#include <BaseMaterial.hh>
virtual ~BaseMaterial ()
double AlphaThreshold () const override
 Get the alpha threshold.
 Get the ambient color.
 Determine if this material casts shadows.
 Removes any emissive map mapped to this material.
 Removes any environment map mapped to this material.
virtual void ClearLightMap () override
 Removes any light map mapped to this material.
 Removes any metalness map mapped to this material.
 Removes any normal map mapped to this material.
 Removes any roughness map mapped to this material.
 Removes any texture mapped to this material.
 Clone this material.
 Copy properties from given Material.
 Determine if depth buffer checking is enabled.
 Determine if depth buffer writing is enabled.
 Get the diffuse color.
 Get the emissive color.
 Get the URI of the emissive map file.
virtual std::shared_ptr< const common::Image > EmissiveMapData () const override
 Get the emissive map data.
 Get the URI of the environment map file.
virtual std::shared_ptr< const common::Image > EnvironmentMapData () const override
 Get the environment map data.
 Get path to the fragment shader.
 Get params for the fragment shader.
 Determine if this material has an emissive map.
 Determine if this material has a environment map.
virtual bool HasLightMap () const override
 Determine if this material has a light map.
 Determine if this material has a metalness map.
 Determine if this material has a normal map.
 Determine if this material has a roughness map.
 Determine if this material has a texture.
 Determine if lighting affects this material.
virtual std::string LightMap () const override
 Get the URI of the light map file.
virtual std::shared_ptr< const common::Image > LightMapData () const override
 Get the light map data.
virtual unsigned int LightMapTexCoordSet () const override
 Get the texture coordinate set used by lightmap.
 Get the metalness value of this material.
 Get the URI of the metalness map file.
virtual std::shared_ptr< const common::Image > MetalnessMapData () const override
 Get the metalness map data.
 Get the URI of the normal map file.
virtual std::shared_ptr< const common::Image > NormalMapData () const override
 Get the normal map data.
 Determine if this material receives shadows.
 Determine if this material has a reflection.
 Get the reflectivity value.
virtual float RenderOrder () const override
 Get the render order value of this material.
 Get the roughness value of this material.
 Get the URI of the roughness map file.
virtual std::shared_ptr< const common::Image > RoughnessMapData () const override
 Get the roughness map data.
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true) override
 Set the material to use the alpha channel from the textures.
 Set the ambient color.
 Specify if this material casts shadows.
 Specify if depth buffer checking is enabled.
 Configuration for Depth Material.
 Specify if depth buffer writing is enabled.
 Set the diffuse color.
 Set the emissive color.
virtual void SetEmissiveMap (const std::string &_emissiveMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material emissive map.
virtual void SetEnvironmentMap (const std::string &_environmentMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material environment map.
 Set the fragment shader.
 Specify if lighting affects this material.
virtual void SetLightMap (const std::string &_lightMap, const std::shared_ptr< const common::Image > &_img, unsigned int _uvSet=0u) override
 Set the material light map from an image loaded in memory.
virtual void SetMetalness (const float _metalness) override
 Set the metalness value. Only affects material of type MT_PBS.
virtual void SetMetalnessMap (const std::string &_metalnessMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material metalness map.
virtual void SetNormalMap (const std::string &_normalMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material normal map.
 Specify if this material receives shadows.
 Specify if this material has a reflection.
 Set the reflectivity value.
virtual void SetRenderOrder (const float _renderOrder) override
 Set the render order. When polygons are coplanar, you can get problems with 'depth fighting' where the pixels from the two polys compete for the same screen pixel. This param help to avoid this problem.
 Set the roughness value. Only affects material of type MT_PBS.
virtual void SetRoughnessMap (const std::string &_roughnessMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material roughness map.
 Set the ShaderType value.
 Set the shininess value.
 Set the specular color.
virtual void SetTexture (const std::string &_texture, const std::shared_ptr< const common::Image > &_img) override
 Set the material texture.
 Set the transparency value.
 Set the vertex shader.
 Get the ShaderType value.
 Get the shininess value.
 Get the specular color.
 Get the URI of the texture file.
bool TextureAlphaEnabled () const override
 Get the enable alpha from textures.
virtual std::shared_ptr< const common::Image > TextureData () const override
 Get the texture data.
