#include <BaseCamera.hh>
| virtual | ~BaseCamera () |
| Add a render pass to the camera. | |
| Get the level of anti-aliasing used during rendering. | |
| Get the camera's aspect ratio. | |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. | |
| Subscribes a new listener to this camera's new frame event. | |
| Writes the last rendered image to the given image buffer. This function can be called multiple times after PostRender has been called, without rendering the scene again. Calling this function before a single image has been rendered will have undefined behavior. | |
| Created an empty image buffer for capturing images. The resulting image will have sufficient memory allocated for subsequent calls to this camera's Capture function. However, any changes to this cameras properties may invalidate the condition. | |
| Create a render window. | |
| Get the camera's far clipping plane distance. | |
| Get the follow offset vector in the frame specified at the time the follow target is set. | |
| Get the camera follow movement P gain. | |
| Get the target node being followed. | |
| Get the camera's horizontal field-of-view. | |
| Get the image pixel format. If the image pixel format has not been set with a valid value, PF_UNKNOWN will be returned. | |
| Get the image height in pixels. | |
| Get the total image memory size in bytes. | |
| Get the image width in pixels. | |
| Get the camera's near clipping plane distance. | |
| Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. | |
| Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. | |
| Prepare this object and any of its children for rendering. This should be called for each object in a scene just before rendering, which can be achieved by a single call to Scene::PreRender. | |
| Project point in 3d world space to 2d screen space. | |
| Get the projection matrix for this camera. | |
| Get the projection type for this camera. | |
| Remove all render passes from the camera. | |
| Remove a render pass from the camera. | |
| Get a render passes by index. | |
| Get the number of render passes applied to the camera. | |
| Get the OpenGL texture id associated with the render texture used by this camera. A valid id is returned only if the underlying render engine is OpenGL based. | |
| Get the Metal texture id associated with the render texture used by this camera. A valid Id is obtained only if the underlying render engine is Metal based. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. | |
| Writes the previously rendered frame to a file. This function can be called multiple times after PostRender has been called, without rendering the scene again. Calling this function before a single image has been rendered will have undefined behavior. | |
| Set the level of anti-aliasing used during rendering. If a value of 0 is given, no anti-aliasing will be performed. Higher values can significantly slow-down rendering times, depending on the underlying render engine. | |
| Set the camera's aspect ratio. This value determines the cameras vertical field-of-view. It is often the. | |
| Set the camera's far clipping plane distance. | |
| Set offset of camera from target node being followed. The offset will be in the frame that is specified at the time the follow target is set. | |
| Set follow P Gain. Determines how fast the camera moves to follow the target node. Valid range: [0-1]. | |
| Set a node for camera to follow. The camera will automatically update its position to keep itself at the specified offset distance from the target being followed. If null is specified, camera follow is disabled. In contrast to SetTrackTarget, the camera does not change its orientation when following is enabled. | |
| Set the camera's horizontal field-of-view. | |
| Set the image pixel format. | |
| Set the image height in pixels. | |
| Set the image width in pixels. | |
| Set a material that the camera should see on all objects. | |
| Set the camera's near clipping plane distance. | |
| Set the projection matrix for this camera. This overrides the standard projection matrix computed based on camera parameters. | |
Set the projection type for this camera This changes the projection matrix of the camera based on the camera projection type. A custom projection matrix can be specified via SetProjectionMatrix to override the provided one. To disable the custom projection matrix, just call this function again with the desired projection type. | |
| Set track offset. Camera will track a point that's at an offset from the target node. The offset will be in the frame that is specified at the time the track target is set. | |
| Set track P Gain. Determines how fast the camera rotates to look at the target node. Valid range: [0-1]. | |
| Set a node for camera to track. The camera will automatically change its orientation to face the target being tracked. If null is specified, tracking is disabled. In contrast to SetFollowTarget the camera does not change its position when tracking is enabled. | |
| Get the track offset vector in the frame specified at the time the track target is set. | |
| Get the camera track rotation P gain. | |
| Get the target node being tracked. | |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. | |
| Get the view matrix for this camera. | |
| Get the visual for a given mouse position param[in] _mousePos mouse position. | |
| virtual | ~Camera () |
| Destructor. | |
| Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns. | |
| Renders the current scene using this camera. This function assumes PreRender() has already been called on the parent Scene, allowing the camera and the scene itself to prepare for rendering. | |
