Visual Class Referenceabstract
Represents a visual node in a scene graph. A Visual is the only node that can have Geometry and other Visual children. More...
#include <gz/rendering/Visual.hh>
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~Visual()
virtual ~Visual ( )
◆ AddGeometry()
virtual void AddGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be added
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, and BaseVisual< OgreNode >.
◆ AddVisibilityFlags()
virtual void AddVisibilityFlags ( uint32_t  _flags)
[in]_flagsVisibility flags
◆ BoundingBox()
virtual gz::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, BaseVisual< OgreNode >, OgreVisual, and Ogre2Visual.
◆ Clone()
virtual VisualPtr Clone ( const std::string &  _name,
NodePtr  _newParent
) const
[in]_nameName of the cloned Visual. Set this to an empty string to auto-generate a unique name for the cloned visual.
[in]_newParentParent of the cloned Visual. Set to nullptr if the cloned visual should have no parent.
The visual. nullptr is returned if cloning failed.
◆ GeometryByIndex()
virtual GeometryPtr GeometryByIndex ( unsigned int  _index) const
[in]_indexIndex of the desired geometry
The specified geometry
◆ GeometryCount()
virtual unsigned int GeometryCount ( ) const
The number of geometries attached to this visual
◆ HasGeometry()
virtual bool HasGeometry ( ConstGeometryPtr  _geometry) const
[in]_geometryGeometry in question
True if given node is attached to this visual
◆ LocalBoundingBox()
virtual gz::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
Implemented in BaseParticleEmitter< T >, BaseParticleEmitter< Ogre2Visual >, BaseParticleEmitter< OgreVisual >, BaseVisual< T >, BaseVisual< Ogre2Node >, BaseVisual< OgreNode >, OgreCOMVisual, OgreInertiaVisual, OgreLightVisual, Ogre2COMVisual, Ogre2InertiaVisual, and Ogre2LightVisual.
◆ RemoveGeometries()
virtual void RemoveGeometries ( )
◆ RemoveGeometry()
virtual GeometryPtr RemoveGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be removed
The removed geometry
◆ RemoveGeometryByIndex()
virtual GeometryPtr RemoveGeometryByIndex ( unsigned int  _index)
[in]_indexIndex of the geometry to be removed
◆ RemoveVisibilityFlags()
virtual void RemoveVisibilityFlags ( uint32_t  _flags)
◆ SetChildMaterial()
virtual void SetChildMaterial ( MaterialPtr  _material,
bool  _unique = true
◆ SetGeometryMaterial()
virtual void SetGeometryMaterial ( MaterialPtr  _material,
bool  _unique = true
◆ SetMaterial() [1/2]
bool  _unique = true
[in]_nameName of the material to be assigned
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in OgreCOMVisual, OgreInertiaVisual, OgreLightVisual, Ogre2COMVisual, Ogre2InertiaVisual, Ogre2LightVisual, BaseParticleEmitter< T >, BaseParticleEmitter< Ogre2Visual >, BaseParticleEmitter< OgreVisual >, BaseVisual< T >, BaseVisual< Ogre2Node >, BaseVisual< OgreNode >, and Ogre2ParticleEmitter.
◆ SetStatic()
virtual void SetStatic ( bool  _static)
Remarks
Performance impact of switching staticness depends on on engine. In ogre2 it isn't expensive but it isn't free either. Try to minimize transitions. Raytracing engines may rely on this information for their BVH structures TODO(anyone): Staticness should be ideally be supplied during construction for maximum performance
ogre2 specific: OgreNext keeps 2 lists of objects. Dynamic and Static. Every frame OgreNext iterates through all nodes & items in the dynamic lists and forcefully updates them (regardless of whether they have actually changed). This may sound slow but Ogre 1.x worked by only updating those objects that have changed, and it was slower. CPUs care a lot more about processing in bulk and having all the data hot in cache.
For the static list, it only iterates through the entire list in that frame when the whole list is tagged as dirty. If one element changes, then the whole list is dirty (OgreNext might be able to optimize it and only update a part of the list by narrowing).
Changing a static node transform implies calling OgreNext's notifyStaticDirty. This is very cheap so it can be called whenever a static object changes. The only thing that needs to be taken into account is that notifyStaticDirty should be called as little as possible. And by "as little as possible" that means ideally it should not be called ever except when loading a scene or when something relevant changed. If it gets called e.g. once per frame or more then it's the same as having all objects dynamic.
Thus if an object is static, make sure you don't keep moving around because it negates the performance of all static objects.
Remarks
(INTERNAL) For implementations: Dynamic Scene Node + Dynamic MovableObject = Valid Static Scene Node + Static MovableObject = Valid Static Scene Node + Dynamic MovableObject = Valid, but rarely makes sense Dynamic Scene Node + Static MovableObject = Invalid
[in]_staticTrue if this visual should be made static
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, BaseVisual< OgreNode >, and Ogre2Visual.
◆ SetVisibilityFlags()
◆ SetVisible()
◆ SetWireframe()
◆ Static()
virtual bool Static ( ) const
True if the visual is static, false otherwise
SetStatic
◆ VisibilityFlags()
virtual uint32_t VisibilityFlags ( ) const
visibility flags
◆ Wireframe()
