking_DVLType_DVLType_MAX
const DVLVelocityTracking_DVLType DVLVelocityTracking_DVLType_DVLType_MIN
 DVLVelocityTracking_DVLType_DVLVelocityTracking_DVLType_INT_MAX_SENTINEL_DO_NOT_USE_
 DVLVelocityTracking_DVLType_DVLVelocityTracking_DVLType_INT_MIN_SENTINEL_DO_NOT_USE_
 ECEF
 Entity_Type_ACTOR
 Entity_Type_COLLISION
 Entity_Type_Entity_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Entity_Type_Entity_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 Entity_Type_JOINT
 Entity_Type_LIGHT
 Entity_Type_LINK
 Entity_Type_MODEL
 Entity_Type_NONE
 Entity_Type_SENSOR
const int Entity_Type_Type_ARRAYSIZE
const Entity_Type Entity_Type_Type_MAX
const Entity_Type Entity_Type_Type_MIN
 Entity_Type_VISUAL
 Entity_Type_WORLD
 Fog_FogType_EXPONENTIAL
 Fog_FogType_EXPONENTIAL2
 Fog_FogType_Fog_FogType_INT_MAX_SENTINEL_DO_NOT_USE_
 Fog_FogType_Fog_FogType_INT_MIN_SENTINEL_DO_NOT_USE_
const int Fog_FogType_FogType_ARRAYSIZE
const Fog_FogType Fog_FogType_FogType_MAX
const Fog_FogType Fog_FogType_FogType_MIN
 Fog_FogType_LINEAR
 Fog_FogType_NONE
 FSWO_LOG_WARNINGS
 FSWO_SUPPRESS_WARNINGS
 Geometry_Type_ARROW
 Geometry_Type_AXIS
 Geometry_Type_BOX
 Geometry_Type_CAPSULE
 Geometry_Type_CONE
 Geometry_Type_CYLINDER
 Geometry_Type_ELLIPSOID
 Geometry_Type_EMPTY
 Geometry_Type_Geometry_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Geometry_Type_Geometry_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 Geometry_Type_HEIGHTMAP
 Geometry_Type_IMAGE
 Geometry_Type_LINE_STRIP
 Geometry_Type_MESH
 Geometry_Type_PLANE
 Geometry_Type_POLYLINE
 Geometry_Type_SPHERE
 Geometry_Type_TRIANGLE_FAN
const int Geometry_Type_Type_ARRAYSIZE
const Geometry_Type Geometry_Type_Type_MAX
const Geometry_Type Geometry_Type_Type_MIN
 GLOBAL
 Joint_Type_BALL
 Joint_Type_CONTINUOUS
 Joint_Type_FIXED
 Joint_Type_GEARBOX
 Joint_Type_Joint_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Joint_Type_Joint_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 Joint_Type_PRISMATIC
 Joint_Type_REVOLUTE
 Joint_Type_REVOLUTE2
 Joint_Type_SCREW
const int Joint_Type_Type_ARRAYSIZE
const Joint_Type Joint_Type_Type_MAX
const Joint_Type Joint_Type_Type_MIN
 Joint_Type_UNIVERSAL
 L_INT16
 L_INT8
 Lens_FunctionType_FUNCTION_NOT_SPECIFIED
const int Lens_FunctionType_FunctionType_ARRAYSIZE
const Lens_FunctionType Lens_FunctionType_FunctionType_MAX
const Lens_FunctionType Lens_FunctionType_FunctionType_MIN
 Lens_FunctionType_ID
 Lens_FunctionType_Lens_FunctionType_INT_MAX_SENTINEL_DO_NOT_USE_
 Lens_FunctionType_Lens_FunctionType_INT_MIN_SENTINEL_DO_NOT_USE_
 Lens_FunctionType_SIN
 Lens_FunctionType_TAN
 Lens_Type_CUSTOM
 Lens_Type_EQUIDISTANT
 Lens_Type_EQUISOLID_ANGLE
 Lens_Type_GNOMONICAL
 Lens_Type_Lens_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Lens_Type_Lens_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 Lens_Type_ORTHOGRAPHIC
 Lens_Type_STEREOGRAPHIC
const int Lens_Type_Type_ARRAYSIZE
const Lens_Type Lens_Type_Type_MAX
const Lens_Type Lens_Type_Type_MIN
