Ogre2.x implementation of the Node class. More...
#include <Ogre2Node.hh>
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 Ogre2Node ()
 Set the parent node.
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2Node()
Ogre2Node ( )
◆ ~Ogre2Node()
virtual ~Ogre2Node ( )
◆ AttachChild()
◆ Children()
virtual NodeStorePtr Children ( ) const
◆ DetachChild()
virtual bool DetachChild ( NodePtr  _child)
◆ HasParent()
Implements Node.
◆ InheritScale()
Implements BaseNode< Ogre2Object >.
◆ Load()
virtual void Load ( )
Reimplemented in BaseCamera< Ogre2Sensor >.
◆ LocalScale()
The local scale
Reimplemented in BaseAxisVisual< Ogre2Visual >.
◆ Node()
virtual Ogre::SceneNode * Node ( ) const
Ogre scene node pointer
◆ Parent()
the parent Node
◆ RawLocalPose()
◆ RawLocalPosition()
virtual math::Vector3d RawLocalPosition ( ) const
Local position
◆ RawLocalRotation()
virtual math::Quaterniond RawLocalRotation ( ) const
Local rotation
◆ SetInheritScale()
[in]_inheritTrue if this node inherits scale from its parent
Implements Node.
◆ SetLocalScaleImpl()
◆ SetParent()
virtual void SetParent ( Ogre2NodePtr  _parent)
[in]_parentThe parent ogre node
◆ SetRawLocalPose()
virtual void SetRawLocalPose ( const math::Pose3d &  _Pose3d)
◆ SetRawLocalPosition()
virtual void SetRawLocalPosition ( const math::Vector3d &  _position)
[in]_positionLocal position to set the node to
◆ SetRawLocalRotation()
virtual void SetRawLocalRotation ( const math::Quaterniond &  _rotation)
[in]_rotationLocal rotation to set the node to
◆ children
◆ ogreNode
Ogre::SceneNode* ogreNode = nullptr
◆ parent
Ogre2NodePtr parent
