Storage.hh
1/*
2 * Copyright (C) 2015 Open Source Robotics Foundation
3 *
4 * Licensed under the Apache License, Version 2.0 (the "License");
5 * you may not use this file except in compliance with the License.
6 * You may obtain a copy of the License at
7 *
8 * http://www.apache.org/licenses/LICENSE-2.0
9 *
10 * Unless required by applicable law or agreed to in writing, software
11 * distributed under the License is distributed on an "AS IS" BASIS,
12 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
13 * See the License for the specific language governing permissions and
14 * limitations under the License.
15 *
16 */
17#ifndef GZ_RENDERING_STORAGE_HH_
18#define GZ_RENDERING_STORAGE_HH_
20#include <memory>
21#include <string>
22#include "gz/rendering/config.hh"
23#include "gz/rendering/Scene.hh"
24#include "gz/rendering/Node.hh"
25#include "gz/rendering/Light.hh"
30#include "gz/rendering/Mesh.hh"
31#include "gz/rendering/Export.hh"
32
33// An X11 header file defines a macro that conflicts with our function name,
34// so undefine it here
35#ifdef DestroyAll
36#undef DestroyAll
37#endif
38
39namespace gz
40{
41 namespace rendering
42 {
43 inline namespace GZ_RENDERING_VERSION_NAMESPACE {
44 //
48 template <class T>
49 class GZ_RENDERING_VISIBLE Map
50 {
54
58
60 public: virtual ~Map() = default;
61
64 public: virtual unsigned int Size() const = 0;
65
69 public: virtual bool ContainsKey(const std::string &_key) const = 0;
70
74 public: virtual bool ContainsValue(ConstTPtr _value) const = 0;
75
79 public: virtual TPtr Get(const std::string &_key) const = 0;
80
84 public: virtual TPtr GetByIndex(unsigned int _index) const = 0;
85
91 public: virtual bool Put(const std::string &_key, TPtr _value) = 0;
92
96 public: virtual void Remove(const std::string &_key) = 0;
97
101 public: virtual void Remove(TPtr _value) = 0;
102
104 public: virtual void RemoveAll() = 0;
105 };
106
113 template <class T>
114 class GZ_RENDERING_VISIBLE Store
115 {
118 typedef std::shared_ptr<T> TPtr;
119
123
125 public: virtual ~Store() = default;
126
129 public: virtual unsigned int Size() const = 0;
130
134 public: virtual bool Contains(ConstTPtr _object) const = 0;
135
139 public: virtual bool ContainsId(unsigned int _id) const = 0;
140
144 public: virtual bool ContainsName(const std::string &_name) const = 0;
145
149 public: virtual TPtr GetById(unsigned int _id) const = 0;
150
154 public: virtual TPtr GetByName(const std::string &_name) const = 0;
155
159 public: virtual TPtr GetByIndex(unsigned int _index) const = 0;
160
166 public: virtual bool Add(TPtr _object) = 0;
167
172 public: virtual TPtr Remove(TPtr _object) = 0;
173
178 public: virtual TPtr RemoveById(unsigned int _id) = 0;
179
184 public: virtual TPtr RemoveByName(const std::string &_name) = 0;
185
190 public: virtual TPtr RemoveByIndex(unsigned int _index) = 0;
191
193 public: virtual void RemoveAll() = 0;
194
198 public: virtual void Destroy(TPtr _object) = 0;
199
203 public: virtual void DestroyById(unsigned int _id) = 0;
204
209 public: virtual void DestroyByName(const std::string &_name) = 0;
210
215 public: virtual void DestroyByIndex(unsigned int _index) = 0;
216
218 public: virtual void DestroyAll() = 0;
219 };
220
226 template <class T>
227 class GZ_RENDERING_VISIBLE CompositeStore :
228 public Store<T>
229 {
232 typedef std::shared_ptr<T> TPtr;
233
236 typedef Store<T> TStore;
237
241
245
247 public: virtual ~CompositeStore() = default;
248
251 public: virtual unsigned int GetStoreCount() const = 0;
252
256 public: virtual bool ContainsStore(ConstTStorePtr _store) const = 0;
257
262 public: virtual bool AddStore(TStorePtr _store) = 0;
263
268 public: virtual TStorePtr GetStore(unsigned int _index) const = 0;
269
274 public: virtual TStorePtr RemoveStore(TStorePtr _store) = 0;
275
280 public: virtual TStorePtr RemoveStore(unsigned int _index) = 0;
281 };
282
290 template <class T, class U>
291 class GZ_RENDERING_VISIBLE StoreWrapper :
292 public Store<T>
293 {
294 public: virtual ~StoreWrapper() = default;
295 };
296
297// armhf failed to build with this code. It can not be removed for the rest
298// of arches to keep ABI but should be removed in major versions unreleased
299// see https://github.com/gazebosim/gz-rendering/pull/457
300#ifndef __ARM_PCS_VFP
301 template class Store<Scene>;
302 template class Store<Node>;
303 template class Store<Light>;
304 template class Store<Sensor>;
305 template class Store<Visual>;
306 template class Store<Geometry>;
307 template class Store<SubMesh>;
308 template class Map<Material>;
309 template class CompositeStore<Node>;
310#endif
311
315
319
323
327
331
335
339
343
347
351
355
359
363
367
371
375
379
383 }
384 }
385}
386#endif