 Lens_Type_TYPE_NOT_SPECIFIED
 Light_LightType_DIRECTIONAL
 Light_LightType_Light_LightType_INT_MAX_SENTINEL_DO_NOT_USE_
 Light_LightType_Light_LightType_INT_MIN_SENTINEL_DO_NOT_USE_
const int Light_LightType_LightType_ARRAYSIZE
const Light_LightType Light_LightType_LightType_MAX
const Light_LightType Light_LightType_LightType_MIN
 Light_LightType_POINT
 Light_LightType_SPOT
 LOCAL
 LOCAL2
 LogStatus_LogFile_Units_BYTES
 LogStatus_LogFile_Units_G_BYTES
 LogStatus_LogFile_Units_K_BYTES
 LogStatus_LogFile_Units_LogStatus_LogFile_Units_INT_MAX_SENTINEL_DO_NOT_USE_
 LogStatus_LogFile_Units_LogStatus_LogFile_Units_INT_MIN_SENTINEL_DO_NOT_USE_
 LogStatus_LogFile_Units_M_BYTES
const int LogStatus_LogFile_Units_Units_ARRAYSIZE
const LogStatus_LogFile_Units LogStatus_LogFile_Units_Units_MAX
const LogStatus_LogFile_Units LogStatus_LogFile_Units_Units_MIN
const int Marker_Action_Action_ARRAYSIZE
const Marker_Action Marker_Action_Action_MAX
const Marker_Action Marker_Action_Action_MIN
 Marker_Action_ADD_MODIFY
 Marker_Action_DELETE_ALL
 Marker_Action_DELETE_MARKER
 Marker_Action_Marker_Action_INT_MAX_SENTINEL_DO_NOT_USE_
 Marker_Action_Marker_Action_INT_MIN_SENTINEL_DO_NOT_USE_
 Marker_Type_ARROW
 Marker_Type_AXIS
 Marker_Type_BOX
 Marker_Type_CAPSULE
 Marker_Type_CONE
 Marker_Type_CYLINDER
 Marker_Type_ELLIPSOID
 Marker_Type_LINE_LIST
 Marker_Type_LINE_STRIP
 Marker_Type_Marker_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Marker_Type_Marker_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 Marker_Type_NONE
 Marker_Type_POINTS
 Marker_Type_SPHERE
 Marker_Type_TEXT
 Marker_Type_TRIANGLE_FAN
 Marker_Type_TRIANGLE_LIST
 Marker_Type_TRIANGLE_STRIP
const int Marker_Type_Type_ARRAYSIZE
const Marker_Type Marker_Type_Type_MAX
const Marker_Type Marker_Type_Type_MIN
 Marker_Visibility_ALL
 Marker_Visibility_GUI
 Marker_Visibility_Marker_Visibility_INT_MAX_SENTINEL_DO_NOT_USE_
 Marker_Visibility_Marker_Visibility_INT_MIN_SENTINEL_DO_NOT_USE_
const int Marker_Visibility_Visibility_ARRAYSIZE
const Marker_Visibility Marker_Visibility_Visibility_MAX
const Marker_Visibility Marker_Visibility_Visibility_MIN
 Material_PBR_WorkflowType_Material_PBR_WorkflowType_INT_MAX_SENTINEL_DO_NOT_USE_
 Material_PBR_WorkflowType_Material_PBR_WorkflowType_INT_MIN_SENTINEL_DO_NOT_USE_
 Material_PBR_WorkflowType_METAL
 Material_PBR_WorkflowType_NONE
 Material_PBR_WorkflowType_SPECULAR
const int Material_PBR_WorkflowType_WorkflowType_ARRAYSIZE
const Material_PBR_WorkflowType Material_PBR_WorkflowType_WorkflowType_MAX
const Material_PBR_WorkflowType Material_PBR_WorkflowType_WorkflowType_MIN
 Material_ShaderType_Material_ShaderType_INT_MAX_SENTINEL_DO_NOT_USE_
 Material_ShaderType_Material_ShaderType_INT_MIN_SENTINEL_DO_NOT_USE_
 Material_ShaderType_NORMAL_MAP_OBJECT_SPACE
 Material_ShaderType_NORMAL_MAP_TANGENT_SPACE
 Material_ShaderType_PIXEL
const int Material_ShaderType_ShaderType_ARRAYSIZE
const Material_ShaderType Material_ShaderType_ShaderType_MAX
