BaseRenderWindow< T > Class Template Reference
 BaseRenderWindow ()
 ~BaseRenderWindow () override
double DevicePixelRatio () const override
 Get the device to pixel ratio.
std::string Handle () const override
 Get the window handle that the render window is attached to.
void OnMove () override
 Alert the window of a window move event.
void OnResize (const unsigned int _width, const unsigned int _height) override
 Alert the window of a window resize event.
void SetDevicePixelRatio (const double _ratio) override
 Set the device to pixel ratio.
void SetHandle (const std::string &_handle) override
 Set the window handle to attach the render window to.
- Public Member Functions inherited from RenderWindow
virtual ~RenderWindow ()
virtual ~RenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual bool Reinterpretable () const =0
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
std::string handle
double ratio = 1.0
◆ BaseRenderWindow()
template<class T >
BaseRenderWindow ( )
◆ ~BaseRenderWindow()
template<class T >
~BaseRenderWindow ( )
◆ DevicePixelRatio()
template<class T >
double DevicePixelRatio ( ) const
Device to pixel ratio
Implements RenderWindow.
◆ Handle()
template<class T >
std::string Handle ( ) const
Window handle
◆ OnMove()
template<class T >
void OnMove ( )
◆ OnResize()
template<class T >
void OnResize ( const unsigned int  _width,
[in]_widthNew window width in pixels
[in]_heightNew window height in pixels
◆ SetDevicePixelRatio()
template<class T >
void SetDevicePixelRatio ( const double  _ratio)
[in]_ratioDevice to pixel ratio
◆ SetHandle()
template<class T >
void SetHandle ( const std::string &  _handle)
[in]_handleWindow handle
◆ handle
template<class T >
std::string handle
◆ ratio
template<class T >
double ratio = 1.0
