Material Class Referenceabstract
Represents a surface material of a Geometry. More...
#include <gz/rendering/Material.hh>
virtual ~Material ()
virtual double AlphaThreshold () const =0
 Get the alpha threshold.
virtual math::Color Ambient () const =0
 Get the ambient color.
 Determine if this material casts shadows.
virtual void ClearEmissiveMap ()=0
 Removes any emissive map mapped to this material.
virtual void ClearEnvironmentMap ()=0
 Removes any environment map mapped to this material.
virtual void ClearLightMap ()=0
 Removes any light map mapped to this material.
virtual void ClearMetalnessMap ()=0
 Removes any metalness map mapped to this material.
virtual void ClearNormalMap ()=0
 Removes any normal map mapped to this material.
virtual void ClearRoughnessMap ()=0
 Removes any roughness map mapped to this material.
virtual void ClearTexture ()=0
 Removes any texture mapped to this material.
virtual MaterialPtr Clone (const std::string &_name="") const =0
 Clone this material.
virtual void CopyFrom (const common::Material &_material)=0
 Copy properties from given Material.
virtual void CopyFrom (ConstMaterialPtr _material)=0
virtual bool DepthCheckEnabled () const =0
 Determine if depth buffer checking is enabled.
virtual bool DepthWriteEnabled () const =0
 Determine if depth buffer writing is enabled.
virtual math::Color Diffuse () const =0
 Get the diffuse color.
virtual math::Color Emissive () const =0
 Get the emissive color.
virtual std::string EmissiveMap () const =0
 Get the URI of the emissive map file.
virtual std::shared_ptr< const common::Image > EmissiveMapData () const =0
 Get the emissive map data.
virtual std::string EnvironmentMap () const =0
 Get the URI of the environment map file.
virtual std::shared_ptr< const common::Image > EnvironmentMapData () const =0
 Get the environment map data.
virtual std::string FragmentShader () const =0
 Get path to the fragment shader.
virtual ShaderParamsPtr FragmentShaderParams ()=0
 Get params for the fragment shader.
virtual bool HasEmissiveMap () const =0
 Determine if this material has an emissive map.
virtual bool HasEnvironmentMap () const =0
 Determine if this material has a environment map.
virtual bool HasLightMap () const =0
 Determine if this material has a light map.
virtual bool HasMetalnessMap () const =0
 Determine if this material has a metalness map.
virtual bool HasNormalMap () const =0
 Determine if this material has a normal map.
virtual bool HasRoughnessMap () const =0
 Determine if this material has a roughness map.
virtual bool HasTexture () const =0
 Determine if this material has a texture.
virtual bool LightingEnabled () const =0
 Determine if lighting affects this material.
virtual std::string LightMap () const =0
 Get the URI of the light map file.
virtual std::shared_ptr< const common::Image > LightMapData () const =0
 Get the light map data.
virtual unsigned int LightMapTexCoordSet () const =0
 Get the texture coordinate set used by lightmap.
virtual float Metalness () const =0
 Get the metalness value of this material.
virtual std::string MetalnessMap () const =0
 Get the URI of the metalness map file.
virtual std::shared_ptr< const common::Image > MetalnessMapData () const =0
 Get the metalness map data.
virtual std::string NormalMap () const =0
 Get the URI of the normal map file.
virtual std::shared_ptr< const common::Image > NormalMapData () const =0
 Get the normal map data.
virtual bool ReceiveShadows () const =0
 Determine if this material receives shadows.
virtual bool ReflectionEnabled () const =0
 Determine if this material has a reflection.
virtual double Reflectivity () const =0
 Get the reflectivity value.
virtual float RenderOrder () const =0
 Get the render order value of this material.
virtual float Roughness () const =0
 Get the roughness value of this material.
virtual std::string RoughnessMap () const =0
 Get the URI of the roughness map file.
virtual std::shared_ptr< const common::Image > RoughnessMapData () const =0
 Get the roughness map data.
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true)=0
 Set the material to use the alpha channel from the textures.
virtual void SetAmbient (const double _r, const double _g, const double _b, const double _a=1.0)=0
 Set the ambient color.
virtual void SetAmbient (const math::Color &_color)=0
virtual void SetCastShadows (const bool _castShadows)=0
 Specify if this material casts shadows.
virtual void SetDepthCheckEnabled (bool _enabled)=0
 Specify if depth buffer checking is enabled.
virtual void SetDepthMaterial (const double far, const double near)=0
 Configuration for Depth Material.
virtual void SetDepthWriteEnabled (bool _enabled)=0
 Specify if depth buffer writing is enabled.
virtual void SetDiffuse (const double _r, const double _g, const double _b, const double _a=1.0)=0
 Set the diffuse color.
