Store< T > Class Template Referenceabstract
#include <gz/rendering/Storage.hh>
virtual ~Store ()=default
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()=0
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual void RemoveAll ()=0
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
template<class T>
class gz::rendering::Store< T >
Template Parameters
TThe storage element type
◆ ~Store()
template<class T >
virtual ~Store ( )
virtualdefault
◆ Add()
template<class T >
virtual bool Add ( TPtr  _object)
True if successful
Implemented in BaseStore< T, U >, BaseStore< Geometry, T >, BaseStore< Light, T >, BaseStore< Node, T >, BaseStore< Scene, T >, BaseStore< Sensor, T >, BaseStore< SubMesh, T >, BaseStore< Visual, T >, BaseCompositeStore< T >, BaseCompositeStore< Node >, and BaseStoreWrapper< T, U >.
◆ Contains()
template<class T >
virtual bool Contains ( ConstTPtr  _object) const
◆ ContainsId()
template<class T >
virtual bool ContainsId ( unsigned int  _id) const
◆ ContainsName()
template<class T >
virtual bool ContainsName ( const std::string &  _name) const
template<class T >
virtual void Destroy ( TPtr  _object)
◆ DestroyAll()
◆ DestroyById()
template<class T >
virtual void DestroyById ( unsigned int  _id)
◆ DestroyByIndex()
template<class T >
virtual void DestroyByIndex ( unsigned int  _index)
◆ DestroyByName()
template<class T >
virtual void DestroyByName ( const std::string &  _name)
◆ GetById()
template<class T >
virtual TPtr GetById ( unsigned int  _id) const
◆ GetByIndex()
template<class T >
◆ GetByName()
template<class T >
virtual TPtr GetByName ( const std::string &  _name) const
◆ Remove()
template<class T >
virtual TPtr Remove ( TPtr  _object)
The removed element
◆ RemoveAll()
◆ RemoveById()
template<class T >
virtual TPtr RemoveById ( unsigned int  _id)
The removed element
◆ RemoveByIndex()
template<class T >
virtual TPtr RemoveByIndex ( unsigned int  _index)
The removed element
◆ RemoveByName()
template<class T >
virtual TPtr RemoveByName ( const std::string &  _name)
The removed element
◆ Size()
template<class T >
