CompositeStore< T > Class Template Referenceabstract
#include <gz/rendering/Storage.hh>
virtual ~CompositeStore ()=default
virtual bool AddStore (TStorePtr _store)=0
 Add the given store. If the given store already exists, then no work will be done.
virtual bool ContainsStore (ConstTStorePtr _store) const =0
 Determine if given store exists.
virtual TStorePtr GetStore (unsigned int _index) const =0
 Get store at the given index. If no such store exists NULL will be returned.
virtual unsigned int GetStoreCount () const =0
 Get number of Stores.
virtual TStorePtr RemoveStore (TStorePtr _store)=0
 Remove given store. If no such store exists no work will be done and NULL will be returned.
virtual TStorePtr RemoveStore (unsigned int _index)=0
 Remove store at the given index. If no such store exists no work will be done and NULL will be returned.
virtual ~Store ()=default
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()=0
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual void RemoveAll ()=0
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
template<class T>
class gz::rendering::CompositeStore< T >
gz/rendering/CompositeStore.hh
Template Parameters
TThe storage element type
◆ ~CompositeStore()
template<class T >
virtual ~CompositeStore ( )
virtualdefault
◆ AddStore()
template<class T >
virtual bool AddStore ( TStorePtr  _store)
[in]_storeStore to be added
True if successful
Implemented in BaseCompositeStore< T >, and BaseCompositeStore< Node >.
◆ ContainsStore()
template<class T >
virtual bool ContainsStore ( ConstTStorePtr  _store) const
[in]_storeStore in question
True if given store exists
◆ GetStore()
template<class T >
virtual TStorePtr GetStore ( unsigned int  _index) const
[in]_indexIndex of the desired store
The specified store
◆ GetStoreCount()
template<class T >
virtual unsigned int GetStoreCount ( ) const
The number of Stores
◆ RemoveStore() [1/2]
template<class T >
virtual TStorePtr RemoveStore ( TStorePtr  _store)
[in]_storeStore to be removed
The removed store
◆ RemoveStore() [2/2]
template<class T >
virtual TStorePtr RemoveStore ( unsigned int  _index)
[in]_indexIndex of the store to be removed
The removed store
