Ogre 2.x implementation of the material class. More...
#include <Ogre2Material.hh>
virtual ~Ogre2Material ()
 Removes any emissive map mapped to this material.
 Removes any environment map mapped to this material.
virtual void ClearLightMap () override
 Removes any light map mapped to this material.
 Removes any metalness map mapped to this material.
 Removes any normal map mapped to this material.
 Removes any roughness map mapped to this material.
 Removes any texture mapped to this material.
virtual Ogre::HlmsPbsDatablock * Datablock () const
 Return ogre Hlms material pbs datablock.
 Determine if depth buffer checking is enabled.
 Determine if depth buffer writing is enabled.
 Get the diffuse color.
 Get the emissive color.
 Get the URI of the emissive map file.
virtual std::shared_ptr< const common::Image > EmissiveMapData () const override
 Get the emissive map data.
 Get the URI of the environment map file.
virtual std::shared_ptr< const common::Image > EnvironmentMapData () const override
 Get the environment map data.
virtual void FillUnlitDatablock (Ogre::HlmsUnlitDatablock *_datablock) const
 Fill the input unlit datablock with current material properties from the pbs datablock.
 Get path to the fragment shader.
 Get params for the fragment shader.
 Determine if this material has an emissive map.
 Determine if this material has a environment map.
virtual bool HasLightMap () const override
 Determine if this material has a light map.
 Determine if this material has a metalness map.
 Determine if this material has a normal map.
 Determine if this material has a roughness map.
 Determine if this material has a texture.
virtual std::string LightMap () const override
 Get the URI of the light map file.
virtual std::shared_ptr< const common::Image > LightMapData () const override
 Get the light map data.
virtual unsigned int LightMapTexCoordSet () const override
 Get the texture coordinate set used by lightmap.
virtual Ogre::MaterialPtr Material ()
 Return ogre low level material.
 Get the metalness value of this material.
 Get the URI of the metalness map file.
virtual std::shared_ptr< const common::Image > MetalnessMapData () const override
 Get the metalness map data.
 Get the URI of the normal map file.
virtual std::shared_ptr< const common::Image > NormalMapData () const override
 Get the normal map data.
 Determine if this material receives shadows.
virtual float RenderOrder () const override
 Get the render order value of this material.
 Get the roughness value of this material.
 Get the URI of the roughness map file.
virtual std::shared_ptr< const common::Image > RoughnessMapData () const override
 Get the roughness map data.
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true) override
 Set the material to use the alpha channel from the textures.
 Specify if depth buffer checking is enabled.
 Specify if depth buffer writing is enabled.
 Set the diffuse color.
 Set the emissive color.
virtual void SetEmissiveMap (const std::string &_emissiveMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material emissive map.
virtual void SetEnvironmentMap (const std::string &_environmentMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material environment map.
 Set the fragment shader.
virtual void SetLightMap (const std::string &_lightMap, const std::shared_ptr< const common::Image > &_img, unsigned int _uvSet=0u) override
 Set the material light map from an image loaded in memory.
virtual void SetMetalness (const float _roughness) override
 Set the metalness value. Only affects material of type MT_PBS.
virtual void SetMetalnessMap (const std::string &_metalnessMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material metalness map.
virtual void SetNormalMap (const std::string &_normalMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material normal map.
 Specify if this material receives shadows.
virtual void SetRenderOrder (const float _renderOrder) override
 Set the render order. When polygons are coplanar, you can get problems with 'depth fighting' where the pixels from the two polys compete for the same screen pixel. This param help to avoid this problem.
 Set the roughness value. Only affects material of type MT_PBS.
virtual void SetRoughnessMap (const std::string &_roughnessMap, const std::shared_ptr< const common::Image > &_img) override
 Set the material roughness map.
 Set the specular color.
virtual void SetTexture (const std::string &_texture, const std::shared_ptr< const common::Image > &_img) override
 Set the material texture.
 Set the transparency value.
 Set the vertex shader.
 Get the specular color.
