Ogre2BoundingBoxCamera Class Reference
BoundingBox camera used to detect 2d / 3d bounding boxes of labeled objects in the scene. More...
#include <Ogre2BoundingBoxCamera.hh>
virtual ~Ogre2BoundingBoxCamera ()
virtual const std::vector< BoundingBox > & BoundingBoxData () const override
 Get the BoundingBox data.
void BoundingBoxes3D ()
 Compute the 3D bounding boxes.
virtual common::ConnectionPtr ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)>) override
 Connect to the new BoundingBox info.
void ConvertToScreenCoord (Ogre::Vector3 &_minVertex, Ogre::Vector3 &_maxVertex) const
 Convert from clip coord (after projection) to screen coord.
void CreateBoundingBoxTexture ()
 Create texture to hold ogre Ids to calculate the boundaries of each ogre id mask.
void CreateRenderTexture ()
 Create dummy render texture. Needed to satisfy inheritance and to set image's dims.
 Destroy the camera.
virtual void DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const override
 Draw a bounding box on the given image.
void DrawLine (unsigned char *_data, const math::Vector2i &_point1, const math::Vector2i &_point2, const math::Color &_color) const
 Draw line between any 2 points in the image data buffer Algorithm: https://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm.
void FullBoundingBoxes ()
 Compute the full bounding boxes by projecting all mesh vertices of each object, then get the min & max of x & y to get the full bbox. Check the visibility by looping over pixels of the ogre Ids map.
 Initialize the camera.
void MarkVisibleBoxes ()
 Mark the visible boxes by checking the ogre ids map and mark the ogre id which appears in the map.
void MeshMinimalBox (const Ogre::MeshPtr _mesh, const Ogre::Matrix4 &_viewMatrix, const Ogre::Matrix4 &_projMatrix, Ogre::Vector3 &_minVertex, Ogre::Vector3 &_maxVertex, const Ogre::Vector3 &_position, const Ogre::Quaternion &_orientation, const Ogre::Vector3 &_scale)
 Get minimal bounding box of the mesh by projecting the 3d vertices of the vertex buffer to 2d, then get the min & max of x & y.
virtual void SetBoundingBoxType (BoundingBoxType _type) override
 Set BoundingBox Type (Visible / Full)
virtual BoundingBoxType Type () const override
 Get the BoundingBox Type (Visible / Full)
void VisibleBoundingBoxes ()
 Compute the visible bounding boxes by looping over pixels of the ogre Ids map, to get the boundaries of each unique ogre Id mask.
- Public Member Functions inherited from BaseBoundingBoxCamera< Ogre2Sensor >
 ~BaseBoundingBoxCamera () override
- Public Member Functions inherited from BoundingBoxCamera
virtual ~BoundingBoxCamera ()
virtual ~Camera ()
 Sensor.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask.
 Get visibility mask.
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 Get a pointer to the render target.
- Protected Member Functions inherited from BaseBoundingBoxCamera< Ogre2Sensor >
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node.
- Protected Attributes inherited from BaseBoundingBoxCamera< Ogre2Sensor >
std::vector< BoundingBox > boundingBoxes
 The bounding box data.
BoundingBoxType type
 The bounding box type.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
uint32_t visibilityMask
 Camera's visibility mask.
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2BoundingBoxCamera()
Ogre2BoundingBoxCamera ( )
◆ ~Ogre2BoundingBoxCamera()
virtual ~Ogre2BoundingBoxCamera ( )
◆ BoundingBoxData()
virtual const std::vector< BoundingBox > & BoundingBoxData ( ) const
Buffer of bounding boxes info (label, minX, minY, maxX, maxY). If the camera's bounding box type is 3D, minZ and maxZ are also defined)
Reimplemented from BaseBoundingBoxCamera< Ogre2Sensor >.
◆ BoundingBoxes3D()
void BoundingBoxes3D ( )
◆ ConnectNewBoundingBoxes()
virtual common::ConnectionPtr ConnectNewBoundingBoxes ( std::function< void(const std::vector< BoundingBox > &)>  _subscriber)
Implements BaseBoundingBoxCamera< Ogre2Sensor >.
◆ ConvertToScreenCoord()
void ConvertToScreenCoord ( Ogre::Vector3 &  _minVertex,
Ogre::Vector3 &  _maxVertex
) const
[in,out]_minVertexmin vertex in clip coord to screen coord
[in,out]_maxVertexmax vertex in clip coord to screen coord
◆ CreateBoundingBoxTexture()
void CreateBoundingBoxTexture ( )
◆ CreateRenderTexture()
void CreateRenderTexture ( )
Destroy the camera.
◆ DrawBoundingBox()
virtual void DrawBoundingBox ( unsigned char *  _data,
const math::Color &  _color,
const BoundingBox &  _box
) const
[in]_databuffer containing the image data
[in]_colorColor of the bounding box to be drawn
[in]_boxbounding box to be drawn
◆ DrawLine()
void DrawLine ( unsigned char *  _data,
const math::Vector2i &  _point1,
const math::Vector2i &  _point2,
) const
[in]_databuffer contains the image data
[in]_point1The 1st 2D point in screen coordinates
[in]_point2The 2nd 2D point in screen coordinates
[in]_colorThe color of the line
◆ FullBoundingBoxes()
void FullBoundingBoxes ( )
Reimplemented from Ogre2Node.
◆ MarkVisibleBoxes()
void MarkVisibleBoxes ( )
◆ MeshMinimalBox()
void MeshMinimalBox ( const Ogre::MeshPtr  _mesh,
const Ogre::Matrix4 &  _viewMatrix,
const Ogre::Matrix4 &  _projMatrix,
Ogre::Vector3 &  _maxVertex,
const Ogre::Vector3 &  _position,
const Ogre::Quaternion &  _orientation,
const Ogre::Vector3 &  _scale
[in]_meshMesh of the item to get its minimal bbox
[in]_viewMatrixCamera view matrix
[in]_projMatrixCamera projection matrix
[out]_minVertexMinimum of projected x & y & z of the vertices
[out]_maxVertexMaximum of projected x & y & z of the vertices
[in]_positionposition of the item in the world space
[in]_orientationrotation of the item
[in]_scalescale of the item
◆ PostRender()
virtual void PostRender ( )
Implements Camera.
◆ ProjectionMatrix()
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< T >.
◆ SetBoundingBoxType()
virtual void SetBoundingBoxType ( BoundingBoxType  _type)
[in]_typeBoundingBox Type (Visible / Full)
◆ SetProjectionMatrix()
Implements Camera.
◆ Type()
virtual BoundingBoxType Type ( ) const
◆ VisibleBoundingBoxes()
void VisibleBoundingBoxes ( )
