#include <BaseStorage.hh>
 BaseStore ()
virtual ~BaseStore ()
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
virtual UIter Begin ()
 Return an iterator to the beginning.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual UIter End ()
 Return an iterator to the end.
virtual void RemoveAll ()
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual ~Store ()=default
 Get a const iterator to the object by pointer. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get a const iterator to the object by id. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get a const iterator to the object by index. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get a const iterator to the object by name. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by pointer. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by id. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by index. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by name. Note that the iterator may change or become invalid when objects are added to / removed from the store.
UStore store
UStoreMap storeMap
◆ BaseStore()
template<class T , class U >
BaseStore ( )
◆ ~BaseStore()
~BaseStore ( )
◆ Add()
bool Add ( TPtr  _object)
True if successful
Implements Store< T >.
References std::dynamic_pointer_cast(), std::endl(), and gzerr.
◆ AddDerived()
bool AddDerived ( UPtr  _object)
References std::endl(), and gzerr.
◆ AddImpl()
bool AddImpl ( UPtr  _object)
References std::endl(), gzerr, and string::size().
◆ Begin()
BaseStore< T, U >::UIter Begin ( )
Iterator to beginning
◆ ConstIter()
BaseStore< T, U >::ConstUIter ConstIter ( ConstTPtr  _object) const
[in]_objectObject pointer
Const iterator to the object
◆ ConstIterById()
BaseStore< T, U >::ConstUIter ConstIterById ( unsigned int  _id) const
[in]_idObject id
◆ ConstIterByIndex()
BaseStore< T, U >::ConstUIter ConstIterByIndex ( unsigned int  _index) const
[in]_indexObject index
References std::advance(), std::endl(), and gzerr.
◆ ConstIterByName()
BaseStore< T, U >::ConstUIter ConstIterByName ( const std::string &  _name) const
[in]_nameObject name
◆ Contains()
◆ ContainsId()
◆ ContainsName()
◆ DerivedById()
BaseStore< T, U >::UPtr DerivedById ( unsigned int  _id) const
◆ DerivedByIndex()
BaseStore< T, U >::UPtr DerivedByIndex ( unsigned int  _index) const
◆ DerivedByName()
BaseStore< T, U >::UPtr DerivedByName ( const std::string &  _name) const
void Destroy ( TPtr  _object)
◆ DestroyAll()
void DestroyAll ( )
◆ DestroyById()
◆ DestroyByIndex()
◆ DestroyByName()
◆ DestroyImpl()
void DestroyImpl ( UIter  _iter)
◆ End()
BaseStore< T, U >::UIter End ( )
Iterator to end
◆ GetById()
BaseStore< T, U >::TPtr GetById ( unsigned int  _id) const
The specified element
◆ GetByIndex()
BaseStore< T, U >::TPtr GetByIndex ( unsigned int  _index) const
◆ GetByName()
BaseStore< T, U >::TPtr GetByName ( const std::string &  _name) const
◆ IsValidIter()
◆ Iter()
BaseStore< T, U >::UIter Iter ( ConstTPtr  _object)
Iterator to the object
◆ IterById()
BaseStore< T, U >::UIter IterById ( unsigned int  _id)
[in]_idObject id
◆ IterByIndex()
BaseStore< T, U >::UIter IterByIndex ( unsigned int  _index)
◆ IterByName()
BaseStore< T, U >::UIter IterByName ( const std::string &  _name)
◆ Remove()
BaseStore< T, U >::TPtr Remove ( TPtr  _object)
The removed element
◆ RemoveAll()
void RemoveAll ( )
◆ RemoveById()
BaseStore< T, U >::TPtr RemoveById ( unsigned int  _id)
The removed element
◆ RemoveByIndex()
BaseStore< T, U >::TPtr RemoveByIndex ( unsigned int  _index)
The removed element
◆ RemoveByName()
BaseStore< T, U >::TPtr RemoveByName ( const std::string &  _name)
The removed element
◆ RemoveConstness()
BaseStore< T, U >::UIter RemoveConstness ( ConstUIter  _iter)
◆ RemoveDerived()
BaseStore< T, U >::UPtr RemoveDerived ( UPtr  _object)
◆ RemoveDerivedById()
BaseStore< T, U >::UPtr RemoveDerivedById ( unsigned int  _id)
◆ RemoveDerivedByIndex()
BaseStore< T, U >::UPtr RemoveDerivedByIndex ( unsigned int  _index)
◆ RemoveDerivedByName()
BaseStore< T, U >::UPtr RemoveDerivedByName ( const std::string &  _name)
◆ RemoveImpl()
BaseStore< T, U >::UPtr RemoveImpl ( UIter  _iter)
References std::distance(), and string::erase().
◆ Size()
unsigned int Size ( ) const
◆ store
UStore store
◆ storeMap
UStoreMap storeMap