 Get the URI of the texture file.
virtual std::shared_ptr< const common::Image > TextureData () const override
 Get the texture data.
virtual enum MaterialType Type () const override
virtual Ogre::HlmsUnlitDatablock * UnlitDatablock ()
 Return ogre Hlms material unlit datablock.
 Get path to the vertex shader.
 Get params for the vertex shader.
- Public Member Functions inherited from BaseMaterial< Ogre2Object >
virtual ~BaseMaterial ()
double AlphaThreshold () const override
 Get the alpha threshold.
 Get the ambient color.
 Determine if this material casts shadows.
 Clone this material.
 Copy properties from given Material.
 Determine if lighting affects this material.
 Determine if this material has a reflection.
 Get the reflectivity value.
 Set the ambient color.
 Specify if this material casts shadows.
 Configuration for Depth Material.
 Specify if lighting affects this material.
 Specify if this material has a reflection.
 Set the reflectivity value.
 Set the ShaderType value.
 Set the shininess value.
 Get the ShaderType value.
 Get the shininess value.
bool TextureAlphaEnabled () const override
 Get the enable alpha from textures.
 Get the transparency value.
bool TwoSidedEnabled () const override
 Get the enable two sided rendering value.
virtual ~Material ()
virtual void SetEmissiveMap (const std::string &_emissiveMap)
virtual void SetEnvironmentMap (const std::string &_environmentMap)
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u)
 Set the material light map.
virtual void SetMetalnessMap (const std::string &_metalnessMap)
virtual void SetNormalMap (const std::string &_normalMap)
virtual void SetRoughnessMap (const std::string &_roughnessMap)
virtual void SetTexture (const std::string &_texture)
 Ogre2Material ()
void SetTextureMapDataImpl (const std::string &_texture, const std::shared_ptr< const common::Image > &_img, Ogre::PbsTextureTypes _type)
 Set the texture map for this material from an image loaded in memory.
virtual void SetTextureMapImpl (const std::string &_texture, Ogre::PbsTextureTypes _type)
 Set the texture map for this material.
virtual Ogre::TextureGpu * Texture (const std::string &_name)
 Get a pointer to the ogre texture by name.
void UpdateShaderParams ()
 bind shader parameters that have changed
void UpdateShaderParams (ConstShaderParamsPtr _params, Ogre::GpuProgramParametersSharedPtr _ogreParams)
 Transfer params from gz-rendering type to ogre type.
virtual void UpdateTransparency ()
 Updates the material transparency in the engine, based on transparency and diffuse alpha values.
- Protected Member Functions inherited from BaseMaterial< Ogre2Object >
 BaseMaterial ()
std::string emissiveMapName
 Name of the emissive map.
std::string environmentMapName
 Name of the environment map.
std::string lightMapName
 Name of the light map.
unsigned int lightMapUvSet = 0u
 Texture coorindate set used by the light map.
std::string metalnessMapName
 Name of the metalness map.
std::string normalMapName
 Name of the normal map.
Ogre::HlmsPbsDatablock * ogreDatablock = nullptr
 Ogre data block containing all pbs material properties.
std::string ogreDatablockId
 Unique id assigned to ogre hlms datablock.
Ogre::HlmsPbs * ogreHlmsPbs = nullptr
 Ogre high level physical based shading object.
Ogre::MaterialPtr ogreMaterial
 Ogre material. Mainly used for render targets.
Ogre::HlmsUnlitDatablock * ogreUnlitDatablock = nullptr
 Ogre data block containing all unlit material properties.
std::string roughnessMapName
 Name of the roughness map.
std::string textureName
 Name of the texture.
