A class that handles Lidar sensor changes. More...
#include <Lidar.hh>
 Lidar (ComponentInspectorEditor *_inspector)
Q_INVOKABLE void OnLidarChange (double _rangeMin, double _rangeMax, double _rangeResolution, double _horizontalScanSamples, double _horizontalScanResolution, double _horizontalScanMinAngle, double _horizontalScanMaxAngle, double _verticalScanSamples, double _verticalScanResolution, double _verticalScanMinAngle, double _verticalScanMaxAngle)
Q_INVOKABLE void OnLidarNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the Lidar sensor's linear acceleration X noise values. More...
◆ Lidar()
Lidar ( ComponentInspectorEditor *  _inspector)
◆ OnLidarChange()
Q_INVOKABLE void OnLidarChange ( double  _rangeMin,
double  _rangeMax,
◆ OnLidarNoise()
Q_INVOKABLE void OnLidarNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
[in]_meanBiasBias mean value
