Node Class Referenceabstract
#include <gz/rendering/Node.hh>
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~Node()
virtual ~Node ( )
◆ AddChild()
virtual void AddChild ( NodePtr  _child)
[in]_childChild node to be added
Implemented in BaseNode< T >, BaseNode< Ogre2Object >, and BaseNode< OgreObject >.
◆ ChildById()
virtual NodePtr ChildById ( unsigned int  _id) const
[in]_idID of the desired node
The specified node
◆ ChildByIndex()
virtual NodePtr ChildByIndex ( unsigned int  _index) const
The specified node
◆ ChildByName()
virtual NodePtr ChildByName ( const std::string &  _name) const
The specified node
◆ ChildCount()
virtual unsigned int ChildCount ( ) const
The number of child nodes
◆ HasChild()
virtual bool HasChild ( ConstNodePtr  _child) const
True if given node is an attached child
◆ HasChildId()
virtual bool HasChildId ( unsigned int  _id) const
True if node with given ID is an attached child
◆ HasChildName()
virtual bool HasChildName ( const std::string &  _name) const
True if node with given name is an attached child
◆ HasParent()
Implemented in OgreNode, and Ogre2Node.
◆ HasUserData()
virtual bool HasUserData ( const std::string &  _key) const
[in]_keyUnique key
True if node has custom data with the specified key
◆ InheritScale()
Implemented in OgreNode, Ogre2Node, BaseNode< T >, BaseNode< Ogre2Object >, and BaseNode< OgreObject >.
◆ InitialLocalPose()
virtual math::Pose3d InitialLocalPose ( ) const
The initial local pose
◆ LocalPose()
virtual math::Pose3d LocalPose ( ) const
◆ LocalPosition()
virtual math::Vector3d LocalPosition ( ) const
The local position
◆ LocalRotation()
virtual math::Quaterniond LocalRotation ( ) const
The local rotation
◆ LocalScale()
◆ Origin()
virtual math::Vector3d Origin ( ) const
The position of the origin
◆ Parent()
the parent Node
◆ RemoveChild()
virtual NodePtr RemoveChild ( NodePtr  _child)
[in]_childChild node to be removed
The removed child node
◆ RemoveChildById()
virtual NodePtr RemoveChildById ( unsigned int  _id)
[in]_idID of the child node to be removed
◆ RemoveChildByIndex()
virtual NodePtr RemoveChildByIndex ( unsigned int  _index)
[in]_indexIndex of the child node to be removed
◆ RemoveChildByName()
virtual NodePtr RemoveChildByName ( const std::string &  _name)
[in]_nameName of the child node to be removed
◆ RemoveChildren()
virtual void RemoveChildren ( )
◆ RemoveParent()
virtual void RemoveParent ( )
◆ Scale() [1/3]
virtual void Scale ( const math::Vector3d &  _scale)
[in]_scaleScalars to alter the current scale
◆ Scale() [2/3]
virtual void Scale ( double  _scale)
[in]_scaleScalar to alter the current scale
◆ Scale() [3/3]
virtual void Scale ( double  _x,
double  _y,
double  _z
[in]_xScalar to alter the current x-coordinate scale
[in]_yScalar to alter the current y-coordinate scale
[in]_zScalar to alter the current z-coordinate scale
◆ SetInheritScale()
[in]_inheritTrue if this node inherits scale from its parent
◆ SetLocalPose()
virtual void SetLocalPose ( const math::Pose3d &  _pose)
Set the local pose.
[in]_poseNew local pose
Implemented in BaseNode< T >, BaseNode< Ogre2Object >, BaseNode< OgreObject >, BaseVisual< T >, BaseVisual< Ogre2Node >, and BaseVisual< OgreNode >.
◆ SetLocalPosition() [1/2]
virtual void SetLocalPosition ( const math::Vector3d &  _position)
[in]_positionNew local position
Implemented in BaseNode< T >, BaseNode< Ogre2Object >, BaseNode< OgreObject >, and Ogre2Light.
◆ SetLocalPosition() [2/2]
virtual void SetLocalPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetLocalRotation() [1/3]
virtual void SetLocalRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew local rotation
◆ SetLocalRotation() [2/3]
virtual void SetLocalRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
◆ SetLocalRotation() [3/3]
virtual void SetLocalRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetLocalScale() [1/3]
virtual void SetLocalScale ( const math::Vector3d &  _scale)
[in]_scaleNew local scale
Implemented in BaseAxisVisual< T >, BaseAxisVisual< Ogre2Visual >, BaseAxisVisual< OgreVisual >, BaseNode< T >, BaseNode< Ogre2Object >, and BaseNode< OgreObject >.
◆ SetLocalScale() [2/3]
virtual void SetLocalScale ( double  _scale)
◆ SetLocalScale() [3/3]
virtual void SetLocalScale ( double  _x,
double  _y,
double  _z
[in]_xNew x-coordinate scale
[in]_yNew y-coordinate scale
[in]_zNew z-coordinate scale
◆ SetOrigin() [1/2]
virtual void SetOrigin ( const math::Vector3d &  _origin)
[in]_originNew origin position
◆ SetOrigin() [2/2]
virtual void SetOrigin ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetUserData()
virtual void SetUserData ( const std::string &  _key,
Variant  _value
[in]_keyUnique key
[in]_valueValue in any type
◆ SetWorldPose()
virtual void SetWorldPose ( const math::Pose3d &  _pose)
Set the world pose.
[in]_poseNew world pose
◆ SetWorldPosition() [1/2]
virtual void SetWorldPosition ( const math::Vector3d &  _position)
[in]_positionNew world position
◆ SetWorldPosition() [2/2]
virtual void SetWorldPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetWorldRotation() [1/3]
virtual void SetWorldRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew world rotation
◆ SetWorldRotation() [2/3]
virtual void SetWorldRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
◆ SetWorldRotation() [3/3]
virtual void SetWorldRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetWorldScale() [1/3]
virtual void SetWorldScale ( const math::Vector3d &  _scale)
[in]_scaleNew world scale
◆ SetWorldScale() [2/3]
virtual void SetWorldScale ( double  _scale)
◆ SetWorldScale() [3/3]
virtual void SetWorldScale ( double  _x,
double  _y,
double  _z
◆ UserData()
virtual Variant UserData ( const std::string &  _key) const
[in]_keyUnique key
Value in any type. If _key does not exist for the node, an empty variant is returned (i.e., no data).
◆ WorldPose()
virtual math::Pose3d WorldPose ( ) const
Get the world pose.
The world pose
◆ WorldPosition()
virtual math::Vector3d WorldPosition ( ) const
The world position
◆ WorldRotation()
virtual math::Quaterniond WorldRotation ( ) const
The world rotation
◆ WorldScale()
virtual math::Vector3d WorldScale ( ) const
The world scale
◆ WorldToLocal()
virtual math::Pose3d WorldToLocal ( const math::Pose3d &  _pose) const
[in]_poseWorld pose to be converted
