AnimationUpdateData Class Reference
Data structure for updating skeleton animations. More...
#include <SceneManager.hh>
Public Attributes
std::string animationName
 Name of animation to play. This field is set only if the actor is not animated by manually using skeleton transforms. More...
bool followTrajectory = false
 True if trajectory animation is on. More...
bool loop = false
 True if animation is looped. More...
math::Matrix4d rootTransform
 Transform of the root node in the skeleton. The actor's skeleton's root node transform needs to be set if trajectory animation is enabled. This field is set only if the actor is not animated by manually using skeleton transforms. More...
std::chrono::steady_clock::duration time
 Timepoint in the animation. Note that animation time is different from sim time. An actor can have multiple animations. Animation time is associated with current animation that is being played. This value is also adjusted if interpolate_x is enabled. More...
common::TrajectoryInfo trajectory
 Trajectory to be followed. More...
bool valid = false
 True if this animation update data is valid. If false, this update data should be ignored. More...
◆ animationName
◆ followTrajectory
◆ loop
bool loop = false
◆ rootTransform
◆ time
◆ trajectory
◆ valid
bool valid = false
