Base implementation of a joint visual. More...
#include <BaseJointVisual.hh>
virtual ~BaseJointVisual ()
 Get the arrow visual which represents the axis attached to the child.
virtual gz::math::Vector3d Axis () const override
 Get axis vector.
virtual gz::math::Vector3d ParentAxis () const override
 Get parent axis vector.
 Get the JointVisual which is attached to the parent.
virtual void SetAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
 Create an axis and attach it to the joint visual.
virtual void SetParentAxis (const gz::math::Vector3d &_axis, const std::string &_parentName, bool _useParentFrame) override
 Create a parent axis for hinge2 and universal joint types and attach it to the joint visual.
 Set type for joint visual.
 Get joint visual type.
virtual bool UpdateAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
 Update an axis' arrow visual.
virtual bool UpdateParentAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
 Update the parent axis' arrow visual if it exists.
virtual ~JointVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseJointVisual ()
void CreateAxis ()
 Helper function to create axis visual.
void CreateParentAxis ()
 Helper function to create parent axis visual.
void ScaleToChild ()
 Scale the joint visual according to the joint's child.
void UpdateAxisImpl (ArrowVisualPtr _arrowVisual, const gz::math::Vector3d &_axis, bool _useParentFrame)
 Implementation for updating an axis' arrow visual.
ArrowVisualPtr arrowVisual = nullptr
 The visual representing the one joint axis. There can be only one axis visual per joint visual, so joints with two axes have a 2nd JointVisual with its own arrowVisual.
gz::math::Vector3d axis
 Joint visual axis vector.
AxisVisualPtr axisVisual = nullptr
 The joint's XYZ frame visual.
bool dirtyAxis = false
 Flag to indicate axis data has changed.
bool dirtyJointType = false
 Flag to indicate joint visual type has changed.
bool dirtyParentAxis = false
 Flag to indicate parent axis data has changed.
std::string jointParentName = ""
 Joint parent name.
 Type of joint visualization.
gz::math::Vector3d parentAxis
 Parent axis vector.
bool parentAxisUseParentFrame = false
 Flag to indicate whether parent axis vector is expressed in joint parent frame.
JointVisualPtr parentAxisVis = nullptr
 Second joint visual for hinge2 and universal joints. It is a simplified visual without an XYZ frame.
gz::math::Vector3d scaleToChild
 Scale based on the size of the joint's child.
bool updateAxis = false
 Flag to update the axis visual.
bool updateParentAxis = false
 Flag to update the parent axis visual.
bool useParentFrame = false
 Flag to indicate whether axis vector is expressed in joint parent frame.
template<class T>
class gz::rendering::BaseJointVisual< T >
◆ BaseJointVisual()
template<class T >
BaseJointVisual ( )
◆ ~BaseJointVisual()
template<class T >
~BaseJointVisual ( )
◆ ArrowVisual()
template<class T >
ArrowVisualPtr ArrowVisual ( ) const
Arrow visual.
Implements JointVisual.
◆ Axis()
template<class T >
gz::math::Vector3d Axis ( ) const
Get axis vector.
The axis vector.
◆ CreateAxis()
template<class T >
void CreateAxis ( )
References Scene::CreateArrowVisual().
◆ CreateParentAxis()
template<class T >
void CreateParentAxis ( )
References Scene::CreateJointVisual(), gzlog, and Scene::NodeByName().
template<class T >
void Destroy ( )
template<class T >
void Init ( )
◆ ParentAxis()
template<class T >
gz::math::Vector3d ParentAxis ( ) const
The parent axis vector.
◆ ParentAxisVisual()
template<class T >
JointVisualPtr ParentAxisVisual ( ) const
Parent axis visual.
template<class T >
void PreRender ( )
◆ ScaleToChild()
template<class T >
void ScaleToChild ( )
References std::dynamic_pointer_cast(), and std::max().
◆ SetAxis()
template<class T >
void SetAxis ( const gz::math::Vector3d &  _axis,
[in]_axisAxis vector.
[in]_useParentFrameTrue if axis vector is expressed in parent frame.
◆ SetParentAxis()
template<class T >
void SetParentAxis ( const gz::math::Vector3d &  _axis,
const std::string &  _parentName,
[in]_parentNameJoint parent name.
References gzlog, gz::rendering::JVT_REVOLUTE2, and gz::rendering::JVT_UNIVERSAL.
◆ SetType()
template<class T >
void SetType ( const JointVisualType  _type)
[in]_typeThe type of visualisation for joint.
◆ SetVisible()
template<class T >
Implements Visual.
References gz::rendering::JVT_REVOLUTE2, gz::rendering::JVT_UNIVERSAL, and Visual::SetVisible().
◆ Type()
template<class T >
JointVisualType Type ( ) const
The joint visual type.
◆ UpdateAxis()
template<class T >
bool UpdateAxis ( const gz::math::Vector3d &  _axis,
True if axis was updated else false.
◆ UpdateAxisImpl()
template<class T >
void UpdateAxisImpl ( ArrowVisualPtr  _arrowVisual,
◆ UpdateParentAxis()
template<class T >
bool UpdateParentAxis ( const gz::math::Vector3d &  _axis,
True if parent axis was updated else false.
◆ arrowVisual
template<class T >
◆ axis
template<class T >
Initial value:
◆ axisVisual
template<class T >
◆ dirtyAxis
template<class T >
◆ dirtyJointType
template<class T >
◆ dirtyParentAxis
template<class T >
◆ jointParentName
template<class T >
Joint parent name.
◆ jointVisualType
template<class T >
Initial value:
◆ parentAxis
template<class T >
Initial value:
Parent axis vector.
◆ parentAxisUseParentFrame
template<class T >
◆ parentAxisVis
template<class T >
◆ scaleToChild
template<class T >
Initial value:
◆ updateAxis
template<class T >
◆ updateParentAxis
template<class T >
◆ useParentFrame
template<class T >
