Storage.hh File Reference
#include <memory>
#include <string>
#include "gz/rendering/config.hh"
#include "gz/rendering/Scene.hh"
#include "gz/rendering/Node.hh"
#include "gz/rendering/Light.hh"
#include "gz/rendering/Sensor.hh"
#include "gz/rendering/Visual.hh"
#include "gz/rendering/Geometry.hh"
#include "gz/rendering/Material.hh"
#include "gz/rendering/Mesh.hh"
#include "gz/rendering/Export.hh"
class  CompositeStore< T >
class  Map< T >
class  Store< T >
class  StoreWrapper< T, U >
namespace  gz
namespace  gz::rendering
typedef Store< Geometry > GeometryStore
typedef std::shared_ptr< GeometryStore > GeometryStorePtr
typedef Store< Light > LightStore
typedef std::shared_ptr< LightStore > LightStorePtr
typedef Map< Material > MaterialMap
typedef std::shared_ptr< MaterialMap > MaterialMapPtr
typedef CompositeStore< Node > NodeCompositeStore
typedef std::shared_ptr< NodeCompositeStore > NodeCompositeStorePtr
typedef Store< Node > NodeStore
typedef std::shared_ptr< NodeStore > NodeStorePtr
typedef Store< Scene > SceneStore
typedef std::shared_ptr< SceneStore > SceneStorePtr
typedef Store< Sensor > SensorStore
typedef std::shared_ptr< SensorStore > SensorStorePtr
typedef Store< SubMesh > SubMeshStore
typedef std::shared_ptr< SubMeshStore > SubMeshStorePtr
typedef Store< Visual > VisualStore
typedef std::shared_ptr< VisualStore > VisualStorePtr
