JointForceCmd.hh File Reference
#include <vector>
#include <gz/sim/config.hh>
 gz
 gz::sim
 gz::sim::components
using JointForceCmd = Component< std::vector< double >, class JointForceCmdTag >
 Commanded joint forces (or torques) to be applied to a joint in SI units (Nm for revolute, N for prismatic). The component wraps a std::vector and systems that set this component need to ensure that the vector has the same size as the degrees of freedom of the joint. More...