- Protected Attributes inherited from BaseMaterial< Ogre2Object >
double alphaThreshold
 Threshold for alpha channel rejection.
math::Color ambient
 Ambient color.
bool castShadows
 Set to true to enable object with this material to cast shadows.
bool depthCheckEnabled
 Flag to indicate if depth buffer checking is enabled.
bool depthWriteEnabled
 Flag to indicate if depth buffer writing is enabled.
math::Color diffuse
 Diffuse color.
math::Color emissive
 Emissive color.
bool lightingEnabled
 Flag to indicate if dynamic lighting is enabled.
bool receiveShadows
 True if material receives shadows.
bool reflectionEnabled
 Flag to indicate if reflection is enabled.
double reflectivity
 Reflectivity.
double renderOrder
 Material render order.
double shininess
 Shininess factor.
math::Color specular
 Specular color.
bool textureAlphaEnabled
 Enable alpha channel based texture transparency.
double transparency
 Transparent. 1: fully transparent, 0: opaque.
bool twoSidedEnabled
 Enable two sided rendering.
 Pointer to the ogre scene.
◆ Ogre2Material()
Ogre2Material ( )
◆ ~Ogre2Material()
virtual ~Ogre2Material ( )
◆ ClearEmissiveMap()
virtual void ClearEmissiveMap ( )
Reimplemented from BaseMaterial< Ogre2Object >.
◆ ClearEnvironmentMap()
virtual void ClearEnvironmentMap ( )
◆ ClearLightMap()
virtual void ClearLightMap ( )
◆ ClearMetalnessMap()
virtual void ClearMetalnessMap ( )
◆ ClearNormalMap()
◆ ClearRoughnessMap()
virtual void ClearRoughnessMap ( )
◆ ClearTexture()
virtual void ClearTexture ( )
◆ Datablock()
virtual Ogre::HlmsPbsDatablock * Datablock ( ) const
Ogre Hlms pbs datablock
◆ DepthCheckEnabled()
◆ DepthWriteEnabled()
◆ Diffuse()
The diffuse color
◆ Emissive()
The emissive color
◆ EmissiveMap()
virtual std::string EmissiveMap ( ) const
◆ EmissiveMapData()
virtual std::shared_ptr< const common::Image > EmissiveMapData ( ) const
Pointer to the common::Image with the data if the texture was loaded from memory
◆ EnvironmentMap()
virtual std::string EnvironmentMap ( ) const
◆ EnvironmentMapData()
virtual std::shared_ptr< const common::Image > EnvironmentMapData ( ) const
◆ FillUnlitDatablock()
virtual void FillUnlitDatablock ( Ogre::HlmsUnlitDatablock *  _datablock) const
[in]_datablockUnlit datablock to fill
◆ FragmentShader()
Path to fragment shader
◆ FragmentShaderParams()
editable parameters
◆ HasEmissiveMap()
virtual bool HasEmissiveMap ( ) const
◆ HasEnvironmentMap()
virtual bool HasEnvironmentMap ( ) const
◆ HasLightMap()
virtual bool HasLightMap ( ) const
True if this material has a light map
◆ HasMetalnessMap()
virtual bool HasMetalnessMap ( ) const
◆ HasNormalMap()
◆ HasRoughnessMap()
virtual bool HasRoughnessMap ( ) const
◆ HasTexture()
◆ LightMap()
virtual std::string LightMap ( ) const
◆ LightMapData()
virtual std::shared_ptr< const common::Image > LightMapData ( ) const
◆ LightMapTexCoordSet()
virtual unsigned int LightMapTexCoordSet ( ) const
texture coordinate set of the light map
virtual Ogre::MaterialPtr Material ( )
Ogre material pointer
◆ Metalness()
virtual float Metalness ( ) const
Material metalness
◆ MetalnessMap()
virtual std::string MetalnessMap ( ) const
◆ MetalnessMapData()
virtual std::shared_ptr< const common::Image > MetalnessMapData ( ) const
◆ NormalMap()
◆ NormalMapData()
virtual std::shared_ptr< const common::Image > NormalMapData ( ) const
◆ ReceiveShadows()
◆ RenderOrder()
◆ Roughness()
virtual float Roughness ( ) const
Material roughness
◆ RoughnessMap()
virtual std::string RoughnessMap ( ) const
