BaseCompositeStore< T > Class Template Reference
#include <BaseStorage.hh>
 BaseCompositeStore ()
virtual ~BaseCompositeStore ()
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
virtual bool AddStore (TStorePtr _store)
 Add the given store. If the given store already exists, then no work will be done.
virtual bool ContainsStore (ConstTStorePtr _store) const
 Determine if given store exists.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual TStorePtr GetStore (unsigned int _index) const
 Get store at the given index. If no such store exists NULL will be returned.
virtual unsigned int GetStoreCount () const
 Get number of Stores.
virtual void RemoveAll ()
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual TStorePtr RemoveStore (TStorePtr _store)
 Remove given store. If no such store exists no work will be done and NULL will be returned.
virtual TStorePtr RemoveStore (unsigned int _index)
 Remove store at the given index. If no such store exists no work will be done and NULL will be returned.
virtual TStorePtr RemoveStoreImpl (TStoreIter _iter)
- Public Member Functions inherited from CompositeStore< T >
virtual ~CompositeStore ()=default
virtual ~Store ()=default
TStoreList stores
◆ BaseCompositeStore()
template<class T >
BaseCompositeStore ( )
◆ ~BaseCompositeStore()
template<class T >
~BaseCompositeStore ( )
◆ Add()
template<class T >
bool Add ( TPtr  _object)
True if successful
Implements Store< T >.
References std::endl(), and gzerr.
◆ AddStore()
template<class T >
bool AddStore ( TStorePtr  _store)
[in]_storeStore to be added
True if successful
Implements CompositeStore< T >.
◆ Contains()
template<class T >
◆ ContainsId()
template<class T >
◆ ContainsName()
template<class T >
◆ ContainsStore()
template<class T >
bool ContainsStore ( ConstTStorePtr  _store) const
[in]_storeStore in question
True if given store exists
References std::find().
template<class T >
void Destroy ( TPtr  _object)
◆ DestroyAll()
template<class T >
void DestroyAll ( )
◆ DestroyById()
template<class T >
◆ DestroyByIndex()
template<class T >
◆ DestroyByName()
template<class T >
◆ GetById()
template<class T >
BaseCompositeStore< T >::TPtr GetById ( unsigned int  _id) const
The specified element
◆ GetByIndex()
template<class T >
BaseCompositeStore< T >::TPtr GetByIndex ( unsigned int  _index) const
◆ GetByName()
template<class T >
BaseCompositeStore< T >::TPtr GetByName ( const std::string &  _name) const
◆ GetStore()
template<class T >
BaseCompositeStore< T >::TStorePtr GetStore ( unsigned int  _index) const
[in]_indexIndex of the desired store
The specified store
◆ GetStoreCount()
template<class T >
unsigned int GetStoreCount ( ) const
The number of Stores
◆ Remove()
template<class T >
BaseCompositeStore< T >::TPtr Remove ( TPtr  _object)
The removed element
◆ RemoveAll()
template<class T >
void RemoveAll ( )
◆ RemoveById()
template<class T >
BaseCompositeStore< T >::TPtr RemoveById ( unsigned int  _id)
The removed element
◆ RemoveByIndex()
template<class T >
BaseCompositeStore< T >::TPtr RemoveByIndex ( unsigned int  _index)
The removed element
◆ RemoveByName()
template<class T >
BaseCompositeStore< T >::TPtr RemoveByName ( const std::string &  _name)
The removed element
◆ RemoveStore() [1/2]
template<class T >
BaseCompositeStore< T >::TStorePtr RemoveStore ( TStorePtr  _store)
[in]_storeStore to be removed
The removed store
◆ RemoveStore() [2/2]
template<class T >
BaseCompositeStore< T >::TStorePtr RemoveStore ( unsigned int  _index)
[in]_indexIndex of the store to be removed
The removed store
References std::advance(), std::endl(), and gzerr.
◆ RemoveStoreImpl()
template<class T >
BaseCompositeStore< T >::TStorePtr RemoveStoreImpl ( TStoreIter  _iter)
◆ Size()
template<class T >
unsigned int Size ( ) const
◆ stores
template<class T >
TStoreList stores
