#include <OgreMaterial.hh>
virtual ~OgreMaterial ()
 Get the ambient color.
 Determine if this material casts shadows.
 Removes any normal map mapped to this material.
 Removes any texture mapped to this material.
 Determine if depth buffer checking is enabled.
 Determine if depth buffer writing is enabled.
 Get the diffuse color.
 Get the emissive color.
 Get path to the fragment shader.
 Get params for the fragment shader.
 Determine if this material has a normal map.
 Determine if this material has a texture.
 Determine if lighting affects this material.
virtual Ogre::MaterialPtr Material () const
 Get the URI of the normal map file.
virtual std::shared_ptr< const common::Image > NormalMapData () const override
 Get the normal map data.
 Determine if this material receives shadows.
 Determine if this material has a reflection.
 Get the reflectivity value.
virtual float RenderOrder () const override
 Get the render order value of this material.
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true) override
 Set the material to use the alpha channel from the textures.
 Set the ambient color.
 Specify if this material casts shadows.
 Specify if depth buffer checking is enabled.
 Configuration for Depth Material.
 Specify if depth buffer writing is enabled.
 Set the diffuse color.
 Set the emissive color.
 Set the fragment shader.
 Specify if lighting affects this material.
virtual void SetNormalMap (const std::string &_normalMap, const std::shared_ptr< const common::Image > &_img=nullptr) override
 Set the material normal map.
 Specify if this material receives shadows.
 Specify if this material has a reflection.
 Set the reflectivity value.
virtual void SetRenderOrder (const float _renderOrder) override
 Set the render order. When polygons are coplanar, you can get problems with 'depth fighting' where the pixels from the two polys compete for the same screen pixel. This param help to avoid this problem.
 Set the ShaderType value.
 Set the shininess value.
 Set the specular color.
virtual void SetTexture (const std::string &_texture, const std::shared_ptr< const common::Image > &_img=nullptr) override
 Set the material texture.
 Set the transparency value.
 Set the vertex shader.
 Get the ShaderType value.
 Get the shininess value.
 Get the specular color.
 Get the URI of the texture file.
virtual std::shared_ptr< const common::Image > TextureData () const override
 Get the texture data.
 Get the transparency value.
 Get path to the vertex shader.
 Get params for the vertex shader.
- Public Member Functions inherited from BaseMaterial< OgreObject >
virtual ~BaseMaterial ()
double AlphaThreshold () const override
 Get the alpha threshold.
 Removes any emissive map mapped to this material.
 Removes any environment map mapped to this material.
virtual void ClearLightMap () override
 Removes any light map mapped to this material.
 Removes any metalness map mapped to this material.
 Removes any roughness map mapped to this material.
 Clone this material.
 Copy properties from given Material.
 Get the URI of the emissive map file.
virtual std::shared_ptr< const common::Image > EmissiveMapData () const override
 Get the emissive map data.
 Get the URI of the environment map file.
virtual std::shared_ptr< const common::Image > EnvironmentMapData () const override
 Get the environment map data.
 Determine if this material has an emissive map.
 Determine if this material has a environment map.
virtual bool HasLightMap () const override
 Determine if this material has a light map.
 Determine if this material has a metalness map.
 Determine if this material has a roughness map.
virtual std::string LightMap () const override
 Get the URI of the light map file.
virtual std::shared_ptr< const common::Image > LightMapData () const override
 Get the light map data.
virtual unsigned int LightMapTexCoordSet () const override
 Get the texture coordinate set used by lightmap.
 Get the metalness value of this material.
 Get the URI of the metalness map file.
virtual std::shared_ptr< const common::Image > MetalnessMapData () const override
 Get the metalness map data.
 Get the roughness value of this material.
 Get the URI of the roughness map file.
virtual std::shared_ptr< const common::Image > RoughnessMapData () const override
 Get the roughness map data.
virtual void SetEmissiveMap (const std::string &_emissiveMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material emissive map.
virtual void SetEnvironmentMap (const std::string &_environmentMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material environment map.
virtual void SetLightMap (const std::string &_lightMap, const std::shared_ptr< const common::Image > &_img, unsigned int _uvSet=0u) override
 Set the material light map from an image loaded in memory.
virtual void SetMetalness (const float _metalness) override
 Set the metalness value. Only affects material of type MT_PBS.
virtual void SetMetalnessMap (const std::string &_metalnessMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material metalness map.