◆ RoughnessMapData()
virtual std::shared_ptr< const common::Image > RoughnessMapData ( ) const
◆ SetAlphaFromTexture()
double  _alpha = 0.5,
bool  _twoSided = true
◆ SetDepthCheckEnabled()
◆ SetDepthWriteEnabled()
◆ SetDiffuse()
[in]_colorNew diffuse color
◆ SetEmissive()
[in]_colorNew emissive color
◆ SetEmissiveMap()
virtual void SetEmissiveMap ( const std::string &  _emissiveMap,
const std::shared_ptr< const common::Image > &  _img
[in]_emissiveMapMap URI of the new emissive map file, or identifying name if map was set from raw data
[in]_imgImage data, nullptr if the image should be loaded from a file
◆ SetEnvironmentMap()
virtual void SetEnvironmentMap ( const std::string &  _environmentMap,
[in]_environmentMapURI of the new environment map file, or identifying name if map was set from raw data
◆ SetFragmentShader()
◆ SetLightMap()
virtual void SetLightMap ( const std::string &  _lightMap,
const std::shared_ptr< const common::Image > &  _img,
unsigned int  _uvSet = 0u
[in]_lightMapURI of the new light map file
[in]_uvSetTexture coordinate set to use
◆ SetMetalness()
virtual void SetMetalness ( const float  _metalness)
◆ SetMetalnessMap()
virtual void SetMetalnessMap ( const std::string &  _metalnessMap,
[in]_metalnessMapURI of the new metalness map file, or identifying name if map was set from raw data
◆ SetNormalMap()
virtual void SetNormalMap ( const std::string &  _normalMap,
[in]_normalMapURI of the new normal map file, or identifying name if map was set from raw data
◆ SetReceiveShadows()
◆ SetRenderOrder()
◆ SetRoughness()
virtual void SetRoughness ( const float  _roughness)
◆ SetRoughnessMap()
virtual void SetRoughnessMap ( const std::string &  _roughnessMap,
[in]_roughnessMapURI of the new roughness map file, or identifying name if map was set from raw data
◆ SetSpecular()
[in]_colorNew specular color
◆ SetTexture()
virtual void SetTexture ( const std::string &  _texture,
[in]_textureURI of the new texture file or identifying name if _img is set
◆ SetTextureMapDataImpl()
void SetTextureMapDataImpl ( const std::string &  _texture,
[in]_textureName of the texture.
[in]_imgcommon::Image containing the texture data
[in]_typeType of texture, i.e. diffuse, normal, roughness, metalness
◆ SetTextureMapImpl()
virtual void SetTextureMapImpl ( const std::string &  _texture,
◆ SetTransparency()
◆ SetVertexShader()
◆ Specular()
The specular color
◆ Texture() [1/2]
◆ Texture() [2/2]
virtual Ogre::TextureGpu * Texture ( const std::string &  _name)
Ogre texture
◆ TextureData()
virtual std::shared_ptr< const common::Image > TextureData ( ) const
◆ Type()
virtual enum MaterialType Type ( ) const
◆ UnlitDatablock()
virtual Ogre::HlmsUnlitDatablock * UnlitDatablock ( )
Ogre Hlms unlit datablock
◆ UpdateShaderParams() [1/2]
void UpdateShaderParams ( )
◆ UpdateShaderParams() [2/2]
void UpdateShaderParams ( ConstShaderParamsPtr  _params,
[in]_paramsGazebo Rendering params
[out]_ogreParamsogre type for holding params
◆ UpdateTransparency()
virtual void UpdateTransparency ( )
◆ VertexShader()
Path to vertex shader
◆ VertexShaderParams()
editable parameters
◆ emissiveMapName
◆ environmentMapName
◆ lightMapName
◆ lightMapUvSet
◆ metalnessMapName
◆ normalMapName
◆ ogreDatablock
Ogre::HlmsPbsDatablock* ogreDatablock = nullptr
◆ ogreDatablockId
◆ ogreHlmsPbs
Ogre::HlmsPbs* ogreHlmsPbs = nullptr
◆ ogreMaterial
◆ ogreUnlitDatablock
Ogre::HlmsUnlitDatablock* ogreUnlitDatablock = nullptr
◆ roughnessMapName
◆ textureName
