StoreWrapper< T, U > Class Template Reference
#include <gz/rendering/StoreWrapper.hh>
virtual ~StoreWrapper ()=default
virtual ~Store ()=default
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()=0
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual void RemoveAll ()=0
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
template<class T, class U>
class gz::rendering::StoreWrapper< T, U >
Template Parameters
TNew storage type
USome derived class of T
◆ ~StoreWrapper()
template<class T , class U >
virtual ~StoreWrapper ( )
virtualdefault