| virtual | ~Sensor () |
| Sensor. | |
| Set visibility mask. | |
| Get visibility mask. | |
| virtual | ~Node () |
| Destructor. | |
| Add the given node to this node. If the given node is already a child, no work will be done. | |
| Get node with given ID. If no child exists with given ID, NULL will be returned. | |
| Get node at given index. If no child exists at given index, NULL will be returned. | |
| Get node with given name. If no child exists with given name, NULL will be returned. | |
| Get number of child nodes. | |
| Determine if given node is an attached child. | |
| Determine if node with given ID is an attached child. | |
| Determine if node with given name is an attached child. | |
| Determine if this Node is attached to another Node. | |
| Check if node has custom data. | |
| Determine if this node inherits scale from this parent. | |
| Get the initial local pose. | |
| Get the local pose. | |
| Get the local position. | |
| Get the local rotation. | |
| Get the local scale. | |
| Get position of origin. | |
| Get the parent Node. | |
| Remove (detach) the given node from this node. If the given node is not a child of this node, no work will be done. | |
| Remove (detach) the node with the given ID from this node. If the specified node is not a child of this node, no work will be done. | |
| Remove (detach) the node at the given index from this node. If the specified node is not a child of this node, no work will be done. | |
| Remove (detach) the node with the given name from this node. If the specified node is not a child of this node, no work will be done. | |
| Remove all child nodes from this node This detaches all the child nodes but does not destroy them. | |
| Detach this Node from its parent. If this Node does not have a parent, no work will be done. | |
| Scale the current scale by the given scalars. | |
| Scale the current scale by the given scalar. The given scalar will be assigned to the x, y, and z coordinates. | |
| Specify if this node inherits scale from its parent. | |
| Set the local pose. | |
| Set the local position. | |
| Set the local rotation. | |
| Set the local scale. | |
| Set the local scale. The given scale will be assigned to the x, y, and z coordinates. | |
| Set position of origin. The position should be relative to the original origin of the geometry. | |
| Store any custom data associated with this node. | |
| Set the world pose. | |
| Set the world position. | |
| Set the world rotation. | |
| Set the world scale. | |
| Set the world scale. The given scale will be assigned to the x, y, and z coordinates. | |
| Get custom data stored in this node. | |
| Get the world pose. | |
| Get the world position. | |
| Get the world rotation. | |
| Get the world scale. | |
| Convert given world pose to local pose. | |
| Destructor. | |
| Destroy any resources associated with this object. Invoking any other functions after destroying an object will result in undefined behavior. | |
| Get the object ID. This ID will be unique across all objects inside a given scene, but necessarily true for objects across different scenes. | |
| Get the object name. This name will be unique across all objects inside a given scene, but necessarily true for objects across different scenes. | |
| Get the Scene that created this object. | |
| BaseCamera () | |
| virtual void * | CreateImageBuffer () const |
| virtual void | Load () override |
| virtual RenderTargetPtr | RenderTarget () const =0 |
| virtual void | Reset () |
Protected Attributes | |
| unsigned int | antiAliasing = 0u |
| Anti-aliasing. | |
| double | aspect = 1.3333333 |
| Aspect ratio. | |
| double | farClip = 1000.0 |
| Far clipping plane distance. | |
| NodePtr | followNode |
| Target node to follow. | |
| math::Vector3d | followOffset |
| Offset distance between camera and target node being followed. | |
| double | followPGain = 1.0 |
| P gain for follow mode. Determines how fast the camera moves to follow the target node. Valid range: [0-1]. | |
| bool | followWorldFrame = false |
| Follow target in world frame. | |
| math::Angle | hfov |
| Horizontal camera field of view. | |
| ImagePtr | imageBuffer |
| double | nearClip = 0.01 |
| Near clipping plane distance. | |
| common::EventT< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> | newFrameEvent |
| math::Matrix4d | projectionMatrix |
| Custom projection matrix. | |
| CameraProjectionType | projectionType = CPT_PERSPECTIVE |
| Camera projection type. | |
| NodePtr | trackNode |
| Target node to track if camera tracking is on. | |
| math::Vector3d | trackOffset |
| Set camera to track a point offset in target node's local or world frame depending on trackWorldFrame. | |
| double | trackPGain = 1.0 |
| P gain for tracking. Determines how fast the camera rotates to look at the target node. Valid range: [0-1]. | |
| bool | trackWorldFrame = false |
| Track point relative to target in world frame. | |
| Callback function for new frame render event listeners. | |
◆ BaseCamera()
protected |
◆ ~BaseCamera()
virtual |
◆ AddRenderPass()
overridevirtual |
[in] _pass New render pass to add
Implements Camera.
Reimplemented in OgreWideAngleCamera, Ogre2DepthCamera, and Ogre2WideAngleCamera.
References RenderTarget::AddRenderPass().
◆ AntiAliasing()
overridevirtual |
- Returns
- The level of anti-aliasing used during rendering
Implements Camera.
Reimplemented in OgreCamera, and Ogre2Camera.
◆ AspectRatio()
overridevirtual |
- Remarks
- If SetAspectRatio() gets called with an input <= 0 this function returns the Aspect Ratio autocalculated based on the camera's dimensions.
