This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a link entity. More...
#include <gz/sim/Link.hh>
 Link (const Link &_link)
 Copy constructor. More...
 Link (Link &&_link) noexcept
 Move constructor. More...
 Link (sim::Entity _entity=kNullEntity)
 ~Link ()
void AddWorldForce (EntityComponentManager &_ecm, const math::Vector3d &_force) const
 Add a force expressed in world coordinates and applied at the center of mass of the link. More...
void AddWorldForce (EntityComponentManager &_ecm, const math::Vector3d &_force, const math::Vector3d &_position) const
 Add a force expressed in world coordinates and applied at an offset from the center of mass of the link. More...
void AddWorldWrench (EntityComponentManager &_ecm, const math::Vector3d &_force, const math::Vector3d &_torque) const
 Add a wrench expressed in world coordinates and applied to the link at the link's origin. This wrench is applied for one simulation step. More...
void AddWorldWrench (EntityComponentManager &_ecm, const math::Vector3d &_force, const math::Vector3d &_torque, const math::Vector3d &_offset) const
 Add a wrench expressed in world coordinates and applied to the link at an offset from the link's origin. This wrench is applied for one simulation step. More...
std::optional< math::AxisAlignedBox > AxisAlignedBox (const EntityComponentManager &_ecm) const
 Get the link's axis-aligned bounding box in the link frame. More...
sim::Entity CollisionByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a collision entity which is an immediate child of this link. More...
uint64_t CollisionCount (const EntityComponentManager &_ecm) const
 Get the number of collisions which are immediate children of this link. More...
std::vector< sim::Entity > Collisions (const EntityComponentManager &_ecm) const
 Get all collisions which are immediate children of this link. More...
std::optional< math::AxisAlignedBox > ComputeAxisAlignedBox (const EntityComponentManager &_ecm) const
 Compute the axis-aligned bounding box of the link. It generates an axis-aligned bounding box for a link based on the collision shapes attached to the it. The link bounding box is generated by merging all the bounding boxes of the collision geometry shapes attached to the link. More...
void EnableAccelerationChecks (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report accelerations for a link, so functions like WorldLinearAcceleration will return nullopt. This function can be used to enable all acceleration checks. More...
void EnableBoundingBoxChecks (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report bounding box for a link, so functions like AxisAlignedBox and WorldAxisAlignedBox will return nullopt. This function can be used to enable bounding box checks and it also initializes the bounding box based on the link's collision shapes. More...
void EnableVelocityChecks (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report velocities for a link, so functions like WorldLinearVelocity will return nullopt. This function can be used to enable all velocity checks. More...
sim::Entity Entity () const
 Get the entity which this Link is related to. More...
std::optional< bool > GravityEnabled (const EntityComponentManager &_ecm) const
 Get whether this link has gravity enabled. More...
bool IsCanonical (const EntityComponentManager &_ecm) const
 Check if this is the canonical link. More...
 Get the link's unscoped name. More...
Link & operator= (const Link &_link)
 Copy assignment operator. More...
Link & operator= (Link &&_link) noexcept
 Move assignment operator. More...
std::optional< Model > ParentModel (const EntityComponentManager &_ecm) const
 Get the parent model. More...
 Reset Entity to a new one. More...
sim::Entity SensorByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a sensor entity which is an immediate child of this link. More...
uint64_t SensorCount (const EntityComponentManager &_ecm) const
 Get the number of sensors which are immediate children of this link. More...
std::vector< sim::Entity > Sensors (const EntityComponentManager &_ecm) const
 Get all sensors which are immediate children of this link. More...
void SetAngularVelocity (EntityComponentManager &_ecm, const math::Vector3d &_vel) const
 Set the angular velocity on this link. If this is set, wrenches on this link will be ignored for the current time step. More...
void SetGravityEnabled (EntityComponentManager &_ecm, bool _enabled) const
 Set a new command to change the link's gravity. More...
void SetLinearVelocity (EntityComponentManager &_ecm, const math::Vector3d &_vel) const
 Set the linear velocity on this link. If this is set, wrenches on this link will be ignored for the current time step. More...
 Check whether this link correctly refers to an entity that has a components::Link. More...
sim::Entity VisualByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a visual entity which is an immediate child of this link. More...
uint64_t VisualCount (const EntityComponentManager &_ecm) const
 Get the number of visuals which are immediate children of this link. More...
std::vector< sim::Entity > Visuals (const EntityComponentManager &_ecm) const
 Get all visuals which are immediate children of this link. More...
bool WindMode (const EntityComponentManager &_ecm) const
 Get whether this link has wind enabled. More...
std::optional< math::Vector3d > WorldAngularAcceleration (const EntityComponentManager &_ecm) const
 Get the angular acceleration of the body in the world frame. More...
std::optional< math::Vector3d > WorldAngularVelocity (const EntityComponentManager &_ecm) const
 Get the angular velocity of the link in the world frame. More...
std::optional< math::AxisAlignedBox > WorldAxisAlignedBox (const EntityComponentManager &_ecm) const
 Get the link's axis-aligned bounding box in the world frame. More...
