Ogre 2.x implementation of a Frustum Visual. More...
#include <Ogre2FrustumVisual.hh>
virtual ~Ogre2FrustumVisual ()
 Initialize the visual.
 Update the Visual.
- Public Member Functions inherited from BaseFrustumVisual< Ogre2Visual >
virtual ~BaseFrustumVisual ()
 Get the aspect ratio, which is the width divided by height of the near or far planes.
 Create predefined materials for lidar visual.
 Get the far distance. This is the distance from the frustum's vertex to the farthest plane.
 Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle.
 Get the near distance. This is the distance from the frustum's vertex to the closest plane.
virtual gz::math::Planed Plane (const FrustumVisualPlane _plane) const override
 Get a plane of the frustum.
virtual void SetAspectRatio (double _aspectRatio) override
 Set the aspect ratio, which is the width divided by height of the near or far planes.
virtual void SetFarClipPlane (double _far) override
 Set the far distance. This is the distance from the frustum's vertex to the farthest plane.
 Set the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle.
virtual void SetNearClipPlane (double _near) override
 Set the near distance. This is the distance from the frustum's vertex to the closest plane.
- Public Member Functions inherited from FrustumVisual
virtual ~FrustumVisual ()
virtual ~Ogre2Visual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
- Protected Member Functions inherited from BaseFrustumVisual< Ogre2Visual >
- Protected Member Functions inherited from FrustumVisual
 FrustumVisual ()
 Default constructor. With the following default values:
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node.
- Protected Attributes inherited from BaseFrustumVisual< Ogre2Visual >
double aspectRatio
 aspect ratio value
double farClip
 far value
gz::math::Angle hfov
 fov value
double nearClip
 near value
std::array< gz::math::Planed, 6 > planes
 array of plane
gz::math::Pose3d pose
 pose of visual
 Pointer to the attached geometries.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2FrustumVisual()
Ogre2FrustumVisual ( )
◆ ~Ogre2FrustumVisual()
virtual ~Ogre2FrustumVisual ( )
Reimplemented from BaseFrustumVisual< Ogre2Visual >.
◆ SetVisible()
Implements Visual.
virtual void Update ( )
Update the Visual.