 Get the transparency value.
bool TwoSidedEnabled () const override
 Get the enable two sided rendering value.
 Get path to the vertex shader.
 Get params for the vertex shader.
virtual ~Material ()
virtual void SetEmissiveMap (const std::string &_emissiveMap)
virtual void SetEnvironmentMap (const std::string &_environmentMap)
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u)
 Set the material light map.
virtual void SetMetalnessMap (const std::string &_metalnessMap)
virtual void SetNormalMap (const std::string &_normalMap)
virtual void SetRoughnessMap (const std::string &_roughnessMap)
virtual void SetTexture (const std::string &_texture)
 BaseMaterial ()
double alphaThreshold = 0.5
 Threshold for alpha channel rejection.
math::Color ambient
 Ambient color.
bool castShadows = true
 Set to true to enable object with this material to cast shadows.
bool depthCheckEnabled = true
 Flag to indicate if depth buffer checking is enabled.
bool depthWriteEnabled = true
 Flag to indicate if depth buffer writing is enabled.
math::Color diffuse
 Diffuse color.
math::Color emissive
 Emissive color.
bool lightingEnabled = false
 Flag to indicate if dynamic lighting is enabled.
bool receiveShadows = true
 True if material receives shadows.
bool reflectionEnabled = false
 Flag to indicate if reflection is enabled.
double reflectivity = 0.0
 Reflectivity.
double renderOrder = 0.0
 Material render order.
double shininess = 0.0
 Shininess factor.
math::Color specular
 Specular color.
bool textureAlphaEnabled = false
 Enable alpha channel based texture transparency.
double transparency = 0.0
 Transparent. 1: fully transparent, 0: opaque.
bool twoSidedEnabled = false
 Enable two sided rendering.
◆ BaseMaterial()
template<class T >
BaseMaterial ( )
◆ ~BaseMaterial()
template<class T >
~BaseMaterial ( )
◆ AlphaThreshold()
template<class T >
double AlphaThreshold ( ) const
The alpha threshold value
Implements Material.
◆ Ambient()
template<class T >
math::Color Ambient ( ) const
The ambient color
Reimplemented in OgreMaterial.
◆ CastShadows()
template<class T >
bool CastShadows ( ) const
◆ ClearEmissiveMap()
template<class T >
void ClearEmissiveMap ( )
Reimplemented in Ogre2Material.
◆ ClearEnvironmentMap()
template<class T >
void ClearEnvironmentMap ( )
◆ ClearLightMap()
template<class T >
void ClearLightMap ( )
◆ ClearMetalnessMap()
template<class T >
void ClearMetalnessMap ( )
◆ ClearNormalMap()
template<class T >
void ClearNormalMap ( )
Reimplemented in OgreMaterial, and Ogre2Material.
◆ ClearRoughnessMap()
template<class T >
void ClearRoughnessMap ( )
◆ ClearTexture()
template<class T >
void ClearTexture ( )
◆ Clone()
template<class T >
MaterialPtr Clone ( const std::string &  _name = "") const
New cloned material
References std::dynamic_pointer_cast().
