Sensor Class Referenceabstract
#include <gz/rendering/Sensor.hh>
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~Sensor()
virtual ~Sensor ( )
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implemented in BaseSensor< T >, BaseSensor< Ogre2Node >, BaseSensor< OgreNode >, OgreCamera, OgreWideAngleCamera, and Ogre2Camera.
◆ VisibilityMask()
virtual uint32_t VisibilityMask ( ) const
visibility mask
Implemented in BaseSensor< T >, BaseSensor< Ogre2Node >, and BaseSensor< OgreNode >.
