BaseFrustumVisual< T > Class Template Reference
Base implementation of a Frustum Visual. More...
#include <BaseFrustumVisual.hh>
virtual ~BaseFrustumVisual ()
 Get the aspect ratio, which is the width divided by height of the near or far planes.
 Create predefined materials for lidar visual.
 Get the far distance. This is the distance from the frustum's vertex to the farthest plane.
 Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle.
 Get the near distance. This is the distance from the frustum's vertex to the closest plane.
virtual gz::math::Planed Plane (const FrustumVisualPlane _plane) const override
 Get a plane of the frustum.
virtual void SetAspectRatio (double _aspectRatio) override
 Set the aspect ratio, which is the width divided by height of the near or far planes.
virtual void SetFarClipPlane (double _far) override
 Set the far distance. This is the distance from the frustum's vertex to the farthest plane.
 Set the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle.
virtual void SetNearClipPlane (double _near) override
 Set the near distance. This is the distance from the frustum's vertex to the closest plane.
 Update the Visual.
- Public Member Functions inherited from FrustumVisual
virtual ~FrustumVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
- Protected Member Functions inherited from FrustumVisual
 FrustumVisual ()
 Default constructor. With the following default values:
double aspectRatio = 1.0
 aspect ratio value
double farClip = 1.0
 far value
gz::math::Angle hfov = gz::math::Angle(0.78539)
 fov value
double nearClip = 0.0
 near value
std::array< gz::math::Planed, 6 > planes
 array of plane
gz::math::Pose3d pose = gz::math::Pose3d::Zero
 pose of visual
template<class T>
class gz::rendering::BaseFrustumVisual< T >
◆ BaseFrustumVisual()
template<class T >
BaseFrustumVisual ( )
◆ ~BaseFrustumVisual()
template<class T >
~BaseFrustumVisual ( )
◆ AspectRatio()
template<class T >
double AspectRatio ( ) const
The frustum's aspect ratio.
SetAspectRatio
Implements FrustumVisual.
◆ CreateMaterials()
template<class T >
void CreateMaterials ( )
References Scene::CreateMaterial().
template<class T >
void Destroy ( )
Reimplemented in OgreFrustumVisual, and Ogre2FrustumVisual.
◆ FarClipPlane()
template<class T >
double FarClipPlane ( ) const
Far distance.
SetFarClipPlane
◆ HFOV()
template<class T >
gz::math::Angle HFOV ( ) const
The field of view.
SetHFOV
template<class T >
void Init ( )
◆ NearClipPlane()
template<class T >
Near distance.
SetNearClipPlane
◆ Plane()
template<class T >
gz::math::Planed Plane ( const FrustumVisualPlane  _plane) const
[in]_planeThe plane to return.
Plane of the frustum.
template<class T >
void PreRender ( )
◆ SetAspectRatio()
template<class T >
void SetAspectRatio ( double  _aspectRatio)
[in]_aspectRatioThe frustum's aspect ratio.
AspectRatio
◆ SetFarClipPlane()
template<class T >
void SetFarClipPlane ( double  _far)
[in]_farFar distance.
FarClipPlane
◆ SetHFOV()
template<class T >
void SetHFOV ( const math::Angle &  _hfov)
[in]_hfovThe field of view.
HFOV
◆ SetNearClipPlane()
template<class T >
void SetNearClipPlane ( double  _near)
[in]_nearNear distance.
NearClipPlane
template<class T >
void Update ( )
Update the Visual.
◆ aspectRatio
template<class T >
aspect ratio value
◆ farClip
template<class T >
far value
◆ hfov
template<class T >
fov value
◆ nearClip
template<class T >
near value
◆ planes
template<class T >
std::array<gz::math::Planed, 6> planes
array of plane
◆ pose
template<class T >
pose of visual
