#include <OgreLightVisual.hh>
virtual ~OgreLightVisual ()
void CreateVisual ()
 Create the Light Visual in Ogre.
 Set the material for all attached visuals and geometries.
- Public Member Functions inherited from BaseLightVisual< OgreVisual >
virtual ~BaseLightVisual ()
std::vector< gz::math::Vector3d > CreateVisualLines ()
 Draw the light visual using dynamic renderables.
 Get inner angle.
 Get outer angle.
 Set inner angle for spot lights.
virtual void SetOuterAngle (double _outerAngle) override
 Set outer angle for spot lights.
 set type of the light
 Get light visual type.
virtual ~LightVisual ()
 Descructor.
virtual ~OgreVisual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreLightVisual ()
 Set material to grid geometry.
- Protected Member Functions inherited from BaseLightVisual< OgreVisual >
 BaseLightVisual ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseLightVisual< OgreVisual >
bool dirtyLightVisual
 Flag to indicate light properties have changed.
double innerAngle
 Inner angle for spot lights.
double outerAngle
 Outer angle for spot lights.
LightVisualType type
 Type of light visual.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreLightVisual()
OgreLightVisual ( )
◆ ~OgreLightVisual()
virtual ~OgreLightVisual ( )
◆ CreateVisual()
void CreateVisual ( )
Reimplemented from BaseLightVisual< OgreVisual >.
Implements Visual.
◆ OgreObject()
Ogre::MovableObject * OgreObject ( ) const
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