◆ CopyFrom() [1/2]
◆ CopyFrom() [2/2]
template<class T >
void CopyFrom ( ConstMaterialPtr  _material)
[in]_materialSource Material to be copied from
◆ DepthCheckEnabled()
template<class T >
bool DepthCheckEnabled ( ) const
◆ DepthWriteEnabled()
template<class T >
bool DepthWriteEnabled ( ) const
◆ Diffuse()
template<class T >
math::Color Diffuse ( ) const
The diffuse color
◆ Emissive()
template<class T >
math::Color Emissive ( ) const
The emissive color
◆ EmissiveMap()
template<class T >
std::string EmissiveMap ( ) const
◆ EmissiveMapData()
template<class T >
std::shared_ptr< const common::Image > EmissiveMapData ( ) const
Pointer to the common::Image with the data if the texture was loaded from memory
◆ EnvironmentMap()
template<class T >
std::string EnvironmentMap ( ) const
◆ EnvironmentMapData()
template<class T >
std::shared_ptr< const common::Image > EnvironmentMapData ( ) const
◆ FragmentShader()
template<class T >
std::string FragmentShader ( ) const
Path to fragment shader
◆ FragmentShaderParams()
template<class T >
ShaderParamsPtr FragmentShaderParams ( )
editable parameters
◆ HasEmissiveMap()
template<class T >
bool HasEmissiveMap ( ) const
◆ HasEnvironmentMap()
template<class T >
bool HasEnvironmentMap ( ) const
◆ HasLightMap()
template<class T >
bool HasLightMap ( ) const
True if this material has a light map
◆ HasMetalnessMap()
template<class T >
bool HasMetalnessMap ( ) const
◆ HasNormalMap()
template<class T >
bool HasNormalMap ( ) const
◆ HasRoughnessMap()
template<class T >
bool HasRoughnessMap ( ) const
◆ HasTexture()
template<class T >
bool HasTexture ( ) const
◆ LightingEnabled()
template<class T >
bool LightingEnabled ( ) const
◆ LightMap()
template<class T >
std::string LightMap ( ) const
◆ LightMapData()
template<class T >
std::shared_ptr< const common::Image > LightMapData ( ) const
◆ LightMapTexCoordSet()
template<class T >
unsigned int LightMapTexCoordSet ( ) const
texture coordinate set of the light map
◆ Metalness()
template<class T >
float Metalness ( ) const
Material metalness
◆ MetalnessMap()
template<class T >
std::string MetalnessMap ( ) const
◆ MetalnessMapData()
template<class T >
std::shared_ptr< const common::Image > MetalnessMapData ( ) const
◆ NormalMap()
template<class T >
std::string NormalMap ( ) const
◆ NormalMapData()
template<class T >
std::shared_ptr< const common::Image > NormalMapData ( ) const
template<class T >
void PreRender ( )
◆ ReceiveShadows()
template<class T >
bool ReceiveShadows ( ) const
◆ ReflectionEnabled()
template<class T >
bool ReflectionEnabled ( ) const
◆ Reflectivity()
template<class T >
double Reflectivity ( ) const
The reflectivity value
◆ RenderOrder()
template<class T >
float RenderOrder ( ) const
◆ Reset()
template<class T >
void Reset ( )
◆ Roughness()
template<class T >
float Roughness ( ) const
Material roughness
◆ RoughnessMap()
template<class T >
std::string RoughnessMap ( ) const
◆ RoughnessMapData()
template<class T >
std::shared_ptr< const common::Image > RoughnessMapData ( ) const
◆ SetAlphaFromTexture()
template<class T >
void SetAlphaFromTexture ( bool  _enabled,
double  _alpha = 0.5,
bool  _twoSided = true
◆ SetAmbient() [1/2]
template<class T >
void SetAmbient ( const double  _r,
const double  _g,
const double  _b,
const double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetAmbient() [2/2]
template<class T >
void SetAmbient ( const math::Color &  _color)
[in]_colorNew ambient color
◆ SetCastShadows()
template<class T >
void SetCastShadows ( const bool  _castShadows)
◆ SetDepthCheckEnabled()
template<class T >
void SetDepthCheckEnabled ( bool  _enabled)
◆ SetDepthMaterial()
template<class T >
void SetDepthMaterial ( const double  far,
const double  near
◆ SetDepthWriteEnabled()
template<class T >
void SetDepthWriteEnabled ( bool  _enabled)
◆ SetDiffuse() [1/2]
template<class T >
void SetDiffuse ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetDiffuse() [2/2]
template<class T >
void SetDiffuse ( const math::Color &  _color)
[in]_colorNew diffuse color
◆ SetEmissive() [1/2]
template<class T >
void SetEmissive ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetEmissive() [2/2]
template<class T >
void SetEmissive ( const math::Color &  _color)
[in]_colorNew emissive color
◆ SetEmissiveMap()
template<class T >
void SetEmissiveMap ( const std::string &  _emissiveMap,
const std::shared_ptr< const common::Image > &  _img
[in]_emissiveMapMap URI of the new emissive map file, or identifying name if map was set from raw data
[in]_imgImage data, nullptr if the image should be loaded from a file
Reimplemented from Material.
