RenderWindow Class Referenceabstract
Represents a on-screen render-window to which cameras can render images. More...
#include <RenderTarget.hh>
virtual ~RenderWindow ()
virtual double DevicePixelRatio () const =0
 Get the device to pixel ratio.
virtual std::string Handle () const =0
 Get the window handle that the render window is attached to.
virtual void OnMove ()=0
 Alert the window of a window move event.
virtual void OnResize (unsigned int _width, unsigned int _height)=0
 Alert the window of a window resize event.
virtual void SetDevicePixelRatio (const double _ratio)=0
 Set the device to pixel ratio.
virtual void SetHandle (const std::string &_handle)=0
 Set the window handle to attach the render window to.
virtual ~RenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual bool Reinterpretable () const =0
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
◆ ~RenderWindow()
virtual ~RenderWindow ( )
◆ DevicePixelRatio()
virtual double DevicePixelRatio ( ) const
Device to pixel ratio
Implemented in BaseRenderWindow< T >, BaseRenderWindow< Ogre2RenderTarget >, and BaseRenderWindow< OgreRenderTarget >.
◆ Handle()
virtual std::string Handle ( ) const
Window handle
◆ OnMove()
virtual void OnMove ( )
◆ OnResize()
virtual void OnResize ( unsigned int  _width,
[in]_widthNew window width in pixels
[in]_heightNew window height in pixels
◆ SetDevicePixelRatio()
virtual void SetDevicePixelRatio ( const double  _ratio)
[in]_ratioDevice to pixel ratio
◆ SetHandle()
virtual void SetHandle ( const std::string &  _handle)
[in]_handleWindow handle
