LightVisual Class Referenceabstract
Represents a light visual. More...
#include <gz/rendering/LightVisual.hh>
virtual ~LightVisual ()
 Descructor.
virtual double InnerAngle ()=0
 Get inner angle.
virtual double OuterAngle ()=0
 Get outer angle.
virtual void SetInnerAngle (double _innerAngle)=0
 Set inner angle for spot lights.
virtual void SetOuterAngle (double _outerAngle)=0
 Set outer angle for spot lights.
virtual void SetType (LightVisualType _type)=0
 set type of the light
virtual LightVisualType Type ()=0
 Get light visual type.
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~LightVisual()
virtual ~LightVisual ( )
Descructor.
◆ InnerAngle()
virtual double InnerAngle ( )
Get inner angle.
The light inner angle
Implemented in BaseLightVisual< T >, BaseLightVisual< Ogre2Visual >, and BaseLightVisual< OgreVisual >.
◆ OuterAngle()
virtual double OuterAngle ( )
Get outer angle.
The light outer angle
◆ SetInnerAngle()
virtual void SetInnerAngle ( double  _innerAngle)
[in]_innerAngleInner angle
◆ SetOuterAngle()
virtual void SetOuterAngle ( double  _outerAngle)
[in]_outerAngleOuter angle
◆ SetType()
virtual void SetType ( LightVisualType  _type)
[in]_typetype of the light
◆ Type()
virtual LightVisualType Type ( )
The light visual type
