virtual ~OgreRenderWindow ()
virtual void Destroy ()
- Public Member Functions inherited from BaseRenderWindow< OgreRenderTarget >
 BaseRenderWindow ()
 ~BaseRenderWindow () override
double DevicePixelRatio () const override
 Get the device to pixel ratio.
std::string Handle () const override
 Get the window handle that the render window is attached to.
void OnMove () override
 Alert the window of a window move event.
void OnResize (const unsigned int _width, const unsigned int _height) override
 Alert the window of a window resize event.
void SetDevicePixelRatio (const double _ratio) override
 Set the device to pixel ratio.
void SetHandle (const std::string &_handle) override
 Set the window handle to attach the render window to.
- Public Member Functions inherited from RenderWindow
virtual ~RenderWindow ()
virtual ~RenderTarget ()
- Public Member Functions inherited from OgreRenderTarget
virtual ~OgreRenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual void Render ()
 Set a material to render on every object. This method is used for special cases like the render target of a depth camera.
 Set visibility mask for the viewport associated with this render target.
 BaseRenderTarget ()
 ~BaseRenderTarget () override
virtual bool Reinterpretable () const override
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false) override
 OgreRenderWindow ()
virtual void BuildTarget ()
virtual void RebuildTarget ()
virtual Ogre::RenderTarget * RenderTarget () const
- Protected Member Functions inherited from OgreRenderTarget
 OgreRenderTarget ()
void RebuildMaterial ()
 Re-initializes render target material to apply a material to everything in the scene. Does nothing if no material has been set.
 Update render pass chain if changes were made.
virtual void Rebuild ()
virtual void Init ()
Ogre::RenderTarget * ogreRenderWindow = nullptr
- Protected Attributes inherited from BaseRenderWindow< OgreRenderTarget >
std::string handle
double ratio
- Protected Attributes inherited from OgreRenderTarget
unsigned int antiAliasing = 4
bool colorDirty = true
 a material used by for the render target
 Helper class that applies the material to the render target.
 visibility mask associated with this render target
PixelFormat format
unsigned int height
bool reinterpretable
bool renderPassDirty
 Flag to indicate if render pass need to be rebuilt.
 A chain of render passes applied to the render target.
bool targetDirty
unsigned int width
◆ OgreRenderWindow()
OgreRenderWindow ( )
◆ ~OgreRenderWindow()
virtual ~OgreRenderWindow ( )
◆ BuildTarget()
virtual void BuildTarget ( )
◆ RebuildTarget()
Implements OgreRenderTarget.
◆ RenderTarget()
virtual Ogre::RenderTarget * RenderTarget ( ) const
◆ ogreRenderWindow
Ogre::RenderTarget* ogreRenderWindow = nullptr