std::optional< math::Matrix6d > WorldFluidAddedMassMatrix (const EntityComponentManager &_ecm) const
 Get the fluid added mass matrix in the world frame. More...
std::optional< math::Inertiald > WorldInertial (const EntityComponentManager &_ecm) const
 Get the world inertia of the link. More...
std::optional< math::Pose3d > WorldInertialPose (const EntityComponentManager &_ecm) const
 Get the world pose of the link inertia. More...
std::optional< math::Matrix3d > WorldInertiaMatrix (const EntityComponentManager &_ecm) const
 Get the inertia matrix in the world frame. More...
std::optional< double > WorldKineticEnergy (const EntityComponentManager &_ecm) const
 Get the rotational and translational kinetic energy of the link with respect to the world frame. More...
std::optional< math::Vector3d > WorldLinearAcceleration (const EntityComponentManager &_ecm) const
 Get the linear acceleration of the body in the world frame. More...
std::optional< math::Vector3d > WorldLinearVelocity (const EntityComponentManager &_ecm) const
 Get the linear velocity at the origin of of the link frame expressed in the world frame, using an offset expressed in a body-fixed frame. If no offset is given, the velocity at the origin of the Link frame will be returned. More...
std::optional< math::Vector3d > WorldLinearVelocity (const EntityComponentManager &_ecm, const math::Vector3d &_offset) const
 Get the linear velocity of a point on the body in the world frame, using an offset expressed in a body-fixed frame. More...
std::optional< math::Pose3d > WorldPose (const EntityComponentManager &_ecm) const
 Get the pose of the link frame in the world coordinate frame. More...
For example, given a link's entity, to find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Link link(entity); std::string name = link.Name(ecm);
◆ Link() [1/3]
Link ( sim::Entity  _entity = kNullEntity)
[in]_entityLink entity
◆ Link() [2/3]
Link ( const Link &  _link)
Copy constructor.
[in]_linkLink to copy.
◆ Link() [3/3]
Link ( Link &&  _link)
noexcept
Move constructor.
[in]_linkLink to move.
◆ ~Link()
~Link ( )
◆ AddWorldForce() [1/2]
void AddWorldForce ( EntityComponentManager &  _ecm,
const math::Vector3d &  _force
) const
[in]_ecmMutable Entity-component manager.
[in]_forceForce to be applied expressed in world coordinates
◆ AddWorldForce() [2/2]
const math::Vector3d &  _force,
const math::Vector3d &  _position
) const
[in]_positionThe point of application of the force expressed in the link-fixed frame.
◆ AddWorldWrench() [1/2]
void AddWorldWrench ( EntityComponentManager &  _ecm,
const math::Vector3d &  _torque
) const
[in]_torqueTorque to be applied expressed in world coordinates
◆ AddWorldWrench() [2/2]
const math::Vector3d &  _torque,
const math::Vector3d &  _offset
) const
[in]_offsetThe point of application of the force expressed in the link frame
◆ AxisAlignedBox()
std::optional<math::AxisAlignedBox> AxisAlignedBox ( const EntityComponentManager &  _ecm) const
Link's AxisAlignedBox in the link frame or nullopt if the link entity does not have a components::AxisAlignedBox component.
◆ CollisionByName()
sim::Entity CollisionByName ( const EntityComponentManager &  _ecm,
const std::string &  _name
) const
[in]_nameCollision name.
Collision entity.
◆ CollisionCount()
uint64_t CollisionCount ( const EntityComponentManager &  _ecm) const
Number of collisions in this link.
◆ Collisions()
std::vector<sim::Entity> Collisions ( const EntityComponentManager &  _ecm) const
All collisions in this link.
◆ ComputeAxisAlignedBox()
std::optional<math::AxisAlignedBox> ComputeAxisAlignedBox ( const EntityComponentManager &  _ecm) const
Link's axis-aligned bounding box in the link frame or nullopt if the link does not have collisions. It returns an invalid bounding box if all of the link collisions are empty.
◆ EnableAccelerationChecks()
void EnableAccelerationChecks ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
[in]_ecmMutable reference to the ECM.
[in]_enableTrue to enable checks, false to disable. Defaults to true.
◆ EnableBoundingBoxChecks()
void EnableBoundingBoxChecks ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
◆ EnableVelocityChecks()
void EnableVelocityChecks ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
◆ Entity()
sim::Entity Entity ( ) const
Link entity.
◆ GravityEnabled()
std::optional<bool> GravityEnabled ( const EntityComponentManager &  _ecm) const
True if gravity mode is on, nullopt if component is missing.
◆ IsCanonical()
bool IsCanonical ( const EntityComponentManager &  _ecm) const
True if it is the canonical link.
◆ Name()
std::optional<std::string> Name ( const EntityComponentManager &  _ecm) const
Link's name or nullopt if the entity does not have a components::Name component
◆ operator=() [1/2]
Link& operator= ( const Link &  _link)
Reference to this.
