Provides buttons for the align tool. More...
#include <AlignTool.hh>
Public Slots
void OnAlign ()
 Callback to the align state the execution queue. More...
void OnAlignAxis (const QString &_mode)
 Callback to update the axis type. More...
void OnAlignConfig (const QString &_mode)
 Callback to update the axis config. More...
void OnAlignTarget (const QString &_target)
 Callback to update the target type. More...
void OnHoveredEntered ()
 Callback to make whenever a hover state is entered on a button. More...
void OnHoveredExited ()
 Callback to make whenever a hover state is exited on a button. More...
void OnReverse (bool _reverse)
 Callback to update if the align orientation is reversed. More...
 AlignTool ()
 ~AlignTool () override
void AddState (const AlignState &_state)
 Callback to add a state to the execution queue. More...
void Align ()
 The function call to execute a state from the queue. This function makes rendering calls and should only be executed within the render thread. More...
rendering::NodePtr TopLevelNode (rendering::ScenePtr &_scene, rendering::NodePtr &_node) const
 Returns the top level node of the passed in node within a given scene. More...
rendering::VisualPtr TopLevelVisual (rendering::ScenePtr &_scene, rendering::VisualPtr &_visual) const
 Returns the top level visual of the passed in visual within a given scene. More...
 Update callback called every time the system is stepped. This is called at a Gazebo Transport thread, so any interaction with Qt should be done through signals and slots. More...
void UpdateTransparency (const rendering::NodePtr &_node, bool _makeTransparent)
 Updates the node to increase its transparency or reset back to its original transparency value, an opaque call requires a previous transparent call, otherwise, no action will be taken. More...
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
void DeleteLater ()
std::string configStr
std::string title
Configuration
<service> : Set the service to receive align tool requests.
◆ AlignTool()
AlignTool ( )
◆ ~AlignTool()
~AlignTool ( )
◆ AddState()
void AddState ( const AlignState &  _state)
[in]_stateNew state to add by enum AlignState
◆ Align()
void Align ( )
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
Reimplemented from Plugin.
◆ OnAlign
void OnAlign ( )
slot
◆ OnAlignAxis
void OnAlignAxis ( const QString &  _mode)
slot
[in]_modeNew axis type
◆ OnAlignConfig
void OnAlignConfig ( const QString &  _mode)
slot
[in]_modeNew config type
◆ OnAlignTarget
void OnAlignTarget ( const QString &  _target)
slot
[in]_targetNew target type
◆ OnHoveredEntered
void OnHoveredEntered ( )
slot
◆ OnHoveredExited
void OnHoveredExited ( )
slot
◆ OnReverse
void OnReverse ( bool  _reverse)
slot
[in]_reverseThe reverse boolean
◆ TopLevelNode()
rendering::NodePtr TopLevelNode ( rendering::ScenePtr &  _scene,
rendering::NodePtr &  _node
) const
[in]_sceneThe scene to check
[in]_nodeThe node to get the top level node for
◆ TopLevelVisual()
rendering::VisualPtr TopLevelVisual ( rendering::ScenePtr &  _scene,
rendering::VisualPtr &  _visual
) const
[in]_visualThe visual to get the top level visual for
Reimplemented from GuiSystem.
◆ UpdateTransparency()
void UpdateTransparency ( const rendering::NodePtr &  _node,
[in]_nodeThe node to update.
[in]_makeTransparenttrue if updating to increase transparency, false to set back to original transparency values (make more opaque)
