RenderTarget Class Referenceabstract
#include <gz/rendering/RenderTarget.hh>
virtual ~RenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual bool Reinterpretable () const =0
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
◆ ~RenderTarget()
virtual ~RenderTarget ( )
◆ AddRenderPass()
Implemented in BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, BaseRenderTarget< OgreObject >, and Ogre2RenderTexture.
Referenced by BaseCamera< T >::AddRenderPass().
◆ BackgroundColor()
Implemented in BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, BaseRenderTarget< OgreObject >, OgreRenderTarget, and Ogre2RenderTarget.
◆ Copy()
Implemented in OgreRenderTarget, and Ogre2RenderTarget.
Referenced by BaseCamera< T >::Copy().
◆ Format()
virtual PixelFormat Format ( ) const
Render target format
Implemented in BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
Referenced by BaseCamera< T >::ImageFormat().
◆ Height()
virtual unsigned int Height ( ) const
Referenced by BaseCamera< T >::ImageHeight().
◆ PreRender() [1/2]
◆ PreRender() [2/2]
virtual void PreRender ( const CameraPtr &  _camera)
Referenced by BaseCamera< T >::PreRender().
◆ Reinterpretable()
virtual bool Reinterpretable ( ) const
See SetFormat()
True if format is reinterpretable
◆ RemoveAllRenderPasses()
virtual void RemoveAllRenderPasses ( )
◆ RemoveRenderPass()
Referenced by BaseCamera< T >::RemoveRenderPass().
◆ RenderPassByIndex()
Referenced by BaseCamera< T >::RenderPassByIndex().
◆ RenderPassCount()
Referenced by BaseCamera< T >::RenderPassCount().
◆ SetFormat()
virtual void SetFormat ( PixelFormat  _format,
bool  _reinterpretable = false
[in]_formatNew target format
[in]_reinterpretablewhether the RenderTarget will be reinterpreted to another format (e.g. from RGBA8_UNORM to/from RGBA8_UNORM_SRGB)
Referenced by BaseCamera< T >::SetImageFormat().
◆ SetHeight()
virtual void SetHeight ( const unsigned int  _height)
Referenced by BaseCamera< T >::SetImageHeight().
◆ SetWidth()
virtual void SetWidth ( const unsigned int  _width)
Referenced by BaseCamera< T >::SetImageWidth().
◆ Width()
virtual unsigned int Width ( ) const
Referenced by BaseCamera< T >::ImageWidth().
