This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a joint entity. More...
#include <gz/sim/Joint.hh>
 Joint (sim::Entity _entity=kNullEntity)
std::optional< std::vector< sdf::JointAxis > > Axis (const EntityComponentManager &_ecm) const
 Get the joint axis. More...
std::optional< std::string > ChildLinkName (const EntityComponentManager &_ecm) const
 Get the child link name. More...
std::optional< std::vector< double > > EffortLimits (const EntityComponentManager &_ecm) const
 Get joint effort limits. More...
void EnablePositionCheck (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report positions for a joint, so functions like Position will return nullopt. This function can be used to enable joint position check. More...
void EnableTransmittedWrenchCheck (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report transmitted wrench for a joint, so functions like TransmittedWrench will return nullopt. This function can be used to enable joint transmitted wrench check. More...
void EnableVelocityCheck (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report velocities for a joint, so functions like Velocity will return nullopt. This function can be used to enable joint velocity check. More...
sim::Entity Entity () const
 Get the entity which this Joint is related to. More...
std::optional< std::vector< double > > MaxVelocityLimits (const EntityComponentManager &_ecm) const
 Get joint velocity limits. More...
 Get the joint's unscoped name. More...
std::optional< std::string > ParentLinkName (const EntityComponentManager &_ecm) const
 Get the parent link name. More...
std::optional< Model > ParentModel (const EntityComponentManager &_ecm) const
 Get the parent model. More...
std::optional< math::Pose3d > Pose (const EntityComponentManager &_ecm) const
 Get the pose of the joint. More...
std::optional< std::vector< double > > Position (const EntityComponentManager &_ecm) const
 Get the position of the joint. More...
std::optional< std::vector< math::Vector2d > > PositionLimits (const EntityComponentManager &_ecm) const
 Get joint position limits. More...
 Reset Entity to a new one. More...
void ResetPosition (EntityComponentManager &_ecm, const std::vector< double > &_positions)
 Reset the joint positions. More...
void ResetVelocity (EntityComponentManager &_ecm, const std::vector< double > &_velocities)
 Reset the joint velocities. More...
sim::Entity SensorByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a sensor entity which is an immediate child of this joint. More...
uint64_t SensorCount (const EntityComponentManager &_ecm) const
 Get the number of sensors which are immediate children of this joint. More...
std::vector< sim::Entity > Sensors (const EntityComponentManager &_ecm) const
 Get all sensors which are immediate children of this joint. More...
void SetEffortLimits (EntityComponentManager &_ecm, const std::vector< math::Vector2d > &_limits)
 Set the effort limits on a joint axis. More...
void SetForce (EntityComponentManager &_ecm, const std::vector< double > &_forces)
 Set force on this joint. If both forces and velocities are set, only forces are applied. More...
void SetPositionLimits (EntityComponentManager &_ecm, const std::vector< math::Vector2d > &_limits)
 Set the position limits on a joint axis. More...
void SetVelocity (EntityComponentManager &_ecm, const std::vector< double > &_velocities)
 Set velocity on this joint. Only applied if no forces are set. More...
void SetVelocityLimits (EntityComponentManager &_ecm, const std::vector< math::Vector2d > &_limits)
 Set the velocity limits on a joint axis. More...
std::optional< double > ThreadPitch (const EntityComponentManager &_ecm) const
 Get the thread pitch of the joint. More...
std::optional< std::vector< msgs::Wrench > > TransmittedWrench (const EntityComponentManager &_ecm) const
 Get the transmitted wrench of the joint. More...
std::optional< sdf::JointType > Type (const EntityComponentManager &_ecm) const
 Get the joint type. More...
 Check whether this joint correctly refers to an entity that has a components::Joint. More...
std::optional< std::vector< double > > Velocity (const EntityComponentManager &_ecm) const
 Get the velocity of the joint. More...
For example, given a joint's entity, find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Joint joint(entity); std::string name = joint.Name(ecm);
◆ Joint()
Joint ( sim::Entity  _entity = kNullEntity)
[in]_entityJoint entity
◆ Axis()
std::optional<std::vector<sdf::JointAxis> > Axis ( const EntityComponentManager &  _ecm) const
Get the joint axis.
Axis of the joint or nullopt if the entity does not have a components::JointAxis or components::JointAxis2 component.
◆ ChildLinkName()
std::optional<std::string> ChildLinkName ( const EntityComponentManager &  _ecm) const
Child link name or nullopt if the entity does not have a components::ChildLinkName component.
◆ EffortLimits()
std::optional<std::vector<double> > EffortLimits ( const EntityComponentManager &  _ecm) const
For each axis, returns the maximum absolute effort limit. The size of the returned vector corresponds to the joint's degrees of freedom. For multi-axis joints, limits are returned for each axis in order (for example, including both JointAxis and JointAxis2 when applicable).
[in]_ecmEntity component manager.
Effort limits if available.
◆ EnablePositionCheck()
void EnablePositionCheck ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
[in]_ecmMutable reference to the ECM.
[in]_enableTrue to enable checks, false to disable. Defaults to true.
◆ EnableTransmittedWrenchCheck()
void EnableTransmittedWrenchCheck ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
◆ EnableVelocityCheck()
void EnableVelocityCheck ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
◆ Entity()
sim::Entity Entity ( ) const
Joint entity.
