BaseVisual< T > Class Template Referenceabstract
#include <BaseVisual.hh>
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseVisual ()
virtual bool AttachGeometry (GeometryPtr _geometry)=0
virtual bool DetachGeometry (GeometryPtr _geometry)=0
virtual GeometryStorePtr Geometries () const =0
uint32_t visibilityFlags = GZ_VISIBILITY_ALL
 Visual's visibility flags.
bool wireframe = false
◆ BaseVisual()
template<class T >
BaseVisual ( )
◆ ~BaseVisual()
template<class T >
~BaseVisual ( )
◆ AddGeometry()
template<class T >
void AddGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be added
Implements Visual.
◆ AddVisibilityFlags()
template<class T >
void AddVisibilityFlags ( uint32_t  _flags)
[in]_flagsVisibility flags
Implements Visual.
◆ AttachGeometry()
template<class T >
protectedpure virtual
Implemented in OgreVisual, and Ogre2Visual.
◆ BoundingBox()
template<class T >
gz::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Implements Visual.
Reimplemented in OgreVisual, and Ogre2Visual.
References std::dynamic_pointer_cast(), std::endl(), gzerr, and AxisAlignedBox::Merge().
◆ Clone()
template<class T >
VisualPtr Clone ( const std::string &  _name,
NodePtr  _newParent
) const
[in]_nameName of the cloned Visual. Set this to an empty string to auto-generate a unique name for the cloned visual.
[in]_newParentParent of the cloned Visual. Set to nullptr if the cloned visual should have no parent.
The visual. nullptr is returned if cloning failed.
Implements Visual.
References std::dynamic_pointer_cast(), string::empty(), and gzerr.
◆ DetachGeometry()
template<class T >
◆ Geometries()
template<class T >
◆ GeometryByIndex()
template<class T >
GeometryPtr GeometryByIndex ( unsigned int  _index) const
[in]_indexIndex of the desired geometry
The specified geometry
Implements Visual.
◆ GeometryCount()
template<class T >
unsigned int GeometryCount ( ) const
The number of geometries attached to this visual
Implements Visual.
◆ HasGeometry()
template<class T >
bool HasGeometry ( ConstGeometryPtr  _geometry) const
[in]_geometryGeometry in question
True if given node is attached to this visual
Implements Visual.
◆ LocalBoundingBox()
template<class T >
gz::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
Implements Visual.
References std::dynamic_pointer_cast(), std::endl(), gzerr, Vector3< typename T >::IsFinite(), AxisAlignedBox::Max(), AxisAlignedBox::Merge(), and AxisAlignedBox::Min().
◆ LocalPose()
template<class T >
math::Pose3d LocalPose ( ) const
Get the local pose.
The local pose
Implements Node.
References Pose3< typename T >::Pos(), and Pose3< typename T >::Rot().
template<class T >
Implements Visual.
Reimplemented in BaseParticleEmitter< Ogre2Visual >, BaseParticleEmitter< OgreVisual >, OgreCOMVisual, OgreInertiaVisual, OgreLightVisual, Ogre2COMVisual, Ogre2InertiaVisual, and Ogre2LightVisual.
◆ PreRenderChildren()
template<class T >
void PreRenderChildren ( )
◆ PreRenderGeometries()
template<class T >
void PreRenderGeometries ( )
◆ RemoveGeometries()
template<class T >
void RemoveGeometries ( )
Implements Visual.
◆ RemoveGeometry()
template<class T >
GeometryPtr RemoveGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be removed
The removed geometry
Implements Visual.
◆ RemoveGeometryByIndex()
template<class T >
GeometryPtr RemoveGeometryByIndex ( unsigned int  _index)
[in]_indexIndex of the geometry to be removed
Implements Visual.
◆ RemoveVisibilityFlags()
template<class T >
void RemoveVisibilityFlags ( uint32_t  _flags)
Implements Visual.
