gz/sim/rendering/Events.hh File Reference
#include <gz/common/Event.hh>#include "gz/sim/config.hh"Go to the source code of this file.
Namespaces | |
| gz | |
| gz::sim | |
| gz::sim::events | |
| Namespace for all events. Refer to the EventManager class for more information about events. | |
Typedefs | |
| using | ForceRender = gz::common::EventT< void(void), struct ForceRenderTag > |
| The force render event may be emitted outside the rendering thread to force rendering calls ie. to ensure rendering occurs even if it wasn't seemingly necessary. More... | |
| using | PostRender = gz::common::EventT< void(void), struct PostRenderTag > |
| The post render event is emitted after rendering updates. The event is emitted in the rendering thread so rendering calls can be made in this event callback. More... | |
| using | PreRender = gz::common::EventT< void(void), struct PreRenderTag > |
| The pre render event is emitted before rendering updates. The event is emitted in the rendering thread so rendering calls can be made in this event callback. More... | |
| using | Render = gz::common::EventT< void(void), struct RenderTag > |
| The render event is emitted during rendering updates. The event is emitted in the rendering thread so rendering calls can be made in this event callback. More... | |
| using | RenderTeardown = gz::common::EventT< void(void), struct RenderTeardownTag > |
| The render teardown event is emitted right before the rendering thread is torn down. The event is emitted in the rendering thread so last minute, cleanup rendering calls can be made in this event callback. More... | |
| using | SceneUpdate = gz::common::EventT< void(void), struct SceneUpdateTag > |
| The render event is emitted when the the scene manager is updated with contents from the ECM. This event is emitted before the PreRender event on the server side in the rendering thread. It is also accessible on the GUI side. More... | |
