Depth camera used to render depth data into an image buffer. More...
#include <Ogre2DepthCamera.hh>
virtual ~Ogre2DepthCamera ()
void AddRenderPass (const RenderPassPtr &_pass) override
virtual gz::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new depth image signal.
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new rgb point cloud signal.
virtual void CreateDepthTexture () override
 Create a texture which will hold the depth data.
 Create dummy render texture. Needed to satisfy inheritance.
virtual const float * DepthData () const override
 All things needed to get back z buffer for depth data.
double FarClipPlane () const override
 Get the far clip distance.
 Initialize the camera.
double NearClipPlane () const override
 Get the near clip distance.
virtual Ogre::Camera * OgreCamera () const override
 Access the Ogre::Camera object.
 Render the camera.
 Get the projection matrix for this camera. The depth rows of the returned matrix encode the configured near and far clip planes (see NearClipPlane and FarClipPlane). Internally the depth camera renders with slightly widened clip distances and clamps to the configured range in shaders; this is not exposed here.
 Implementation of the render call.
 Set the far clip distance.
 Set the near clip distance.
 Set the projection matrix for this camera. Only the image plane rows (0 and 1) of the given matrix, i.e. the focal lengths, principal point and skew, are used. The depth rows (2 and 3) are derived from the configured near and far clip planes so that depth rendering stays consistent with the camera frustum. Consequently ProjectionMatrix() returns the given image plane rows together with depth rows encoding the configured clip planes.
void SetShadowsDirty () override
- Public Member Functions inherited from BaseDepthCamera< Ogre2Sensor >
 ~BaseDepthCamera () override
virtual gz::common::ConnectionPtr ConnectNewRGBPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)
- Public Member Functions inherited from DepthCamera
virtual ~DepthCamera ()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal.
virtual ~Camera ()
 Sensor.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask.
 Get visibility mask.
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
- Public Member Functions inherited from Ogre2ObjectInterface
virtual ~Ogre2ObjectInterface ()
 Access to an Ogre::MovableObject.
 Ogre2DepthCamera ()
void CreateCamera ()
 Create the camera.
 Get a pointer to the render target.
- Protected Member Functions inherited from BaseDepthCamera< Ogre2Sensor >
 BaseDepthCamera ()
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node.
Static Protected Member Functions
static double LimitFOV (const double _fov)
 Limit field of view taking care of using a valid value for an OGRE camera.
Ogre::Camera * ogreCamera
 Pointer to the ogre camera.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
uint32_t visibilityMask
 Camera's visibility mask.
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
- Public Types inherited from DepthCamera
◆ Ogre2DepthCamera()
Ogre2DepthCamera ( )
◆ ~Ogre2DepthCamera()
virtual ~Ogre2DepthCamera ( )
◆ AddRenderPass()
Implements Camera.
◆ ConnectNewDepthFrame()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Reimplemented from BaseDepthCamera< Ogre2Sensor >.
◆ ConnectNewRgbPointCloud()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateDepthTexture()
virtual void CreateDepthTexture ( )
Set up 1st pass material, texture, and compositor
◆ CreateRenderTexture()
◆ DepthData()
virtual const float * DepthData ( ) const
The z-buffer as a float array
◆ FarClipPlane()
double FarClipPlane ( ) const
Far clip distance. A value of zero is returned if the ogre camera has not been created.
Implements Camera.
Reimplemented from Ogre2Node.
◆ LimitFOV()
static double LimitFOV ( const double  _fov)
staticprotected
[in]_fovexpected field of view
valid field of view
◆ NearClipPlane()
Near clip distance. A value of zero is returned if the ogre camera has not been created.
Implements Camera.
◆ OgreCamera()
virtual Ogre::Camera * OgreCamera ( ) const
Implements Ogre2ObjectInterface.
◆ PostRender()
virtual void PostRender ( )
Render the camera.
Implements Camera.
◆ ProjectionMatrix()
Camera projection matrix
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< T >.
◆ SetFarClipPlane()
[in]_farfar clip distance
Implements Camera.
◆ SetNearClipPlane()
[in]_nearNear clip distance
Implements Camera.
◆ SetProjectionMatrix()
Implements Camera.
◆ SetShadowsDirty()
void SetShadowsDirty ( )
Implements Camera.
◆ ogreCamera
Ogre::Camera* ogreCamera