◆ MaxVelocityLimits()
std::optional<std::vector<double> > MaxVelocityLimits ( const EntityComponentManager &  _ecm) const
For each axis, returns the maximum absolute velocity limit. The size of the returned vector corresponds to the joint's degrees of freedom. For multi-axis joints, limits are returned for each axis in order (for example, including both JointAxis and JointAxis2 when applicable).
Velocity limits if available.
◆ Name()
std::optional<std::string> Name ( const EntityComponentManager &  _ecm) const
Joint's name or nullopt if the entity does not have a components::Name component
◆ ParentLinkName()
std::optional<std::string> ParentLinkName ( const EntityComponentManager &  _ecm) const
Parent link name or nullopt if the entity does not have a components::ParentLinkName component.
◆ ParentModel()
std::optional<Model> ParentModel ( const EntityComponentManager &  _ecm) const
Parent Model or nullopt if the entity does not have a components::ParentEntity component.
◆ Pose()
std::optional<math::Pose3d> Pose ( const EntityComponentManager &  _ecm) const
Pose of the joint or nullopt if the entity does not have a components::Pose component.
◆ Position()
std::optional<std::vector<double> > Position ( const EntityComponentManager &  _ecm) const
Position of the joint or nullopt if position check is not enabled.
EnablePositionCheck
◆ PositionLimits()
std::optional<std::vector<math::Vector2d> > PositionLimits ( const EntityComponentManager &  _ecm) const
For each axis, returns min / max position limits. The size of the returned vector corresponds to the joint's degrees of freedom. For multi-axis joints, limits are returned for each axis in order (for example, including both JointAxis and JointAxis2 when applicable).
Position limits if available.
◆ ResetEntity()
[in]_newEntityNew joint entity.
◆ ResetPosition()
void ResetPosition ( EntityComponentManager &  _ecm,
const std::vector< double > &  _positions
[in]_ecmEntity Component manager.
[in]_positionsJoint positions to reset to. The vector of positions should have the same size as the degrees of freedom of the joint.
◆ ResetVelocity()
void ResetVelocity ( EntityComponentManager &  _ecm,
const std::vector< double > &  _velocities
[in]_velocitiesJoint velocities to reset to. This is different from SetVelocity as this modifies the internal state of the joint. The vector of velocities should have the same size as the degrees of freedom of the joint.
◆ SensorByName()
sim::Entity SensorByName ( const EntityComponentManager &  _ecm,
const std::string &  _name
) const
[in]_nameSensor name.
Sensor entity.
◆ SensorCount()
uint64_t SensorCount ( const EntityComponentManager &  _ecm) const
Number of sensors in this joint.
◆ Sensors()
std::vector<sim::Entity> Sensors ( const EntityComponentManager &  _ecm) const
All sensors in this joint.
◆ SetEffortLimits()
void SetEffortLimits ( EntityComponentManager &  _ecm,
const std::vector< math::Vector2d > &  _limits
[in]_limitsJoint limits to set to. The X() component of the Vector2 specifies the minimum effort limit, the Y() component stands for maximum limit. The vector of limits should have the same size as the degrees of freedom of the joint.
◆ SetForce()
void SetForce ( EntityComponentManager &  _ecm,
const std::vector< double > &  _forces
[in]_forcesJoint force or torque commands (target forces or torques). The vector of forces should have the same size as the degrees of freedom of the joint.
◆ SetPositionLimits()
void SetPositionLimits ( EntityComponentManager &  _ecm,
[in]_limitsJoint limits to set to. The X() component of the Vector2 specifies the minimum position limit, the Y() component stands for maximum limit. The vector of limits should have the same size as the degrees of freedom of the joint.
◆ SetVelocity()
void SetVelocity ( EntityComponentManager &  _ecm,
[in]_velocitiesJoint velocities commands (target velocities). This is different from ResetVelocity in that this does not modify the internal state of the joint. Instead, the physics engine is expected to compute the necessary joint torque for the commanded velocity and apply it in the next simulation step. The vector of velocities should have the same size as the degrees of freedom of the joint.
◆ SetVelocityLimits()
void SetVelocityLimits ( EntityComponentManager &  _ecm,
[in]_limitsJoint limits to set to. The X() component of the Vector2 specifies the minimum velocity limit, the Y() component stands for maximum limit. The vector of limits should have the same size as the degrees of freedom of the joint.
◆ ThreadPitch()
std::optional<double> ThreadPitch ( const EntityComponentManager &  _ecm) const
Thread pitch of the joint or nullopt if the entity does not have a components::ThreadPitch component.
◆ TransmittedWrench()
std::optional<std::vector<msgs::Wrench> > TransmittedWrench ( const EntityComponentManager &  _ecm) const
Transmitted wrench of the joint or nullopt if transmitted wrench check is not enabled.
◆ Type()
std::optional<sdf::JointType> Type ( const EntityComponentManager &  _ecm) const
Get the joint type.
Type of the joint or nullopt if the entity does not have a components::JointType component.
◆ Valid()
True if it's a valid joint in the manager.
◆ Velocity()
std::optional<std::vector<double> > Velocity ( const EntityComponentManager &  _ecm) const
Velocity of the joint or nullopt if velocity check is not enabled.
EnableVelocityCheck
