A base implementation of the GizmoVisual class. More...
#include <BaseGizmoVisual.hh>
virtual ~BaseGizmoVisual ()
 Get the current active axis.
 Get the Transform axis associated with the given id.
 Get the child visual by axis.
virtual void LookAt (const math::Vector3d &_pos, const math::Quaterniond &_rot) override
 Update the Gizmo visual's rotation visuals to face the specified position.
 Get the current transform mode.
 Reset the gizmo visual state.
 Set the active axis in the gizmo visual.
 Set the transform mode of the gizmo. This controls the visual appearance of the gizmo. Only the visuals in the specified mode will be visible, e.g. if set to TM_TRANSLATION mode, then only the translation axis visuals will be visible.
virtual ~GizmoVisual ()
virtual ~CompositeVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
Protected Types
enum  AxisMaterial {
  AM_X , AM_Y , AM_Z , AM_ACTIVE ,
  AM_O , AM_HANDLE
 BaseGizmoVisual ()
void CreateMaterials ()
 Create materials used by the gizmo visual.
void CreateRotationVisual ()
 Create gizmo visual for rotation.
void CreateScaleVisual ()
 Create gizmo visual for scale.
 Create gizmo visual for translation.
VisualPtr activeVis
 Currently active visual.
math::Vector3d axis = math::Vector3d::Zero
 Active axis.
 A map of gizmo axis and their handle visuals.
 A map of axis enums to materials.
TransformMode mode = TransformMode::TM_NONE
 Current gizmo mode.
bool modeDirty = false
 Flag to indicate the mode has changed.
 A map of gizmo axis and their visuals.
template<class T>
class gz::rendering::BaseGizmoVisual< T >
◆ AxisMaterial
template<class T >
enum AxisMaterial
Enumerator
AM_X
X axis.
AM_Y
Y axis.
AM_Z
Z axis.
AM_ACTIVE
Active axis.
AM_O
Origin.
AM_HANDLE
handle
◆ BaseGizmoVisual()
template<class T >
BaseGizmoVisual ( )
◆ ~BaseGizmoVisual()
template<class T >
~BaseGizmoVisual ( )
◆ ActiveAxis()
template<class T >
math::Vector3d ActiveAxis ( ) const
Active axis
SetActiveAxis
Implements GizmoVisual.
◆ AxisById()
template<class T >
TransformAxis AxisById ( unsigned int  _id) const
References gz::rendering::TA_NONE.
◆ ChildByAxis()
template<class T >
VisualPtr ChildByAxis ( unsigned int  _axis) const
TransformAxis, TransformMode
◆ CreateMaterials()
template<class T >
void CreateMaterials ( )
References Scene::CreateMaterial(), and Scene::Material().
◆ CreateRotationVisual()
template<class T >
void CreateRotationVisual ( )
◆ CreateScaleVisual()
template<class T >
void CreateScaleVisual ( )
◆ CreateTranslationVisual()
template<class T >
void CreateTranslationVisual ( )
template<class T >
void Init ( )
◆ LookAt()
template<class T >
void LookAt ( const math::Vector3d &  _pos,
const math::Quaterniond &  _rot
[in]_posPosition to face. One typical position to face is the eye (camera) position so that the rotation visuals are rendered in a pose that is not behind the object the Gizmo visual is attached to.
[in]_rotRotation to be applied. For local space rotation, set this to the rotation of the object that the Gizmo visual is attached to so that the rotation visuals are rotated to match the object's rotation. For world space rotation, set this to identity quarternion for rotation visuals to be rendered in a pose that the rotation visuals are aligned with the world axes.
References GZ_PI, Matrix4< typename T >::LookAt(), Vector3< typename T >::Normalize(), Quaternion< typename T >::RotateVectorReverse(), Matrix4< typename T >::Rotation(), gz::rendering::TA_ROTATION_X, gz::rendering::TA_ROTATION_Y, gz::rendering::TA_ROTATION_Z, Vector3< typename T >::X(), Vector3< typename T >::Y(), and Vector3< typename T >::Z().
◆ Mode()
template<class T >
TransformMode Mode ( ) const
Transform mode
SetTransformMode
template<class T >
void PreRender ( )
◆ Reset()
◆ SetActiveAxis()
template<class T >
void SetActiveAxis ( const math::Vector3d &  _axis)
◆ SetTransformMode()
template<class T >
void SetTransformMode ( TransformMode  _mode)
GizmoMode
References Vector3< typename T >::Zero.
◆ activeVis
template<class T >
VisualPtr activeVis
◆ axis
template<class T >
Active axis.
◆ handles
template<class T >
std::map<unsigned int, VisualPtr> handles
◆ materials
template<class T >
std::map<unsigned int, MaterialPtr> materials
◆ mode
template<class T >
Current gizmo mode.
◆ modeDirty
template<class T >
◆ visuals
template<class T >
std::map<unsigned int, VisualPtr> visuals