const Material_ShaderType Material_ShaderType_ShaderType_MIN
 Material_ShaderType_VERTEX
 ParameterError_Type_ALREADY_DECLARED
 ParameterError_Type_INVALID_TYPE
 ParameterError_Type_NOT_DECLARED
 ParameterError_Type_ParameterError_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 ParameterError_Type_ParameterError_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 ParameterError_Type_SUCCESS
const int ParameterError_Type_Type_ARRAYSIZE
const ParameterError_Type ParameterError_Type_Type_MAX
const ParameterError_Type ParameterError_Type_Type_MIN
 ParticleEmitter_EmitterType_BOX
 ParticleEmitter_EmitterType_CYLINDER
 ParticleEmitter_EmitterType_ELLIPSOID
const int ParticleEmitter_EmitterType_EmitterType_ARRAYSIZE
const ParticleEmitter_EmitterType ParticleEmitter_EmitterType_EmitterType_MAX
const ParticleEmitter_EmitterType ParticleEmitter_EmitterType_EmitterType_MIN
 ParticleEmitter_EmitterType_ParticleEmitter_EmitterType_INT_MAX_SENTINEL_DO_NOT_USE_
 ParticleEmitter_EmitterType_ParticleEmitter_EmitterType_INT_MIN_SENTINEL_DO_NOT_USE_
 ParticleEmitter_EmitterType_POINT
 Physics_Type_BULLET
 Physics_Type_DART
 Physics_Type_ODE
 Physics_Type_Physics_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Physics_Type_Physics_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 Physics_Type_SIMBODY
const int Physics_Type_Type_ARRAYSIZE
const Physics_Type Physics_Type_Type_MAX
const Physics_Type Physics_Type_Type_MIN
const int PixelFormatType_ARRAYSIZE
 PixelFormatType_INT_MAX_SENTINEL_DO_NOT_USE_
 PixelFormatType_INT_MIN_SENTINEL_DO_NOT_USE_
const PixelFormatType PixelFormatType_MAX
const PixelFormatType PixelFormatType_MIN
const int PointCloudPacked_Field_DataType_DataType_ARRAYSIZE
const PointCloudPacked_Field_DataType PointCloudPacked_Field_DataType_DataType_MAX
const PointCloudPacked_Field_DataType PointCloudPacked_Field_DataType_DataType_MIN
 PointCloudPacked_Field_DataType_FLOAT32
 PointCloudPacked_Field_DataType_FLOAT64
 PointCloudPacked_Field_DataType_INT16
 PointCloudPacked_Field_DataType_INT32
 PointCloudPacked_Field_DataType_INT8
 PointCloudPacked_Field_DataType_PointCloudPacked_Field_DataType_INT_MAX_SENTINEL_DO_NOT_USE_
 PointCloudPacked_Field_DataType_PointCloudPacked_Field_DataType_INT_MIN_SENTINEL_DO_NOT_USE_
 PointCloudPacked_Field_DataType_UINT16
 PointCloudPacked_Field_DataType_UINT32
 PointCloudPacked_Field_DataType_UINT8
 R_FLOAT16
 R_FLOAT32
 RestResponse_Type_ERR
 RestResponse_Type_LOGIN
 RestResponse_Type_LOGOUT
 RestResponse_Type_RestResponse_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 RestResponse_Type_RestResponse_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 RestResponse_Type_SUCCESS
const int RestResponse_Type_Type_ARRAYSIZE
const RestResponse_Type RestResponse_Type_Type_MAX
const RestResponse_Type RestResponse_Type_Type_MIN
 RGB_FLOAT16
 RGB_FLOAT32
 RGB_INT16
 RGB_INT32
 RGB_INT8
 RGBA_INT8
 SensorNoise_Type_GAUSSIAN
 SensorNoise_Type_GAUSSIAN_QUANTIZED