 Set the roughness value. Only affects material of type MT_PBS.
virtual void SetRoughnessMap (const std::string &_roughnessMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material roughness map.
bool TextureAlphaEnabled () const override
 Get the enable alpha from textures.
bool TwoSidedEnabled () const override
 Get the enable two sided rendering value.
virtual ~Material ()
virtual void SetEmissiveMap (const std::string &_emissiveMap)
virtual void SetEnvironmentMap (const std::string &_environmentMap)
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u)
 Set the material light map.
virtual void SetMetalnessMap (const std::string &_metalnessMap)
virtual void SetNormalMap (const std::string &_normalMap)
virtual void SetRoughnessMap (const std::string &_roughnessMap)
virtual void SetTexture (const std::string &_texture)
 OgreMaterial ()
virtual Ogre::TexturePtr CreateTexture (const std::string &_name)
virtual void LoadOneImage (const std::string &_name, Ogre::Image &_image)
void SetTextureDataImpl (const std::string &_texture, const std::shared_ptr< const common::Image > &_img)
 Set the texture for this material from an image that was loaded from memory.
virtual void SetTextureImpl (const std::string &_texture)
 Set the texture for this material.
virtual Ogre::TexturePtr Texture (const std::string &_name)
virtual void UpdateColorOperation ()
void UpdateShaderParams ()
 bind shader parameters that have changed
void UpdateShaderParams (ConstShaderParamsPtr _params, Ogre::GpuProgramParametersSharedPtr _ogreParams)
 Transfer params from gz-rendering type to ogre type.
virtual void UpdateTransparency ()
- Protected Member Functions inherited from BaseMaterial< OgreObject >
 BaseMaterial ()
ShaderParamsPtr fragmentShaderParams
 Parameters to be bound to the fragment shader.
std::string fragmentShaderPath
 Path to fragment shader program.
std::shared_ptr< const common::Image > normalMapData
 Normal map image if it was passed as binary data.
std::string normalMapName
Ogre::String ogreGroup
Ogre::MaterialPtr ogreMaterial
Ogre::Pass * ogrePass = nullptr
Ogre::Technique * ogreTechnique = nullptr
Ogre::TextureUnitState * ogreTexState = nullptr
enum ShaderType shaderType = ST_PIXEL
std::shared_ptr< const common::Image > textureData
 Diffuse texture image if it was passed as binary data.
std::string textureName
ShaderParamsPtr vertexShaderParams
 Parameters to be bound to the vertex shader.
std::string vertexShaderPath
 Path to vertex shader program.
- Protected Attributes inherited from BaseMaterial< OgreObject >
double alphaThreshold
 Threshold for alpha channel rejection.
math::Color ambient
 Ambient color.
bool castShadows
 Set to true to enable object with this material to cast shadows.
bool depthCheckEnabled
 Flag to indicate if depth buffer checking is enabled.
bool depthWriteEnabled
 Flag to indicate if depth buffer writing is enabled.
math::Color diffuse
 Diffuse color.
math::Color emissive
 Emissive color.
bool lightingEnabled
 Flag to indicate if dynamic lighting is enabled.
bool receiveShadows
 True if material receives shadows.
bool reflectionEnabled
 Flag to indicate if reflection is enabled.
double reflectivity
 Reflectivity.
double renderOrder
 Material render order.
double shininess
 Shininess factor.
math::Color specular
 Specular color.
bool textureAlphaEnabled
 Enable alpha channel based texture transparency.
double transparency
 Transparent. 1: fully transparent, 0: opaque.
bool twoSidedEnabled
 Enable two sided rendering.
◆ OgreMaterial()
OgreMaterial ( )
◆ ~OgreMaterial()
virtual ~OgreMaterial ( )
◆ Ambient()
virtual math::Color Ambient ( ) const
The ambient color
Reimplemented from BaseMaterial< OgreObject >.