virtual void SetDiffuse (const math::Color &_color)=0
virtual void SetEmissive (const double _r, const double _g, const double _b, const double _a=1.0)=0
 Set the emissive color.
virtual void SetEmissive (const math::Color &_color)=0
virtual void SetEmissiveMap (const std::string &_emissiveMap)
 Set the material emissive map.
virtual void SetEmissiveMap (const std::string &_emissiveMap, const std::shared_ptr< const common::Image > &_img)
virtual void SetEnvironmentMap (const std::string &_environmentMap)
 Set the material environment map.
virtual void SetEnvironmentMap (const std::string &_environmentMap, const std::shared_ptr< const common::Image > &_img)
virtual void SetFragmentShader (const std::string &_path)=0
 Set the fragment shader.
virtual void SetLightingEnabled (const bool _enabled)=0
 Specify if lighting affects this material.
virtual void SetLightMap (const std::string &_lightMap, const std::shared_ptr< const common::Image > &_img, unsigned int _uvSet=0)
 Set the material light map from an image loaded in memory.
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u)
 Set the material light map.
virtual void SetMetalness (const float _metalness)=0
 Set the metalness value. Only affects material of type MT_PBS.
virtual void SetMetalnessMap (const std::string &_metalnessMap)
 Set the material metalness map.
virtual void SetMetalnessMap (const std::string &_metalnessMap, const std::shared_ptr< const common::Image > &_img)
virtual void SetNormalMap (const std::string &_normalMap)
 Set the material normal map.
virtual void SetNormalMap (const std::string &_normalMap, const std::shared_ptr< const common::Image > &_img)
virtual void SetReceiveShadows (const bool _receiveShadows)=0
 Specify if this material receives shadows.
virtual void SetReflectionEnabled (const bool _enabled)=0
 Specify if this material has a reflection.
virtual void SetReflectivity (const double _reflectivity)=0
 Set the reflectivity value.
virtual void SetRenderOrder (const float _renderOrder)=0
 Set the render order. When polygons are coplanar, you can get problems with 'depth fighting' where the pixels from the two polys compete for the same screen pixel. This param help to avoid this problem.
virtual void SetRoughness (const float _roughness)=0
 Set the roughness value. Only affects material of type MT_PBS.
virtual void SetRoughnessMap (const std::string &_roughnessMap)
 Set the material roughness map.
virtual void SetRoughnessMap (const std::string &_roughnessMap, const std::shared_ptr< const common::Image > &_img)
virtual void SetShaderType (enum ShaderType _type)=0
 Set the ShaderType value.
virtual void SetShininess (const double _shininess)=0
 Set the shininess value.
virtual void SetSpecular (const double _r, const double _g, const double _b, const double _a=1.0)=0
 Set the specular color.
virtual void SetSpecular (const math::Color &_color)=0
virtual void SetTexture (const std::string &_texture)
 Set the material texture.
virtual void SetTexture (const std::string &_texture, const std::shared_ptr< const common::Image > &_img)
virtual void SetTransparency (const double _transparency)=0
 Set the transparency value.
virtual void SetVertexShader (const std::string &_path)=0
 Set the vertex shader.
virtual enum ShaderType ShaderType () const =0
 Get the ShaderType value.
virtual double Shininess () const =0
 Get the shininess value.
virtual math::Color Specular () const =0
 Get the specular color.
virtual std::string Texture () const =0
 Get the URI of the texture file.
virtual bool TextureAlphaEnabled () const =0
 Get the enable alpha from textures.
virtual std::shared_ptr< const common::Image > TextureData () const =0
 Get the texture data.
virtual double Transparency () const =0
 Get the transparency value.
virtual bool TwoSidedEnabled () const =0
 Get the enable two sided rendering value.
virtual enum MaterialType Type () const =0
virtual std::string VertexShader () const =0
 Get path to the vertex shader.
virtual ShaderParamsPtr VertexShaderParams ()=0
 Get params for the vertex shader.
◆ ~Material()
virtual ~Material ( )
◆ AlphaThreshold()
virtual double AlphaThreshold ( ) const
The alpha threshold value
Implemented in BaseMaterial< T >, BaseMaterial< Ogre2Object >, and BaseMaterial< OgreObject >.
◆ Ambient()
virtual math::Color Ambient ( ) const
The ambient color
Implemented in BaseMaterial< T >, BaseMaterial< Ogre2Object >, BaseMaterial< OgreObject >, and OgreMaterial.
◆ CastShadows()
◆ ClearEmissiveMap()
virtual void ClearEmissiveMap ( )
Implemented in BaseMaterial< T >, BaseMaterial< Ogre2Object >, BaseMaterial< OgreObject >, and Ogre2Material.