 SensorNoise_Type_NONE
 SensorNoise_Type_SensorNoise_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 SensorNoise_Type_SensorNoise_Type_INT_MIN_SENTINEL_DO_NOT_USE_
const int SensorNoise_Type_Type_ARRAYSIZE
const SensorNoise_Type SensorNoise_Type_Type_MAX
const SensorNoise_Type SensorNoise_Type_Type_MIN
 Shadows_ShadowType_Shadows_ShadowType_INT_MAX_SENTINEL_DO_NOT_USE_
 Shadows_ShadowType_Shadows_ShadowType_INT_MIN_SENTINEL_DO_NOT_USE_
const int Shadows_ShadowType_ShadowType_ARRAYSIZE
const Shadows_ShadowType Shadows_ShadowType_ShadowType_MAX
const Shadows_ShadowType Shadows_ShadowType_ShadowType_MIN
 Shadows_ShadowType_STENCIL_ADDITIVE
 Shadows_ShadowType_STENCIL_MODULATIVE
 Shadows_ShadowType_TEXTURE_ADDITIVE
 Shadows_ShadowType_TEXTURE_MODULATIVE
 SPHERICAL
 SphericalCoordinates_SurfaceModel_CUSTOM_SURFACE
 SphericalCoordinates_SurfaceModel_EARTH_WGS84
 SphericalCoordinates_SurfaceModel_MOON_SCS
 SphericalCoordinates_SurfaceModel_SphericalCoordinates_SurfaceModel_INT_MAX_SENTINEL_DO_NOT_USE_
 SphericalCoordinates_SurfaceModel_SphericalCoordinates_SurfaceModel_INT_MIN_SENTINEL_DO_NOT_USE_
const int SphericalCoordinates_SurfaceModel_SurfaceModel_ARRAYSIZE
const SphericalCoordinates_SurfaceModel SphericalCoordinates_SurfaceModel_SurfaceModel_MAX
const SphericalCoordinates_SurfaceModel SphericalCoordinates_SurfaceModel_SurfaceModel_MIN
const int SphericalCoordinatesType_ARRAYSIZE
 SphericalCoordinatesType_INT_MAX_SENTINEL_DO_NOT_USE_
 SphericalCoordinatesType_INT_MIN_SENTINEL_DO_NOT_USE_
const SphericalCoordinatesType SphericalCoordinatesType_MAX
const SphericalCoordinatesType SphericalCoordinatesType_MIN
 Statistic_DataType_AVERAGE
const int Statistic_DataType_DataType_ARRAYSIZE
const Statistic_DataType Statistic_DataType_DataType_MAX
const Statistic_DataType Statistic_DataType_DataType_MIN
 Statistic_DataType_MAX_ABS_VALUE
 Statistic_DataType_MAXIMUM
 Statistic_DataType_MINIMUM
 Statistic_DataType_ROOT_MEAN_SQUARE
 Statistic_DataType_SAMPLE_COUNT
 Statistic_DataType_Statistic_DataType_INT_MAX_SENTINEL_DO_NOT_USE_
 Statistic_DataType_Statistic_DataType_INT_MIN_SENTINEL_DO_NOT_USE_
 Statistic_DataType_STDDEV
 Statistic_DataType_UNINITIALIZED
 Statistic_DataType_VARIANCE
 UNKNOWN_PIXEL_FORMAT
 UserCmd_Type_MOVING
 UserCmd_Type_SCALING
const int UserCmd_Type_Type_ARRAYSIZE
const UserCmd_Type UserCmd_Type_Type_MAX
const UserCmd_Type UserCmd_Type_Type_MIN
 UserCmd_Type_UserCmd_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 UserCmd_Type_UserCmd_Type_INT_MIN_SENTINEL_DO_NOT_USE_
 UserCmd_Type_WORLD_CONTROL
 UserCmd_Type_WRENCH
 Visual_Type_COLLISION
 Visual_Type_ENTITY
 Visual_Type_GUI
 Visual_Type_LINK
 Visual_Type_MODEL
 Visual_Type_PHYSICS
 Visual_Type_SENSOR
const int Visual_Type_Type_ARRAYSIZE
const Visual_Type Visual_Type_Type_MAX
const Visual_Type Visual_Type_Type_MIN
 Visual_Type_VISUAL
 Visual_Type_Visual_Type_INT_MAX_SENTINEL_DO_NOT_USE_
 Visual_Type_Visual_Type_INT_MIN_SENTINEL_DO_NOT_USE_
