BaseRenderTarget< T > Class Template Referenceabstract
 BaseRenderTarget ()
 ~BaseRenderTarget () override
virtual bool Reinterpretable () const override
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false) override
virtual ~RenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual void Rebuild ()
virtual void RebuildImpl ()=0
PixelFormat format = PF_UNKNOWN
unsigned int height = 0u
bool reinterpretable = false
bool renderPassDirty = false
 Flag to indicate if render pass need to be rebuilt.
 A chain of render passes applied to the render target.
bool targetDirty = true
unsigned int width = 0u
◆ BaseRenderTarget()
template<class T >
BaseRenderTarget ( )
◆ ~BaseRenderTarget()
template<class T >
~BaseRenderTarget ( )
◆ AddRenderPass()
template<class T >
Implements RenderTarget.
Reimplemented in Ogre2RenderTexture.
◆ BackgroundColor()
template<class T >
math::Color BackgroundColor ( ) const
Reimplemented in OgreRenderTarget, and Ogre2RenderTarget.
References Scene::BackgroundColor().
◆ Format()
template<class T >
PixelFormat Format ( ) const
Render target format
◆ Height()
template<class T >
unsigned int Height ( ) const
◆ PostRender()
template<class T >
void PostRender ( )
Reimplemented in OgreRenderTarget, OgreRenderTexture, Ogre2RenderTarget, and Ogre2RenderTexture.
◆ PreRender() [1/2]
template<class T >
void PreRender ( )
◆ PreRender() [2/2]
template<class T >
void PreRender ( const CameraPtr &  _camera)
◆ Rebuild()
template<class T >
void Rebuild ( )
◆ RebuildImpl()
template<class T >
virtual void RebuildImpl ( )
protectedpure virtual
Implemented in OgreRenderTarget, and Ogre2RenderTarget.
◆ Reinterpretable()
template<class T >
bool Reinterpretable ( ) const
See SetFormat()
True if format is reinterpretable
◆ RemoveAllRenderPasses()
template<class T >
void RemoveAllRenderPasses ( )
◆ RemoveRenderPass()
template<class T >
References std::find().
◆ RenderPassByIndex()
template<class T >
References std::endl(), and gzerr.
◆ RenderPassCount()
template<class T >
◆ SetFormat()
template<class T >
void SetFormat ( PixelFormat  _format,
bool  _reinterpretable = false
[in]_formatNew target format
[in]_reinterpretablewhether the RenderTarget will be reinterpreted to another format (e.g. from RGBA8_UNORM to/from RGBA8_UNORM_SRGB)
References PixelUtil::Sanitize().
◆ SetHeight()
template<class T >
void SetHeight ( const unsigned int  _height)
◆ SetWidth()
template<class T >
void SetWidth ( const unsigned int  _width)
◆ Width()
template<class T >
unsigned int Width ( ) const
◆ format
template<class T >
◆ height
template<class T >
◆ reinterpretable
template<class T >
◆ renderPassDirty
template<class T >
◆ renderPasses
template<class T >
std::vector<RenderPassPtr> renderPasses
◆ targetDirty
template<class T >
◆ width
template<class T >
