ComponentInspector.hh File Reference
#include <map>
#include <memory>
#include <string>
#include <sdf/Material.hh>
#include <sdf/Physics.hh>
#include <gz/math/SphericalCoordinates.hh>
#include <gz/math/Vector3.hh>
#include <gz/transport/Node.hh>
#include <gz/sim/gui/GuiSystem.hh>
#include <gz/sim/Types.hh>
#include "Types.hh"
#include <gz/msgs/light.pb.h>
Functions
 Q_DECLARE_METATYPE (ComponentTypeId) namespace gz
Function Documentation
◆ Q_DECLARE_METATYPE()
Q_DECLARE_METATYPE ( ComponentTypeId  )
Generic function to set data.
[in]_itemItem whose data will be set.
[in]_dataData to set.
Specialized to set string data.
Specialized to set light data.
Specialized to set vector data.
Specialized to set Physics data.
Specialized to set Spherical Coordinates data.
Specialized to set boolean data.
Specialized to set integer data.
Specialized to set double data.
Specialized to set stream data.
Specialized to set material data.
Set the unit of a given item.
[in]_itemItem whose unit will be set.
[in]_unitUnit to be displayed, such as 'm' for meters.
Model holding information about components, such as their type and data.
Constructor
Destructor
Static version of roleNames
A hash connecting a unique identifier to a role name.
Add a component type to the inspector.
[in]_typeIdType of component to be added.
Newly created item.
Remove a component type from the inspector.
[in]_typeIdType of component to be removed.
Keep track of items in the tree, according to type ID.
Displays a tree view with all the entities in the world.
Configuration
None
Entity
Type
Locked
Paused
Nested Model
System display name list
Constructor
Destructor
Add a callback that's called whenever there are updates from the ECM to the view, for a given component type.
[in]_idThe component type id
[in]_cbFunction that's called when there are updates.
Callback in Qt thread when specular changes.
[in]_rSpecularspecular red
[in]_gSpecularspecular green
[in]_bSpecularspecular blue
[in]_aSpecularspecular alpha
[in]_rDiffuseDiffuse red
[in]_gDiffuseDiffuse green
[in]_bDiffuseDiffuse blue
[in]_aDiffuseDiffuse alpha
[in]_attRangeRange attenuation
[in]_attLinearLinear attenuation
[in]_attConstantConstant attenuation
[in]_attQuadraticQuadratic attenuation
[in]_castShadowsSpecify if this light should cast shadows
[in]_directionXX direction of the light
[in]_directionYY direction of the light
[in]_directionZZ direction of the light
[in]_innerAngleInner angle of the spotlight
[in]_outerAngleOuter angle of the spotlight
[in]_falloffFalloff of the spotlight
[in]_intensityIntensity of the light
[in]_typelight type
[in]_isLightOnis light on
[in]_visualizeVisualis visual enabled
Callback in Qt thread when physics' properties change.
[in]_stepSizestep size
[in]_realTimeFactorreal time factor
Callback in Qt thread when material color changes for a visual
[in]_rAmbientambient red
[in]_gAmbientambient green
[in]_bAmbientambient blue
[in]_aAmbientambient alpha
[in]_rDiffusediffuse red
[in]_gDiffusediffuse green
[in]_bDiffusediffuse blue
[in]_aDiffusediffuse alpha
[in]_rEmissiveemissive red
[in]_gEmissiveemissive green
[in]_bEmissiveemissive blue
[in]_aEmissiveemissive alpha
[in]_typeif type is not empty, opens QColorDialog. The possible types are ambient, diffuse, specular, or emissive.
[in]_currColorused for QColorDialog to show the current color in the open dialog.
Callback in Qt thread when spherical coordinates change.
[in]_surfaceSurface model
[in]_latitudeLatitude in degrees
[in]_longitudeLongitude in degrees
[in]_elevationElevation in meters
[in]_headingHeading in degrees
Get whether the entity is a nested model or not
True if the entity is a nested model, false otherwise
Notify that is nested model property has changed
Get the entity currently inspected.
Entity ID.
Set the entity currently inspected.
[in]_entityEntity ID.
Get the type of entity currently inspected.
Type, such as 'world' or 'model'
Set the type of entity currently inspected.
[in]_typeType, such as 'world' or 'model'.
Notify that entity type has changed
Get whether the inspector is currently locked on an entity.
True for locked
Set whether the inspector is currently locked on an entity.
[in]_lockedTrue for locked.
Get whether the inspector is currently paused for updates.
True for paused.
Set whether the inspector is currently paused for updates.
[in]_pausedTrue for paused.
Notify that paused has changed.
Name of world entity
World name
Node for communication
Transport node
Query system plugin info.
Get the system plugin display name list
A list of names that are potentially system plugins
Set the system plugin display name list
[in]_systempFilenameListA list of system plugin display names
Notify that system plugin display name list has changed
Callback when a new system is to be added to an entity
[in]_nameName of system
[in]_filenameFilename of system
[in]_innerxmlInner XML content of the system
References std::endl(), gzwarn, stringstream::str(), and IsOutStreamable< Stream, DataType >::value.
