Base implementation of a light visual. More...
#include <BaseLightVisual.hh>
virtual ~BaseLightVisual ()
std::vector< gz::math::Vector3d > CreateVisualLines ()
 Draw the light visual using dynamic renderables.
 Get inner angle.
 Get outer angle.
 Set inner angle for spot lights.
virtual void SetOuterAngle (double _outerAngle) override
 Set outer angle for spot lights.
 set type of the light
 Get light visual type.
virtual ~LightVisual ()
 Descructor.
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseLightVisual ()
bool dirtyLightVisual = false
 Flag to indicate light properties have changed.
double innerAngle = 0
 Inner angle for spot lights.
double outerAngle = 0
 Outer angle for spot lights.
LightVisualType type = LightVisualType::LVT_EMPTY
 Type of light visual.
template<class T>
class gz::rendering::BaseLightVisual< T >
◆ BaseLightVisual()
template<class T >
BaseLightVisual ( )
◆ ~BaseLightVisual()
template<class T >
~BaseLightVisual ( )
◆ CreateVisualLines()
template<class T >
std::vector< gz::math::Vector3d > CreateVisualLines ( )
References vector< T >::emplace_back(), gz::rendering::LVT_DIRECTIONAL, gz::rendering::LVT_POINT, and gz::rendering::LVT_SPOT.
template<class T >
void Init ( )
Reimplemented in OgreLightVisual, and Ogre2LightVisual.
◆ InnerAngle()
template<class T >
double InnerAngle ( )
Get inner angle.
The light inner angle
Implements LightVisual.
◆ OuterAngle()
template<class T >
double OuterAngle ( )
Get outer angle.
The light outer angle
template<class T >
void PreRender ( )
◆ SetInnerAngle()
template<class T >
void SetInnerAngle ( double  _innerAngle)
[in]_innerAngleInner angle
◆ SetOuterAngle()
template<class T >
void SetOuterAngle ( double  _outerAngle)
[in]_outerAngleOuter angle
◆ SetType()
template<class T >
void SetType ( LightVisualType  _type)
[in]_typetype of the light
◆ Type()
template<class T >
LightVisualType Type ( )
The light visual type
◆ dirtyLightVisual
template<class T >
◆ innerAngle
template<class T >
◆ outerAngle
template<class T >
◆ type
template<class T >
