EventManager Class Reference
The EventManager is used to send/receive notifications of simulator events. More...
#include <EventManager.hh>
 EventManager ()=default
 EventManager (const EventManager &)=delete
 ~EventManager ()=default
template<typename E >
gz::common::ConnectionPtr Connect (const typename E::CallbackT &_subscriber)
 Add a connection to an event. More...
unsigned int ConnectionCount ()
 Get connection count for a particular event Connection count for the event. More...
template<typename E , typename ... Args>
void Emit (Args &&... _args)
 Emit an event signal to connected subscribers. More...
EventManager & operator= (const EventManager &)=delete
The simulator environment and corresponding systems can either connect to an Event or emit an Event as needed to signal actions that need to occur.
See events for a complete list of events. TODO: if visibility is added here the MSVC is unable to compile it. The use of smart pointer inside the unordered_map (events method) is the cause of it. Maybe a compiler bug?
◆ EventManager() [1/2]
EventManager ( )
default
◆ EventManager() [2/2]
EventManager ( const EventManager &  )
delete
◆ ~EventManager()
~EventManager ( )
default
◆ Connect()
gz::common::ConnectionPtr Connect ( const typename E::CallbackT &  _subscriber)
inline
[in]_subscriberA std::function callback function. The function signature must match that of the event (template parameter E).
A Connection pointer, which will automatically call Disconnect when it goes out of scope.
◆ ConnectionCount()
unsigned int ConnectionCount ( )
inline
◆ Emit()
void Emit ( Args &&...  _args)
inline
[in]_argsfunction arguments to be passed to the event callbacks. Must match the signature of the event type E.
◆ operator=()
EventManager& operator= ( const EventManager &  )
delete
