FrustumVisual Class Referenceabstract
Mathematical representation of a frustum and related functions. This is also known as a view frustum. More...
#include <FrustumVisual.hh>
virtual ~FrustumVisual ()
 Get the aspect ratio, which is the width divided by height of the near or far planes.
 Get the far distance. This is the distance from the frustum's vertex to the farthest plane.
virtual gz::math::Angle HFOV () const =0
 Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle.
 Get the near distance. This is the distance from the frustum's vertex to the closest plane.
virtual gz::math::Planed Plane (const FrustumVisualPlane _plane) const =0
 Get a plane of the frustum.
virtual void SetAspectRatio (double _aspectRatio)=0
 Set the aspect ratio, which is the width divided by height of the near or far planes.
virtual void SetFarClipPlane (double _far)=0
 Set the far distance. This is the distance from the frustum's vertex to the farthest plane.
virtual void SetHFOV (const gz::math::Angle &_hfov)=0
 Set the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle.
virtual void SetNearClipPlane (double _near)=0
 Set the near distance. This is the distance from the frustum's vertex to the closest plane.
virtual void Update ()=0
 Update the Visual.
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 FrustumVisual ()
 Default constructor. With the following default values:
◆ FrustumVisual()
FrustumVisual ( )
  • near: 0.0
  • far: 1.0
  • hfov: 0.78539 radians (45 degrees)
  • aspect ratio: 1.0
  • pose: Pose3d::Zero
◆ ~FrustumVisual()
virtual ~FrustumVisual ( )
◆ AspectRatio()
The frustum's aspect ratio.
SetAspectRatio
Implemented in BaseFrustumVisual< T >, BaseFrustumVisual< Ogre2Visual >, and BaseFrustumVisual< OgreVisual >.
◆ FarClipPlane()
virtual double FarClipPlane ( ) const
Far distance.
SetFarClipPlane
◆ HFOV()
virtual gz::math::Angle HFOV ( ) const
The field of view.
SetHFOV
◆ NearClipPlane()
virtual double NearClipPlane ( ) const
Near distance.
SetNearClipPlane
◆ Plane()
virtual gz::math::Planed Plane ( const FrustumVisualPlane  _plane) const
[in]_planeThe plane to return.
Plane of the frustum.
◆ SetAspectRatio()
virtual void SetAspectRatio ( double  _aspectRatio)
[in]_aspectRatioThe frustum's aspect ratio.
AspectRatio
◆ SetFarClipPlane()
virtual void SetFarClipPlane ( double  _far)
[in]_farFar distance.
FarClipPlane
◆ SetHFOV()
virtual void SetHFOV ( const gz::math::Angle &  _hfov)
[in]_hfovThe field of view.
HFOV
◆ SetNearClipPlane()
virtual void SetNearClipPlane ( double  _near)
[in]_nearNear distance.
NearClipPlane
