#include <BaseNode.hh>
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
virtual bool AttachChild (NodePtr _child)=0
virtual NodeStorePtr Children () const =0
virtual bool DetachChild (NodePtr _child)=0
virtual math::Pose3d RawLocalPose () const =0
virtual void SetLocalScaleImpl (const math::Vector3d &_scale)=0
virtual void SetRawLocalPose (const math::Pose3d &_pose)=0
bool initialLocalPoseSet = false
◆ BaseNode()
template<class T >
BaseNode ( )
◆ ~BaseNode()
template<class T >
~BaseNode ( )
◆ AddChild()
template<class T >
void AddChild ( NodePtr  _child)
[in]_childChild node to be added
Implements Node.
References std::endl(), and gzerr.
◆ AttachChild()
template<class T >
protectedpure virtual
Implemented in OgreNode, and Ogre2Node.
◆ ChildById()
template<class T >
NodePtr ChildById ( unsigned int  _id) const
[in]_idID of the desired node
The specified node
Implements Node.
◆ ChildByIndex()
template<class T >
NodePtr ChildByIndex ( unsigned int  _index) const
The specified node
Implements Node.
◆ ChildByName()
template<class T >
NodePtr ChildByName ( const std::string &  _name) const
The specified node
Implements Node.
◆ ChildCount()
template<class T >
unsigned int ChildCount ( ) const
The number of child nodes
Implements Node.
◆ Children()
template<class T >
virtual NodeStorePtr Children ( ) const
◆ DetachChild()
template<class T >
virtual bool DetachChild ( NodePtr  _child)
◆ HasChild()
template<class T >
bool HasChild ( ConstNodePtr  _child) const
True if given node is an attached child
Implements Node.
◆ HasChildId()
template<class T >
bool HasChildId ( unsigned int  _id) const
True if node with given ID is an attached child
Implements Node.
◆ HasChildName()
template<class T >
bool HasChildName ( const std::string &  _name) const
True if node with given name is an attached child
Implements Node.
◆ HasUserData()
template<class T >
bool HasUserData ( const std::string &  _key) const
[in]_keyUnique key
True if node has custom data with the specified key
Implements Node.
◆ InheritScale()
template<class T >
overridepure virtual
Implements Node.
◆ InitialLocalPose()
template<class T >
math::Pose3d InitialLocalPose ( ) const
The initial local pose
Implements Node.
◆ LocalPose()
template<class T >
math::Pose3d LocalPose ( ) const
Get the local pose.
The local pose
Implements Node.
Reimplemented in BaseVisual< Ogre2Node >, and BaseVisual< OgreNode >.
References Pose3< typename T >::Pos(), and Pose3< typename T >::Rot().
◆ LocalPosition()
template<class T >
math::Vector3d LocalPosition ( ) const
The local position
Implements Node.
◆ LocalRotation()
template<class T >
math::Quaterniond LocalRotation ( ) const
The local rotation
Implements Node.
◆ LocalScale()
template<class T >
The local scale
Implements Node.
Implemented in BaseAxisVisual< Ogre2Visual >, BaseAxisVisual< OgreVisual >, OgreNode, and Ogre2Node.
◆ Origin()
template<class T >
math::Vector3d Origin ( ) const
The position of the origin
Implements Node.
◆ Parent()
template<class T >
the parent Node
Implements Node.
◆ PreRenderChildren()
template<class T >
void PreRenderChildren ( )
◆ RawLocalPose()
template<class T >
◆ RemoveChild()
template<class T >
NodePtr RemoveChild ( NodePtr  _child)
[in]_childChild node to be removed
The removed child node
Implements Node.
◆ RemoveChildById()
template<class T >
NodePtr RemoveChildById ( unsigned int  _id)
[in]_idID of the child node to be removed
Implements Node.
◆ RemoveChildByIndex()
template<class T >
NodePtr RemoveChildByIndex ( unsigned int  _index)
[in]_indexIndex of the child node to be removed
Implements Node.
◆ RemoveChildByName()
template<class T >
NodePtr RemoveChildByName ( const std::string &  _name)
[in]_nameName of the child node to be removed
Implements Node.
◆ RemoveChildren()
template<class T >
void RemoveChildren ( )
Implements Node.
◆ RemoveParent()
template<class T >
void RemoveParent ( )
Implements Node.
References std::dynamic_pointer_cast().
◆ Scale() [1/3]
template<class T >
void Scale ( const math::Vector3d &  _scale)
[in]_scaleScalars to alter the current scale
Implements Node.
◆ Scale() [2/3]
template<class T >
void Scale ( double  _scale)
[in]_scaleScalar to alter the current scale
Implements Node.
◆ Scale() [3/3]
template<class T >
void Scale ( double  _x,
double  _y,
double  _z
[in]_xScalar to alter the current x-coordinate scale
[in]_yScalar to alter the current y-coordinate scale
[in]_zScalar to alter the current z-coordinate scale
Implements Node.