◆ ClearEnvironmentMap()
virtual void ClearEnvironmentMap ( )
◆ ClearLightMap()
virtual void ClearLightMap ( )
◆ ClearMetalnessMap()
virtual void ClearMetalnessMap ( )
◆ ClearNormalMap()
Implemented in BaseMaterial< T >, BaseMaterial< Ogre2Object >, BaseMaterial< OgreObject >, OgreMaterial, and Ogre2Material.
◆ ClearRoughnessMap()
virtual void ClearRoughnessMap ( )
◆ ClearTexture()
virtual void ClearTexture ( )
◆ Clone()
virtual MaterialPtr Clone ( const std::string &  _name = "") const
New cloned material
◆ CopyFrom() [1/2]
virtual void CopyFrom ( const common::Material &  _material)
[in]_materialSource Material to be copied from
◆ CopyFrom() [2/2]
virtual void CopyFrom ( ConstMaterialPtr  _material)
◆ DepthCheckEnabled()
◆ DepthWriteEnabled()
◆ Diffuse()
The diffuse color
◆ Emissive()
The emissive color
◆ EmissiveMap()
virtual std::string EmissiveMap ( ) const
◆ EmissiveMapData()
virtual std::shared_ptr< const common::Image > EmissiveMapData ( ) const
Pointer to the common::Image with the data if the texture was loaded from memory
◆ EnvironmentMap()
virtual std::string EnvironmentMap ( ) const
◆ EnvironmentMapData()
virtual std::shared_ptr< const common::Image > EnvironmentMapData ( ) const
◆ FragmentShader()
Path to fragment shader
◆ FragmentShaderParams()
editable parameters
◆ HasEmissiveMap()
virtual bool HasEmissiveMap ( ) const
◆ HasEnvironmentMap()
virtual bool HasEnvironmentMap ( ) const
◆ HasLightMap()
virtual bool HasLightMap ( ) const
True if this material has a light map
◆ HasMetalnessMap()
virtual bool HasMetalnessMap ( ) const
◆ HasNormalMap()
◆ HasRoughnessMap()
virtual bool HasRoughnessMap ( ) const
◆ HasTexture()
◆ LightingEnabled()
virtual bool LightingEnabled ( ) const
◆ LightMap()
virtual std::string LightMap ( ) const
◆ LightMapData()
virtual std::shared_ptr< const common::Image > LightMapData ( ) const
◆ LightMapTexCoordSet()
virtual unsigned int LightMapTexCoordSet ( ) const
texture coordinate set of the light map
◆ Metalness()
virtual float Metalness ( ) const
Material metalness
◆ MetalnessMap()
virtual std::string MetalnessMap ( ) const
◆ MetalnessMapData()
virtual std::shared_ptr< const common::Image > MetalnessMapData ( ) const
◆ NormalMap()
◆ NormalMapData()
virtual std::shared_ptr< const common::Image > NormalMapData ( ) const
◆ ReceiveShadows()
◆ ReflectionEnabled()
virtual bool ReflectionEnabled ( ) const
◆ Reflectivity()
virtual double Reflectivity ( ) const
The reflectivity value
◆ RenderOrder()
Material render order
◆ Roughness()
virtual float Roughness ( ) const
Material roughness
◆ RoughnessMap()
virtual std::string RoughnessMap ( ) const
◆ RoughnessMapData()
virtual std::shared_ptr< const common::Image > RoughnessMapData ( ) const
◆ SetAlphaFromTexture()
double  _alpha = 0.5,
bool  _twoSided = true
◆ SetAmbient() [1/2]
virtual void SetAmbient ( const double  _r,
const double  _g,
const double  _b,
const double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetAmbient() [2/2]
virtual void SetAmbient ( const math::Color &  _color)
[in]_colorNew ambient color
◆ SetCastShadows()
virtual void SetCastShadows ( const bool  _castShadows)
◆ SetDepthCheckEnabled()
◆ SetDepthMaterial()
virtual void SetDepthMaterial ( const double  far,
const double  near
◆ SetDepthWriteEnabled()
◆ SetDiffuse() [1/2]
virtual void SetDiffuse ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetDiffuse() [2/2]
[in]_colorNew diffuse color
◆ SetEmissive() [1/2]
virtual void SetEmissive ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetEmissive() [2/2]
[in]_colorNew emissive color
◆ SetEmissiveMap() [1/2]
virtual void SetEmissiveMap ( const std::string &  _emissiveMap)
inlinevirtual
[in]_emissiveMapMap URI of the new emissive map file
References Material::SetEmissiveMap().
Referenced by Material::SetEmissiveMap().
◆ SetEmissiveMap() [2/2]
virtual void SetEmissiveMap ( const std::string &  _emissiveMap,
const std::shared_ptr< const common::Image > &  _img
inlinevirtual
[in]_emissiveMapMap URI of the new emissive map file, or identifying name if map was set from raw data
[in]_imgImage data, nullptr if the image should be loaded from a file
Reimplemented in BaseMaterial< T >, BaseMaterial< Ogre2Object >, BaseMaterial< OgreObject >, and Ogre2Material.
