#include <BaseSensor.hh>
virtual ~BaseSensor ()
 Set visibility mask.
 Get visibility mask.
 Sensor.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseSensor ()
 Camera's visibility mask.
◆ BaseSensor()
template<class T >
BaseSensor ( )
◆ ~BaseSensor()
template<class T >
~BaseSensor ( )
◆ SetVisibilityMask()
template<class T >
void SetVisibilityMask ( uint32_t  _mask)
[in]_maskVisibility mask
Implements Sensor.
Reimplemented in OgreCamera, OgreWideAngleCamera, and Ogre2Camera.
◆ VisibilityMask()
template<class T >
uint32_t VisibilityMask ( ) const
visibility mask
Implements Sensor.
◆ visibilityMask
template<class T >
