GizmoVisual Class Referenceabstract
#include <gz/rendering/GizmoVisual.hh>
virtual ~GizmoVisual ()
virtual math::Vector3d ActiveAxis () const =0
 Get the current active axis.
virtual TransformAxis AxisById (unsigned int _id) const =0
 Get the Transform axis associated with the given id.
virtual VisualPtr ChildByAxis (unsigned int _axis) const =0
 Get the child visual by axis.
virtual void LookAt (const math::Vector3d &_pos, const math::Quaterniond &_rot)=0
 Update the Gizmo visual's rotation visuals to face the specified position.
virtual TransformMode Mode () const =0
 Get the current transform mode.
virtual void SetActiveAxis (const math::Vector3d &_axis)=0
 Set the active axis in the gizmo visual.
virtual void SetTransformMode (TransformMode _mode)=0
 Set the transform mode of the gizmo. This controls the visual appearance of the gizmo. Only the visuals in the specified mode will be visible, e.g. if set to TM_TRANSLATION mode, then only the translation axis visuals will be visible.
virtual ~CompositeVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~GizmoVisual()
virtual ~GizmoVisual ( )
◆ ActiveAxis()
virtual math::Vector3d ActiveAxis ( ) const
Active axis
SetActiveAxis
Implemented in BaseGizmoVisual< T >, BaseGizmoVisual< Ogre2Visual >, and BaseGizmoVisual< OgreVisual >.
◆ AxisById()
virtual TransformAxis AxisById ( unsigned int  _id) const
◆ ChildByAxis()
virtual VisualPtr ChildByAxis ( unsigned int  _axis) const
TransformAxis, TransformMode
◆ LookAt()
virtual void LookAt ( const math::Vector3d &  _pos,
const math::Quaterniond &  _rot
[in]_posPosition to face. One typical position to face is the eye (camera) position so that the rotation visuals are rendered in a pose that is not behind the object the Gizmo visual is attached to.
[in]_rotRotation to be applied. For local space rotation, set this to the rotation of the object that the Gizmo visual is attached to so that the rotation visuals are rotated to match the object's rotation. For world space rotation, set this to identity quarternion for rotation visuals to be rendered in a pose that the rotation visuals are aligned with the world axes.
◆ Mode()
virtual TransformMode Mode ( ) const
Transform mode
SetTransformMode
◆ SetActiveAxis()
virtual void SetActiveAxis ( const math::Vector3d &  _axis)
◆ SetTransformMode()
virtual void SetTransformMode ( TransformMode  _mode)
GizmoMode