◆ SetEnvironmentMap() [1/2]
virtual void SetEnvironmentMap ( const std::string &  _environmentMap)
inlinevirtual
[in]_environmentMapURI of the new environment map file
References Material::SetEnvironmentMap().
Referenced by Material::SetEnvironmentMap().
◆ SetEnvironmentMap() [2/2]
virtual void SetEnvironmentMap ( const std::string &  _environmentMap,
inlinevirtual
[in]_environmentMapURI of the new environment map file, or identifying name if map was set from raw data
◆ SetFragmentShader()
◆ SetLightingEnabled()
virtual void SetLightingEnabled ( const bool  _enabled)
◆ SetLightMap() [1/2]
virtual void SetLightMap ( const std::string &  _lightMap,
const std::shared_ptr< const common::Image > &  _img,
unsigned int  _uvSet = 0
inlinevirtual
[in]_lightMapURI of the new light map file
[in]_uvSetTexture coordinate set to use
◆ SetLightMap() [2/2]
unsigned int  _uvSet = 0u
inlinevirtual
References Material::SetLightMap().
Referenced by Material::SetLightMap().
◆ SetMetalness()
virtual void SetMetalness ( const float  _metalness)
◆ SetMetalnessMap() [1/2]
virtual void SetMetalnessMap ( const std::string &  _metalnessMap)
inlinevirtual
[in]_metalnessMapURI of the new metalness map file
References Material::SetMetalnessMap().
Referenced by Material::SetMetalnessMap().
◆ SetMetalnessMap() [2/2]
virtual void SetMetalnessMap ( const std::string &  _metalnessMap,
inlinevirtual
[in]_metalnessMapURI of the new metalness map file, or identifying name if map was set from raw data
◆ SetNormalMap() [1/2]
virtual void SetNormalMap ( const std::string &  _normalMap)
inlinevirtual
[in]_normalMapURI of the new normal map file
References Material::SetNormalMap().
Referenced by Material::SetNormalMap().
◆ SetNormalMap() [2/2]
virtual void SetNormalMap ( const std::string &  _normalMap,
inlinevirtual
[in]_normalMapURI of the new normal map file, or identifying name if map was set from raw data
Reimplemented in BaseMaterial< T >, BaseMaterial< Ogre2Object >, BaseMaterial< OgreObject >, Ogre2Material, and OgreMaterial.
◆ SetReceiveShadows()
◆ SetReflectionEnabled()
virtual void SetReflectionEnabled ( const bool  _enabled)
◆ SetReflectivity()
virtual void SetReflectivity ( const double  _reflectivity)
◆ SetRenderOrder()
◆ SetRoughness()
virtual void SetRoughness ( const float  _roughness)
◆ SetRoughnessMap() [1/2]
virtual void SetRoughnessMap ( const std::string &  _roughnessMap)
inlinevirtual
[in]_roughnessMapURI of the new roughness map file
References Material::SetRoughnessMap().
Referenced by Material::SetRoughnessMap().
◆ SetRoughnessMap() [2/2]
virtual void SetRoughnessMap ( const std::string &  _roughnessMap,
inlinevirtual
[in]_roughnessMapURI of the new roughness map file, or identifying name if map was set from raw data
◆ SetShaderType()
[in]_typeNew ShaderType value
◆ SetShininess()
virtual void SetShininess ( const double  _shininess)
◆ SetSpecular() [1/2]
virtual void SetSpecular ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetSpecular() [2/2]
[in]_colorNew specular color
◆ SetTexture() [1/2]
virtual void SetTexture ( const std::string &  _texture)
inlinevirtual
[in]_textureURI of the new texture file or identifying name if _img is set
References Material::SetTexture().
Referenced by Material::SetTexture().
◆ SetTexture() [2/2]
virtual void SetTexture ( const std::string &  _texture,
inlinevirtual
◆ SetTransparency()
◆ SetVertexShader()
◆ ShaderType()
The ShaderType value
◆ Shininess()
virtual double Shininess ( ) const
The shininess value
◆ Specular()
The specular color
◆ Texture()
◆ TextureAlphaEnabled()
virtual bool TextureAlphaEnabled ( ) const
The enable alpha value
◆ TextureData()
virtual std::shared_ptr< const common::Image > TextureData ( ) const
◆ Transparency()
virtual double Transparency ( ) const
The transparency value
◆ TwoSidedEnabled()
virtual bool TwoSidedEnabled ( ) const
The enable two sided rendering value
◆ Type()
virtual enum MaterialType Type ( ) const
◆ VertexShader()
Path to vertex shader
◆ VertexShaderParams()
editable parameters
