#include <OgreVisual.hh>
virtual ~OgreVisual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreVisual()
OgreVisual ( )
◆ ~OgreVisual()
virtual ~OgreVisual ( )
◆ AttachGeometry()
◆ BoundingBox()
virtual gz::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Reimplemented from BaseVisual< OgreNode >.
◆ DetachGeometry()
◆ Geometries()
◆ LocalBoundingBox()
virtual gz::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
◆ SetVisibilityFlags()
[in]_flagsVisibility flags
◆ SetVisible()
Reimplemented in BaseArrowVisual< OgreVisual >, BaseAxisVisual< OgreVisual >, BaseJointVisual< OgreVisual >, OgreFrustumVisual, and OgreLidarVisual.
◆ SetWireframe()
◆ Wireframe()
◆ geometries
