Provides buttons for translation, rotation, and scale. More...
#include <TransformControl.hh>
Public Slots
void OnMode (const QString &_mode)
 Callback in Qt thread when mode changes. More...
void OnSnapToGrid ()
 Callback in Qt thread when the snap to grid button is clicked. More...
void OnSnapUpdate (double _x, double _y, double _z, double _roll, double _pitch, double _yaw, double _scaleX, double _scaleY, double _scaleZ)
 Sends an event to update the internal snapping values for translation, rotation, and scaling. More...
double pitchSnap ()
 Callback in Qt thread when the snap to grid button is clicked in order to update custom snap values menu. More...
double rollSnap ()
double scaleXSnap ()
double scaleYSnap ()
double scaleZSnap ()
double xSnap ()
double yawSnap ()
double ySnap ()
double zSnap ()
Signals
void activateRotate ()
 Notify that rotation has been activated. More...
void activateSelect ()
 Notify that selection has been activated. More...
void activateTranslate ()
 Notify that translation has been activated. More...
void newSnapValues ()
 Notify that new snapping values have been set. More...
 TransformControl ()
 ~TransformControl () override
void LoadGrid ()
 Callback to retrieve existing grid. Should only be called within the render thread. If no grid is found, the grid pointer is not updated. More...
void SnapToGrid ()
 Sets the custom snap values to the grid values. More...
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
void DeleteLater ()
std::string configStr
std::string title
Configuration
<service> : Set the service to receive transform mode requests.
◆ TransformControl()
◆ ~TransformControl()
~TransformControl ( )
◆ activateRotate
void activateRotate ( )
signal
◆ activateSelect
void activateSelect ( )
signal
◆ activateTranslate
void activateTranslate ( )
signal
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
Reimplemented from Plugin.
◆ LoadGrid()
void LoadGrid ( )
◆ newSnapValues
void newSnapValues ( )
signal
◆ OnMode
void OnMode ( const QString &  _mode)
slot
[in]_modeNew transform mode
◆ OnSnapToGrid
void OnSnapToGrid ( )
slot
◆ OnSnapUpdate
void OnSnapUpdate ( double  _x,
double  _y,
double  _z,
double  _roll,
double  _pitch,
double  _yaw,
double  _scaleX,
double  _scaleY,
double  _scaleZ
slot
[in]_xThe snapping distance along the world's x (red) axis expressed in meters.
[in]_yThe snapping distance along the world's y (green) axis expressed in meters.
[in]_zThe snapping distance along the world's z (blue) axis expressed in meters.
[in]_rollThe snapping distance along the entity's roll (red) axis expressed in degrees.
[in]_pitchThe snapping distance along the entity's pitch (green) axis expressed in degrees.
[in]_yawThe snapping distance along the entity's yaw (blue) axis expressed in degrees.
[in]_scaleXThe snapping scale along the entity's x (red) axis
[in]_scaleYThe snapping scale along the entity's y (green) axis
[in]_scaleZThe snapping scale along the entity's z (blue) axis
◆ pitchSnap
double pitchSnap ( )
slot
The set pitch rotational snapping value
◆ rollSnap
double rollSnap ( )
slot
The set roll rotational snapping value
◆ scaleXSnap
double scaleXSnap ( )
slot
The set x scaling snapping value
◆ scaleYSnap
double scaleYSnap ( )
slot
The set y scaling snapping value
◆ scaleZSnap
double scaleZSnap ( )
slot
The set z scaling snapping value
◆ SnapToGrid()
void SnapToGrid ( )
◆ xSnap
double xSnap ( )
slot
The set x translational snapping value
◆ yawSnap
double yawSnap ( )
slot
The set yaw rotational snapping value
◆ ySnap
double ySnap ( )
slot
The set y translational snapping value
◆ zSnap
double zSnap ( )
slot
The set z translational snapping value