◆ SetChildMaterial()
template<class T >
void SetChildMaterial ( MaterialPtr  _material,
bool  _unique = true
Implements Visual.
References std::dynamic_pointer_cast(), std::endl(), and gzerr.
◆ SetGeometryMaterial()
template<class T >
void SetGeometryMaterial ( MaterialPtr  _material,
bool  _unique = true
Implements Visual.
◆ SetLocalPose()
template<class T >
void SetLocalPose ( const math::Pose3d &  _pose)
Set the local pose.
[in]_poseNew local pose
Implements Node.
References std::endl(), gzerr, Pose3< typename T >::IsFinite(), Pose3< typename T >::Pos(), and Pose3< typename T >::Rot().
◆ SetMaterial() [1/2]
template<class T >
bool  _unique = true
[in]_nameName of the material to be assigned
Implements Visual.
References Scene::Material().
◆ SetMaterial() [2/2]
template<class T >
bool  _unique = true
Implements Visual.
Reimplemented in OgreCOMVisual, OgreInertiaVisual, OgreLightVisual, Ogre2COMVisual, Ogre2InertiaVisual, Ogre2LightVisual, BaseParticleEmitter< Ogre2Visual >, BaseParticleEmitter< OgreVisual >, and Ogre2ParticleEmitter.
◆ SetStatic()
template<class T >
void SetStatic ( bool  _static)
Remarks
Performance impact of switching staticness depends on on engine. In ogre2 it isn't expensive but it isn't free either. Try to minimize transitions. Raytracing engines may rely on this information for their BVH structures TODO(anyone): Staticness should be ideally be supplied during construction for maximum performance
ogre2 specific: OgreNext keeps 2 lists of objects. Dynamic and Static. Every frame OgreNext iterates through all nodes & items in the dynamic lists and forcefully updates them (regardless of whether they have actually changed). This may sound slow but Ogre 1.x worked by only updating those objects that have changed, and it was slower. CPUs care a lot more about processing in bulk and having all the data hot in cache.
For the static list, it only iterates through the entire list in that frame when the whole list is tagged as dirty. If one element changes, then the whole list is dirty (OgreNext might be able to optimize it and only update a part of the list by narrowing).
Changing a static node transform implies calling OgreNext's notifyStaticDirty. This is very cheap so it can be called whenever a static object changes. The only thing that needs to be taken into account is that notifyStaticDirty should be called as little as possible. And by "as little as possible" that means ideally it should not be called ever except when loading a scene or when something relevant changed. If it gets called e.g. once per frame or more then it's the same as having all objects dynamic.
Thus if an object is static, make sure you don't keep moving around because it negates the performance of all static objects.
Remarks
(INTERNAL) For implementations: Dynamic Scene Node + Dynamic MovableObject = Valid Static Scene Node + Static MovableObject = Valid Static Scene Node + Dynamic MovableObject = Valid, but rarely makes sense Dynamic Scene Node + Static MovableObject = Invalid
[in]_staticTrue if this visual should be made static
Implements Visual.
Reimplemented in Ogre2Visual.
References std::endl(), Scene::Engine(), gzerr, and RenderEngine::Name().
◆ SetVisibilityFlags()
template<class T >
void SetVisibilityFlags ( uint32_t  _flags)
Implements Visual.
◆ SetVisible()
template<class T >
◆ SetWireframe()
template<class T >
void SetWireframe ( bool  _show)
Implements Visual.
◆ Static()
template<class T >
bool Static ( ) const
True if the visual is static, false otherwise
SetStatic
Implements Visual.
◆ VisibilityFlags()
template<class T >
uint32_t VisibilityFlags ( ) const
visibility flags
Implements Visual.
◆ Wireframe()
template<class T >
bool Wireframe ( ) const
Implements Visual.
◆ boundingBox
template<class T >
◆ material
template<class T >
◆ visibilityFlags
template<class T >
◆ wireframe
template<class T >