- Returns
- The camera's aspect ratio. This value is always in range (0; inf) unless the dimensions are invalid (e.g. 0 width or height, NaN resolution, etc)
Implements Camera.
◆ Capture()
overridevirtual |
[out] _image Output image buffer
Implements Camera.
◆ ConnectNewImageFrame()
overridevirtual |
[in] _listener New camera listener callback
Implements Camera.
◆ Copy()
overridevirtual |
Implements Camera.
Reimplemented in OgreWideAngleCamera, and Ogre2WideAngleCamera.
References RenderTarget::Copy().
◆ CreateImage()
overridevirtual |
- Returns
- A newly allocated Image for storing this cameras images
Implements Camera.
◆ CreateImageBuffer()
protectedvirtual |
◆ CreateRenderWindow()
overridevirtual |
- Returns
- A pointer to the render window.
Implements Camera.
References std::endl(), Scene::Engine(), gzerr, and RenderEngine::Name().
◆ FarClipPlane()
overridevirtual |
- Returns
- Far clipping plane distance
Implements Camera.
Reimplemented in OgreDepthCamera, and Ogre2DepthCamera.
◆ FollowOffset()
overridevirtual |
- Returns
- Offset of camera from target.
Implements Camera.
◆ FollowPGain()
overridevirtual |
◆ FollowTarget()
overridevirtual |
◆ HFOV()
overridevirtual |
- Returns
- Angle containing the camera's horizontal field-of-view
Implements Camera.
◆ ImageFormat()
overridevirtual |
- Returns
- The image pixel format
Implements Camera.
References RenderTarget::Format().
◆ ImageHeight()
overridevirtual |
- Returns
- The image height in pixels
Implements Camera.
References RenderTarget::Height().
◆ ImageMemorySize()
overridevirtual |
- Returns
- The image memory size in bytes
Implements Camera.
References PixelUtil::MemorySize().
◆ ImageWidth()
overridevirtual |
- Returns
- The image width in pixels
Implements Camera.
References RenderTarget::Width().
◆ Load()
overrideprotectedvirtual |
◆ NearClipPlane()
overridevirtual |
- Returns
- Near clipping plane distance
Implements Camera.
◆ PostRender()
overridevirtual |
Implements Camera.
Reimplemented in OgreDepthCamera, OgreGpuRays, OgreThermalCamera, OgreWideAngleCamera, Ogre2BoundingBoxCamera, Ogre2DepthCamera, Ogre2GpuRays, Ogre2SegmentationCamera, Ogre2ThermalCamera, and Ogre2WideAngleCamera.
References Object::PostRender().
◆ PrepareForExternalSampling()
overridevirtual |
Implements Camera.
Reimplemented in Ogre2Camera.
References std::endl(), and gzerr.
◆ PreRender()
overridevirtual |
References std::dynamic_pointer_cast(), gz::math::equal(), Quaternion< typename T >::Identity, Matrix4< typename T >::LookAt(), Pose3< typename T >::Pos(), RenderTarget::PreRender(), Pose3< typename T >::Rot(), and Quaternion< typename T >::Slerp().
◆ Project()
overridevirtual |
[in] _pt Point in 3d world space
- Returns
- Point in 2d screen space
Implements Camera.
References Vector2< typename T >::X(), Vector3< typename T >::X(), Vector2< typename T >::Y(), Vector3< typename T >::Y(), and Vector3< typename T >::Z().
◆ ProjectionMatrix()
overridevirtual |
- Returns
- Camera projection matrix
Implements Camera.
Reimplemented in OgreCamera, OgreDepthCamera, Ogre2BoundingBoxCamera, Ogre2Camera, Ogre2DepthCamera, Ogre2SegmentationCamera, and Ogre2ThermalCamera.
References std::atan(), gz::rendering::CPT_ORTHOGRAPHIC, gz::rendering::CPT_PERSPECTIVE, std::endl(), gzerr, and std::tan().
◆ ProjectionType()
overridevirtual |
◆ RemoveAllRenderPasses()
overridevirtual |
Implements Camera.
◆ RemoveRenderPass()
overridevirtual |
[in] _pass render pass to remove
Implements Camera.
References RenderTarget::RemoveRenderPass().
◆ RenderPassByIndex()
overridevirtual |
- Returns
- Render pass at the specified index
Implements Camera.
References RenderTarget::RenderPassByIndex().
◆ RenderPassCount()
overridevirtual |
- Returns
- Number of render passes applied
Implements Camera.
References RenderTarget::RenderPassCount().