◆ SetEnvironmentMap()
template<class T >
void SetEnvironmentMap ( const std::string &  _environmentMap,
[in]_environmentMapURI of the new environment map file, or identifying name if map was set from raw data
◆ SetFragmentShader()
template<class T >
void SetFragmentShader ( const std::string &  _path)
◆ SetLightingEnabled()
template<class T >
void SetLightingEnabled ( const bool  _enabled)
◆ SetLightMap()
template<class T >
void SetLightMap ( const std::string &  _lightMap,
const std::shared_ptr< const common::Image > &  _img,
unsigned int  _uvSet = 0u
[in]_lightMapURI of the new light map file
[in]_uvSetTexture coordinate set to use
◆ SetMetalness()
template<class T >
void SetMetalness ( const float  _metalness)
◆ SetMetalnessMap()
template<class T >
void SetMetalnessMap ( const std::string &  _metalnessMap,
[in]_metalnessMapURI of the new metalness map file, or identifying name if map was set from raw data
◆ SetNormalMap()
template<class T >
void SetNormalMap ( const std::string &  _normalMap,
[in]_normalMapURI of the new normal map file, or identifying name if map was set from raw data
Reimplemented in Ogre2Material, and OgreMaterial.
◆ SetReceiveShadows()
template<class T >
void SetReceiveShadows ( const bool  _receiveShadows)
◆ SetReflectionEnabled()
template<class T >
void SetReflectionEnabled ( const bool  _enabled)
◆ SetReflectivity()
template<class T >
void SetReflectivity ( const double  _reflectivity)
◆ SetRenderOrder()
template<class T >
void SetRenderOrder ( const float  _renderOrder)
◆ SetRoughness()
template<class T >
void SetRoughness ( const float  _roughness)
◆ SetRoughnessMap()
template<class T >
void SetRoughnessMap ( const std::string &  _roughnessMap,
[in]_roughnessMapURI of the new roughness map file, or identifying name if map was set from raw data
◆ SetShaderType()
template<class T >
inlineoverridevirtual
[in]_typeNew ShaderType value
◆ SetShininess()
template<class T >
void SetShininess ( const double  _shininess)
◆ SetSpecular() [1/2]
template<class T >
void SetSpecular ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetSpecular() [2/2]
template<class T >
void SetSpecular ( const math::Color &  _color)
[in]_colorNew specular color
◆ SetTexture()
template<class T >
void SetTexture ( const std::string &  _texture,
[in]_textureURI of the new texture file or identifying name if _img is set
◆ SetTransparency()
template<class T >
void SetTransparency ( const double  _transparency)
◆ SetVertexShader()
template<class T >
void SetVertexShader ( const std::string &  _path)
◆ ShaderType()
template<class T >
The ShaderType value
References gz::rendering::ST_PIXEL.
◆ Shininess()
template<class T >
double Shininess ( ) const
The shininess value
◆ Specular()
template<class T >
math::Color Specular ( ) const
The specular color
◆ Texture()
template<class T >
std::string Texture ( ) const
◆ TextureAlphaEnabled()
template<class T >
bool TextureAlphaEnabled ( ) const
The enable alpha value
◆ TextureData()
template<class T >
std::shared_ptr< const common::Image > TextureData ( ) const
◆ Transparency()
template<class T >
double Transparency ( ) const
The transparency value
◆ TwoSidedEnabled()
template<class T >
bool TwoSidedEnabled ( ) const
The enable two sided rendering value
◆ Type()
template<class T >
MaterialType Type ( ) const
References gz::rendering::MT_CLASSIC.
◆ VertexShader()
template<class T >
std::string VertexShader ( ) const
Path to vertex shader
◆ VertexShaderParams()
template<class T >
ShaderParamsPtr VertexShaderParams ( )
editable parameters
◆ alphaThreshold
template<class T >
◆ ambient
template<class T >
math::Color ambient
Ambient color.
◆ castShadows
template<class T >
◆ depthCheckEnabled
template<class T >
◆ depthWriteEnabled
template<class T >
◆ diffuse
template<class T >
math::Color diffuse
Diffuse color.
◆ emissive
template<class T >
Emissive color.
◆ lightingEnabled
template<class T >
◆ receiveShadows
template<class T >
◆ reflectionEnabled
template<class T >
◆ reflectivity
template<class T >
Reflectivity.
◆ renderOrder
template<class T >
◆ shininess
template<class T >
Shininess factor.
◆ specular
template<class T >
Specular color.
◆ textureAlphaEnabled
template<class T >
◆ transparency
template<class T >
◆ twoSidedEnabled
template<class T >