◆ operator=() [2/2]
Link& operator= ( Link &&  _link)
noexcept
[in]_linkLink component to move.
Reference to this.
◆ ParentModel()
std::optional<Model> ParentModel ( const EntityComponentManager &  _ecm) const
Parent Model or nullopt if the entity does not have a components::ParentEntity component.
◆ ResetEntity()
[in]_newEntityNew link entity.
◆ SensorByName()
sim::Entity SensorByName ( const EntityComponentManager &  _ecm,
) const
[in]_nameSensor name.
Sensor entity.
◆ SensorCount()
uint64_t SensorCount ( const EntityComponentManager &  _ecm) const
Number of sensors in this link.
◆ Sensors()
std::vector<sim::Entity> Sensors ( const EntityComponentManager &  _ecm) const
All sensors in this link.
◆ SetAngularVelocity()
void SetAngularVelocity ( EntityComponentManager &  _ecm,
const math::Vector3d &  _vel
) const
[in]_ecmEntity Component manager.
[in]_velAngular velocity to set in Link's Frame.
◆ SetGravityEnabled()
void SetGravityEnabled ( EntityComponentManager &  _ecm,
bool  _enabled
) const
[in]_enabledTrue to enable gravity, false otherwise.
◆ SetLinearVelocity()
void SetLinearVelocity ( EntityComponentManager &  _ecm,
) const
[in]_velLinear velocity to set in Link's Frame.
◆ Valid()
True if it's a valid link in the manager.
◆ VisualByName()
sim::Entity VisualByName ( const EntityComponentManager &  _ecm,
) const
[in]_nameVisual name.
Visual entity.
◆ VisualCount()
uint64_t VisualCount ( const EntityComponentManager &  _ecm) const
Number of visuals in this link.
◆ Visuals()
std::vector<sim::Entity> Visuals ( const EntityComponentManager &  _ecm) const
All visuals in this link.
◆ WindMode()
bool WindMode ( const EntityComponentManager &  _ecm) const
True if wind mode is on.
◆ WorldAngularAcceleration()
std::optional<math::Vector3d> WorldAngularAcceleration ( const EntityComponentManager &  _ecm) const
Angular acceleration of the body in the world frame or nullopt if acceleration checks aren't enabled.
◆ WorldAngularVelocity()
std::optional<math::Vector3d> WorldAngularVelocity ( const EntityComponentManager &  _ecm) const
Angular velocity of the link or nullopt if velocity checks aren't enabled.
◆ WorldAxisAlignedBox()
std::optional<math::AxisAlignedBox> WorldAxisAlignedBox ( const EntityComponentManager &  _ecm) const
Link's AxisAlignedBox in the world frame or nullopt if the link entity does not have a components::AxisAlignedBox component.
AxisAlignedBox
◆ WorldFluidAddedMassMatrix()
std::optional<math::Matrix6d> WorldFluidAddedMassMatrix ( const EntityComponentManager &  _ecm) const
Fluide added matrix in world frame, returns nullopt if link does not have components components::Inertial and components::WorldPose.
◆ WorldInertial()
std::optional<math::Inertiald> WorldInertial ( const EntityComponentManager &  _ecm) const
Inertia of the link pose in world frame or nullopt if the link does not have the component components::Inertial.
◆ WorldInertialPose()
std::optional<math::Pose3d> WorldInertialPose ( const EntityComponentManager &  _ecm) const
Inertial pose in world frame or nullopt if the link does not have the components components::WorldPose and components::Inertial.
◆ WorldInertiaMatrix()
std::optional<math::Matrix3d> WorldInertiaMatrix ( const EntityComponentManager &  _ecm) const
Inertia matrix in world frame, returns nullopt if link does not have components components::Inertial and components::WorldPose.
◆ WorldKineticEnergy()
std::optional<double> WorldKineticEnergy ( const EntityComponentManager &  _ecm) const
Kinetic energy in world frame, returns nullopt if link does not have components components::Inertial, components::WorldAngularVelocity, components::WorldLinearVelocity, and components::WorldPose.
◆ WorldLinearAcceleration()
std::optional<math::Vector3d> WorldLinearAcceleration ( const EntityComponentManager &  _ecm) const
Linear acceleration of the body in the world frame or nullopt if acceleration checks aren't enabled.
◆ WorldLinearVelocity() [1/2]
std::optional<math::Vector3d> WorldLinearVelocity ( const EntityComponentManager &  _ecm) const
Linear velocity of the link or nullopt if the velocity checks aren't enabled.
◆ WorldLinearVelocity() [2/2]
std::optional<math::Vector3d> WorldLinearVelocity ( const EntityComponentManager &  _ecm,
) const
[in]_offsetOffset of the point from the origin of the Link frame, expressed in the body-fixed frame.
Linear velocity of the point on the body or nullopt if velocity checks aren't enabled.
◆ WorldPose()
std::optional<math::Pose3d> WorldPose ( const EntityComponentManager &  _ecm) const
Absolute Pose of the link or nullopt if the entity does not have a components::WorldPose component.
