virtual ~OgreRenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual void Destroy () override=0
virtual void Render ()
virtual Ogre::RenderTarget * RenderTarget () const =0
 Set a material to render on every object. This method is used for special cases like the render target of a depth camera.
 Set visibility mask for the viewport associated with this render target.
 BaseRenderTarget ()
 ~BaseRenderTarget () override
virtual bool Reinterpretable () const override
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false) override
virtual ~RenderTarget ()
 OgreRenderTarget ()
void RebuildMaterial ()
 Re-initializes render target material to apply a material to everything in the scene. Does nothing if no material has been set.
virtual void RebuildTarget ()=0
 Update render pass chain if changes were made.
virtual void Rebuild ()
virtual void Init ()
unsigned int antiAliasing = 4
bool colorDirty = true
 a material used by for the render target
 Helper class that applies the material to the render target.
 visibility mask associated with this render target
PixelFormat format
unsigned int height
bool reinterpretable
bool renderPassDirty
 Flag to indicate if render pass need to be rebuilt.
 A chain of render passes applied to the render target.
bool targetDirty
unsigned int width
◆ OgreRenderTarget()
OgreRenderTarget ( )
◆ ~OgreRenderTarget()
virtual ~OgreRenderTarget ( )
◆ AddViewport()
Ogre::Viewport * AddViewport ( Ogre::Camera *  _viewport)
◆ AntiAliasing()
◆ BackgroundColor()
Reimplemented from BaseRenderTarget< OgreObject >.
◆ Camera()
virtual Ogre::Camera * Camera ( ) const
◆ Copy()
Implements RenderTarget.
overridepure virtual
Implemented in OgreRenderWindow, and OgreRenderTexture.
◆ PostRender()
virtual void PostRender ( )
Reimplemented in OgreRenderTexture.
◆ RebuildImpl()
virtual void RebuildImpl ( )
◆ RebuildMaterial()
void RebuildMaterial ( )
OgreRenderTarget::RebuildImpl()
BaseRenderTarget::Rebuild()
◆ RebuildTarget()
protectedpure virtual
◆ RebuildViewport()
virtual void RebuildViewport ( )
◆ Render()
virtual void Render ( )
◆ RenderTarget()
virtual Ogre::RenderTarget * RenderTarget ( ) const
◆ SetAntiAliasing()
virtual void SetAntiAliasing ( unsigned int  _aa)
◆ SetAutoUpdated()
void SetAutoUpdated ( const bool  _value)
◆ SetBackgroundColor()
virtual void SetBackgroundColor ( math::Color  _color)
◆ SetCamera()
virtual void SetCamera ( Ogre::Camera *  _camera)
◆ SetMaterial()
void SetMaterial ( MaterialPtr  _material)
[in]_materialThe material to render
◆ SetUpdate()
void SetUpdate ( const bool  _value)
◆ SetVisibilityMask()
[in]_maskVisibility mask
◆ UpdateBackgroundColor()
virtual void UpdateBackgroundColor ( )
◆ UpdateRenderPassChain()
virtual void UpdateRenderPassChain ( )
◆ Viewport()
Ogre::Viewport * Viewport ( const int  _viewportId) const
◆ antiAliasing
◆ colorDirty
◆ material
◆ materialApplicator
◆ ogreBackgroundColor
◆ ogreCamera
◆ ogreViewport
Ogre::Viewport* ogreViewport = nullptr
◆ visibilityMask