◆ SetLocalPose()
template<class T >
void SetLocalPose ( const math::Pose3d &  _pose)
Set the local pose.
[in]_poseNew local pose
Implements Node.
References std::endl(), gzerr, Pose3< typename T >::IsFinite(), Pose3< typename T >::Pos(), and Pose3< typename T >::Rot().
◆ SetLocalPosition() [1/2]
template<class T >
void SetLocalPosition ( const math::Vector3d &  _position)
[in]_positionNew local position
Implements Node.
Reimplemented in Ogre2Light.
References std::endl(), gzerr, Vector3< typename T >::IsFinite(), and Pose3< typename T >::Pos().
◆ SetLocalPosition() [2/2]
template<class T >
void SetLocalPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
◆ SetLocalRotation() [1/3]
template<class T >
void SetLocalRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew local rotation
Implements Node.
References std::endl(), gzerr, Quaternion< typename T >::IsFinite(), and Pose3< typename T >::Rot().
◆ SetLocalRotation() [2/3]
template<class T >
void SetLocalRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
Implements Node.
◆ SetLocalRotation() [3/3]
template<class T >
void SetLocalRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
◆ SetLocalScale() [1/3]
template<class T >
[in]_scaleNew local scale
Implements Node.
Reimplemented in BaseAxisVisual< Ogre2Visual >, and BaseAxisVisual< OgreVisual >.
◆ SetLocalScale() [2/3]
template<class T >
void SetLocalScale ( double  _scale)
Implements Node.
◆ SetLocalScale() [3/3]
template<class T >
void SetLocalScale ( double  _x,
double  _y,
double  _z
[in]_xNew x-coordinate scale
[in]_yNew y-coordinate scale
[in]_zNew z-coordinate scale
Implements Node.
◆ SetLocalScaleImpl()
template<class T >
◆ SetOrigin() [1/2]
template<class T >
void SetOrigin ( const math::Vector3d &  _origin)
[in]_originNew origin position
Implements Node.
References std::endl(), gzerr, and Vector3< typename T >::IsFinite().
◆ SetOrigin() [2/2]
template<class T >
void SetOrigin ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
◆ SetRawLocalPose()
template<class T >
virtual void SetRawLocalPose ( const math::Pose3d &  _pose)
◆ SetUserData()
template<class T >
void SetUserData ( const std::string &  _key,
Variant  _value
[in]_keyUnique key
[in]_valueValue in any type
Implements Node.
◆ SetWorldPose()
template<class T >
void SetWorldPose ( const math::Pose3d &  _pose)
Set the world pose.
[in]_poseNew world pose
Implements Node.
◆ SetWorldPosition() [1/2]
template<class T >
void SetWorldPosition ( const math::Vector3d &  _position)
[in]_positionNew world position
Implements Node.
References Pose3< typename T >::Pos().
◆ SetWorldPosition() [2/2]
template<class T >
void SetWorldPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
◆ SetWorldRotation() [1/3]
template<class T >
void SetWorldRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew world rotation
Implements Node.
References Pose3< typename T >::Rot().
◆ SetWorldRotation() [2/3]
template<class T >
void SetWorldRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
Implements Node.
◆ SetWorldRotation() [3/3]
template<class T >
void SetWorldRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
◆ SetWorldScale() [1/3]
template<class T >
void SetWorldScale ( const math::Vector3d &  _scale)
[in]_scaleNew world scale
Implements Node.
References Vector3< typename T >::One.
◆ SetWorldScale() [2/3]
template<class T >
void SetWorldScale ( double  _scale)
Implements Node.
◆ SetWorldScale() [3/3]
template<class T >
void SetWorldScale ( double  _x,
double  _y,
double  _z
Implements Node.
◆ UserData()
template<class T >
Variant UserData ( const std::string &  _key) const
[in]_keyUnique key
Value in any type. If _key does not exist for the node, an empty variant is returned (i.e., no data).
Implements Node.
◆ WorldPose()
template<class T >
Get the world pose.
The world pose
Implements Node.
◆ WorldPosition()
template<class T >
math::Vector3d WorldPosition ( ) const
The world position
Implements Node.
◆ WorldRotation()
template<class T >
math::Quaterniond WorldRotation ( ) const
The world rotation
Implements Node.
◆ WorldScale()
template<class T >
math::Vector3d WorldScale ( ) const
The world scale
Implements Node.
◆ WorldToLocal()
template<class T >
math::Pose3d WorldToLocal ( const math::Pose3d &  _pose) const
[in]_poseWorld pose to be converted
Implements Node.
◆ initialLocalPose
template<class T >
Initial value:
◆ initialLocalPoseSet
template<class T >
◆ origin
template<class T >
◆ userData
template<class T >
std::map<std::string, Variant> userData