◆ RenderTarget()
protectedpure virtual |
Implemented in OgreCamera, OgreDepthCamera, OgreGpuRays, OgreThermalCamera, OgreWideAngleCamera, Ogre2BoundingBoxCamera, Ogre2Camera, Ogre2DepthCamera, Ogre2GpuRays, Ogre2SegmentationCamera, Ogre2ThermalCamera, Ogre2WideAngleCamera, BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, and BaseGpuRays< OgreSensor >.
◆ RenderTextureGLId()
overridevirtual |
- Returns
- Texture Id of type GLuint.
Implements Camera.
◆ RenderTextureMetalId()
overridevirtual |
[out] _textureIdPtr the address of a void* pointer.
Implements Camera.
◆ Reset()
protectedvirtual |
References gz::rendering::PF_R8G8B8, and Angle::SetDegree().
◆ SaveFrame()
overridevirtual |
[in] _name Name of the output file
Implements Camera.
◆ SetAntiAliasing()
overridevirtual |
[in] _aa Level of anti-aliasing used during rendering
Implements Camera.
◆ SetAspectRatio()
overridevirtual |
[in] _ratio The camera's aspect ratio
Implements Camera.
◆ SetFarClipPlane()
overridevirtual |
[in] _far Far clipping plane distance
Implements Camera.
Reimplemented in OgreCamera, OgreDepthCamera, Ogre2Camera, and Ogre2DepthCamera.
References std::endl(), gzerr, and std::isfinite().
◆ SetFollowOffset()
overridevirtual |
[in] _offset Offset distance from target node.
Implements Camera.
◆ SetFollowPGain()
overridevirtual |
[in] _pGain P gain for camera following
Implements Camera.
References gz::math::clamp().
◆ SetFollowTarget()
overridevirtual |
[in] _target Target node to follow [in] _offset Tether the camera at an offset distance from the target node. [in] _worldFrame True to follow the target node at a distance that's fixed in world frame. Default is false which means the camera follows at fixed distance in target node's local frame.
Implements Camera.
◆ SetHFOV()
overridevirtual |
[in] _hfov Desired horizontal field-of-view
Implements Camera.
◆ SetImageFormat()
overridevirtual |
[in] _format New image pixel format [in] _reinterpretable See RenderTarget::SetFormat
Implements Camera.
References RenderTarget::SetFormat().
◆ SetImageHeight()
overridevirtual |
[in] _height New image height in pixels
Implements Camera.
References RenderTarget::SetHeight().
◆ SetImageWidth()
overridevirtual |
[in] _width New image width in pixels
Implements Camera.
References RenderTarget::SetWidth().
◆ SetMaterial()
overridevirtual |
[in] _material a material instance
Implements Camera.
◆ SetNearClipPlane()
overridevirtual |
[in] _near Near clipping plane distance
Implements Camera.
◆ SetProjectionMatrix()
overridevirtual |
[in] _matrix Camera projection matrix
Implements Camera.
◆ SetProjectionType()
overridevirtual |
[in] _type Camera projection type
- See also
- SetProjectionMatrix
Implements Camera.
◆ SetShadowsDirty()
overridevirtual |
Implements Camera.
Reimplemented in Ogre2Camera, and Ogre2DepthCamera.
◆ SetTrackOffset()
overridevirtual |
◆ SetTrackPGain()
overridevirtual |
[in] _pGain P gain for camera tracking
Implements Camera.
◆ SetTrackTarget()
overridevirtual |
[in] _target Target node to track [in] _offset Track a point that is at an offset relative to target. [in] _worldFrame If true, the offset point to track will be treated in world frame and its position relative to the target node remains fixed regardless of the target node's rotation. Default is false, which means the camera tracks the point in target node's local frame.
Implements Camera.
◆ TrackOffset()
overridevirtual |
- Returns
- Point offset from target.
Implements Camera.
◆ TrackPGain()
overridevirtual |
◆ TrackTarget()
overridevirtual |
◆ Update()
overridevirtual |
Implements Camera.
References Scene::PostRender(), and Scene::PreRender().
◆ ViewMatrix()
overridevirtual |
- Returns
- Camera view matrix
Implements Camera.
References Matrix4< typename T >::SetTranslation(), and Matrix3< typename T >::Transpose().
◆ VisualAt()
overridevirtual |
Implements Camera.
◆ antiAliasing
protected |
Anti-aliasing.
◆ aspect
protected |
Aspect ratio.
◆ farClip
protected |
◆ followNode
protected |
◆ followOffset
protected |
◆ followPGain
protected |
◆ followWorldFrame
protected |
◆ hfov
protected |
◆ imageBuffer
protected |
◆ nearClip
protected |
◆ newFrameEvent
protected |
◆ projectionMatrix
protected |
◆ projectionType
protected |
◆ trackNode
protected |
◆ trackOffset
protected |
◆ trackPGain
protected |
◆ trackWorldFrame
protected |