◆ CastShadows()
◆ ClearNormalMap()
◆ ClearTexture()
virtual void ClearTexture ( )
◆ CreateTexture()
virtual Ogre::TexturePtr CreateTexture ( const std::string &  _name)
◆ DepthCheckEnabled()
◆ DepthWriteEnabled()
◆ Diffuse()
The diffuse color
◆ Emissive()
The emissive color
◆ FragmentShader()
◆ FragmentShaderParams()
editable parameters
◆ HasNormalMap()
◆ HasTexture()
◆ LightingEnabled()
virtual bool LightingEnabled ( ) const
◆ LoadOneImage()
virtual void LoadOneImage ( const std::string &  _name,
Ogre::Image &  _image
virtual Ogre::MaterialPtr Material ( ) const
◆ NormalMap()
◆ NormalMapData()
virtual std::shared_ptr< const common::Image > NormalMapData ( ) const
Pointer to the common::Image with the data if the texture was loaded from memory
◆ ReceiveShadows()
◆ ReflectionEnabled()
virtual bool ReflectionEnabled ( ) const
◆ Reflectivity()
virtual double Reflectivity ( ) const
The reflectivity value
◆ RenderOrder()
◆ SetAlphaFromTexture()
double  _alpha = 0.5,
bool  _twoSided = true
◆ SetAmbient()
virtual void SetAmbient ( const math::Color &  _color)
[in]_colorNew ambient color
◆ SetCastShadows()
virtual void SetCastShadows ( const bool  _castShadows)
◆ SetDepthCheckEnabled()
◆ SetDepthMaterial()
virtual void SetDepthMaterial ( const double  far,
const double  near
◆ SetDepthWriteEnabled()
◆ SetDiffuse()
[in]_colorNew diffuse color
◆ SetEmissive()
[in]_colorNew emissive color
◆ SetFragmentShader()
◆ SetLightingEnabled()
virtual void SetLightingEnabled ( const bool  _enabled)
◆ SetNormalMap()
virtual void SetNormalMap ( const std::string &  _normalMap,
const std::shared_ptr< const common::Image > &  _img = nullptr
[in]_normalMapURI of the new normal map file, or identifying name if map was set from raw data
[in]_imgImage data, nullptr if the image should be loaded from a file
◆ SetReceiveShadows()
◆ SetReflectionEnabled()
virtual void SetReflectionEnabled ( const bool  _enabled)
◆ SetReflectivity()
virtual void SetReflectivity ( const double  _reflectivity)
◆ SetRenderOrder()
◆ SetShaderType()
[in]_typeNew ShaderType value
◆ SetShininess()
virtual void SetShininess ( const double  _shininess)
◆ SetSpecular()
[in]_colorNew specular color
◆ SetTexture()
virtual void SetTexture ( const std::string &  _texture,
[in]_textureURI of the new texture file or identifying name if _img is set
◆ SetTextureDataImpl()
void SetTextureDataImpl ( const std::string &  _texture,
[in]_textureName of the texture.
[in]_imgcommon::Image containing the texture data
◆ SetTextureImpl()
virtual void SetTextureImpl ( const std::string &  _texture)
◆ SetTransparency()
◆ SetVertexShader()
◆ ShaderType()
The ShaderType value
◆ Shininess()
virtual double Shininess ( ) const
The shininess value
◆ Specular()
The specular color
◆ Texture() [1/2]
◆ Texture() [2/2]
virtual Ogre::TexturePtr Texture ( const std::string &  _name)
◆ TextureData()
virtual std::shared_ptr< const common::Image > TextureData ( ) const
◆ Transparency()
virtual double Transparency ( ) const
The transparency value
◆ UpdateColorOperation()
virtual void UpdateColorOperation ( )
◆ UpdateShaderParams() [1/2]
void UpdateShaderParams ( )
◆ UpdateShaderParams() [2/2]
void UpdateShaderParams ( ConstShaderParamsPtr  _params,
[in]_paramsGazebo Rendering params
[out]_ogreParamsogre type for holding params
◆ UpdateTransparency()
virtual void UpdateTransparency ( )
◆ VertexShader()
◆ VertexShaderParams()
editable parameters
◆ fragmentShaderParams
◆ fragmentShaderPath
◆ normalMapData
std::shared_ptr<const common::Image> normalMapData
◆ normalMapName
◆ ogreGroup
◆ ogreMaterial
◆ ogrePass
Ogre::Pass* ogrePass = nullptr
◆ ogreTechnique
Ogre::Technique* ogreTechnique = nullptr
◆ ogreTexState
Ogre::TextureUnitState* ogreTexState = nullptr
◆ shaderType
◆ textureData
std::shared_ptr<const common::Image> textureData
◆ textureName
◆ vertexShaderParams
◆ vertexShaderPath
